Minimalist Approach to Screen Wall - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 84Likes
post #361 of 507 Old 03-06-2014, 08:35 PM
san16's Avatar
Originally Posted by Spaceman View Post
Here is a modified version of the minimalist screen wall with 1x2 blocking around the perimeter (along ceiling, walls and floor). In my case, I'm using the blocking to attach the panels with ball and socket speaker grill pegs but I guess you could use it for the Fabricmate track. The screen itself only comes to the midpoint of the top and bottom cross pieces and the two vertical goal posts, so the other half is available for panel attachment.
All lumber was 1x2 and 1x4 FJP from HD. More detailed pics including perimeter blocking can be found here.
love your false wall
do you have pictures of the panels with the ball and socket speaker grill pegs and how you used it.
dabsabre likes this.
san16 is offline
post #362 of 507 Old 03-06-2014, 09:33 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
No pics of the false wall panels with their balls and sockets, but I documented how I used them for my other panels towards the end of this post.
Spaceman is offline
post #363 of 507 Old 03-07-2014, 01:01 PM
san16's Avatar
thanks
i plan to use seymore av screen. their screen is 1.6 inch thick. if the panels are made using 1 inch thick frames will the gap between the framed and screen border be an issue. Thanks for your help
san16 is offline
post #364 of 507 Old 03-07-2014, 01:57 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Originally Posted by san16 View Post
thanks
I have that same screen and it doesn't bother me that the screen frame sticks out a little more than the surrounding panels. Both the screen and the surrounding panels are wrapped in black velvet so it's almost impossible to see that the screen sticks out 1/2" more than the panels.
If I was doing my screen wall panels again, I'd construct them like I did in 7channelfreak's build. Instead of ripping 1/2" plywood into strips and doubling it up for a 1" thick panel, I doubled up 1x2 fjp boards (the same ones used on the false wall). It was much faster than ripping plywood and for just 4 frames, not too expensive. The 1x2s measure 3/4" thick, so with 2 layers, those panels wound up being 1.5" thick. They look pretty seamless when placed next to the 1.6" thick Seymour frame.
Either way looks fine though.
Spaceman is offline
post #365 of 507 Old 03-07-2014, 03:30 PM
san16's Avatar
thanks i think i will go the doubled up 1x2 fjb boards
san16 is offline
post #366 of 507 Old 04-04-2014, 04:56 AM
san16's Avatar
getting ready to treat front wall with oc 703. how do i attach the boards to the dry wall. Contractor is recommending liquid nails. Is that ok or do we need to use anything else
san16 is offline
post #367 of 507 Old 04-04-2014, 05:12 AM
NGiovas's Avatar
Liked: 43
I attached the OC 703 to my front wall using long screws with large fender washers.  I then covered the entire front wall with a single piece of accoustically transparent black cloth.
NGiovas is offline
post #368 of 507 Old 04-04-2014, 06:32 AM - Thread Starter
Quoted: 3199 Post(s)
Liked: 2687
instead of long screws and washers I grab Powerhead screws, It is a screw on steroids with a large flat head, http://www.fastcap.com/estore/pc/PowerHead-Screws-Metal-p13265.htm
there are other methods of attaching acoustical treatments, 3M Spray adhesive, impaling clips but a few screws goes quick
popalock likes this.
post #369 of 507 Old 04-04-2014, 08:12 AM
aaron_hinni's Avatar
It doesn't take much to hold up OC703. I just used some long finish nails and shot em in there so enough of the nail would go into the drywall to hold them up. Only needed a few nails per piece. If for whatever reason you need to take those pieces down (we had a pipe burst this winter, so had to take the entire room apart), you'll be thankful you didn't use liquid nails.
ADDUpstate likes this.
aaron_hinni is offline
post #370 of 507 Old 04-04-2014, 08:26 AM
jefftr's Avatar
Quoted: 20 Post(s)
Liked: 26
jefftr is offline
post #371 of 507 Old 04-11-2014, 08:20 AM
zebracatzebra's Avatar
This thread was very helpful during my recent upgrade to a 2.35:1 AT screen so I thought I'd share my results:
zebracatzebra is offline
post #372 of 507 Old 04-11-2014, 08:34 AM
avtexan's Avatar
Quoted: 47 Post(s)
Liked: 89
Originally Posted by jefftr View Post
I used these:
http://www.lowes.com/pd_7764-1278-GC3_0__?productId=3581456
I used the same ones that you did but just days after I was done I saw that Ace Hardware has them in black.
http://www.acehardware.com/product/index.jsp?productId=30685316&KPID=989856&pla=pla_989856
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
post #373 of 507 Old 04-11-2014, 12:22 PM
LoudDad's Avatar
Quoted: 27 Post(s)
Hey ZebraCatZebra (is there a story here?),
What you did is similar to what I'm planning on doing.  I have some tall tower speakers (Polk RTi A9) that I want to put behind an AT screen.
Looks like the way you did it you are blocking off the bottom of the speakers behind the screen.
Did you use some kind of AT material below the screen, and how did everything turn out with this kind of setup?
I was a bit worried that my tweeters would be higher than ear height, but not sure how much impact that has.
Bill
LoudDad is online now
post #374 of 507 Old 04-11-2014, 07:08 PM
Bill,
I'm very happy with the way it turned out and would do it the same way over again. My tweeters are slightly above ear level of the first row but it doesn't make a difference in sound quality to me. Actually it sounds great with the sound coming from behind the screen.
For the material around the screen, at Jo-Anne fabric they had this material called stretchy velvet. Does a great job of absorbing light and when stretched over the frames it is very breathable and sound passes through without any issues that I can detect. The tweeters and mid range drivers are directly behind the Seymour screen and the sub and bass drivers are directly behind the stretchy velvet.
Here's a picture of the frames without the velvet. They are just held in place with friction and easily pop off when needed.
post #375 of 507 Old 04-11-2014, 11:34 PM
Thundersnow's Avatar
Quoted: 13 Post(s)
Zebracatzebra, how is your screen material mounted? It almost looks like it's mounted directly to the studs with no frame? It looks really good thanks for sharing your pictures.
Thundersnow is online now
post #376 of 507 Old 04-12-2014, 10:13 AM
I built a frame out of 1x4 and then wrapped the screen around it and stapled it to the back. Then I used these french cleats to hang the frame from the horizontal beam.
http://t.homedepot.com/p/OOK-Hangman-13-Piece-French-Cleat-Picture-Hanger-Kit-with-Wall-Dogs-55312/202341625/
The fabric panels butt right up against the frame and absorb any light. This approach worked better for me than building a fabric wrapped frame then stapling the screen material to the back. I'd be happy to snap some pictures if you want to see any details, just let me know.
post #377 of 507 Old 04-12-2014, 12:18 PM
Quoted: 13 Post(s)
That's a very good idea. I was going to buy a frame but your idea I like better plus it should save me some money.
post #378 of 507 Old 04-13-2014, 04:31 PM
san16's Avatar
OC 703 is up. what is the best way to attach GOM FR701 black fabric in front of it. I put framing on all four borders of the wall and around the corner bass traps.
thanks
san16 is offline
post #379 of 507 Old 04-13-2014, 04:33 PM
san16's Avatar
Can I please get some recommendations for carpet for my theater room. Looking for patterned black or dark grey.
thanks
san16 is offline
post #380 of 507 Old 04-13-2014, 06:32 PM - Thread Starter
Liked: 2687
Lowes has patterned dark grey. see Bacon Race, Also check out the stickey thread, "Show me your carpet"
post #381 of 507 Old 04-13-2014, 06:33 PM - Thread Starter
Liked: 2687
thanks
I always use an upholstery stapler.
post #382 of 507 Old 04-13-2014, 08:42 PM
ADDUpstate's Avatar
thanks
Check out my thread in my signature. Just installed Royal Dutch Stanton Carlton in Blackstone. It's a black carpet with grey pattern.
ADDUpstate is offline
post #383 of 507 Old 07-17-2014, 11:03 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
anything 2 1/2 or over.
BIG,
Have you ever built your minimalist design over a carpeted floor not a stage? Reason I ask is I'm not doing a stage on my second floor theater. I have carpeted the room and I am ready to build the false wall and screen. I would love to find a way to build the false wall without screwing through the brand new carpet but I don't have the creative construction mind to figure out how to do that. Any recommendations?
wraunch is offline
post #384 of 507 Old 07-17-2014, 11:05 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Quote:Originally Posted by BIGmouthinDC
instead of long screws and washers I grab Powerhead screws, It is a screw on steroids with a large flat head, http://www.fastcap.com/estore/pc/Pow...tal-p13265.htm
thanks
I just did this. Look at my build. I used Stanton Carlyle in Blackstone.
wraunch is offline
post #385 of 507 Old 07-17-2014, 12:34 PM
dabsabre's Avatar
I'll be starting this effort shortly and plan on drawing it out to better visualize but I may need to run the support horizontally instead of vertically for a couple of reasons.
1. the false wall will be under part of a sloped ceiling. I could certainly figure out the angle and cut the top pieces at that angle if it comes to that
2. of bigger concern is that the room is already carpeted and I'd just assume not go thru the carpet into the subfloor when screwing down the bottom supports. might not pass the WAF in this case..
part of my problem with going with horizontal supports across the width of the room along the top and bottom of the screen is that my room is a little over 12' wide so I'm not going to be able to find a single board that would span the entire length of the room. If I could find a straight 12' board I could just add some blocking support that would attach into the side wall studs but finding a straight 12' board at Lowes and HD may prove problematic.. and of course having a board 20" off the ground running horizontally wall-to-wall would make access to the back of the screen a little more acrobatic
thoughts?
dabsabre is offline
post #386 of 507 Old 07-17-2014, 01:09 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I have the same dilemma with not wanting to anchor the false wall through the carpet. I'll be interested to see what solutions are offered.
wraunch is offline
post #387 of 507 Old 07-17-2014, 01:26 PM
Keith AP's Avatar
Quoted: 21 Post(s)
Liked: 25
Did you use 2x4 or 1x4 for the black framing members? I like how you've minimized the need for running framing across the entire width of the floor/ceiling.
dabsabre and 4AlexF like this.
Keith AP is offline
post #388 of 507 Old 07-17-2014, 02:32 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
I built my wall on top of my stage, but my stage was carpeted. I can tell you that one screw through the base into the carpet will not likely cause any harm, however, I understand your concerns.
One thing you can do, make the vertical supports 1/4" - 1/2" longer than you originally planned and then they will friction fit on top of the carpet. Screw into the ceiling to anchor, and unless you're body checking the wall, it should stay in place.
wraunch and ADDUpstate like this.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #389 of 507 Old 07-18-2014, 10:47 AM
I used 2x4's to make the frame and I'm happy with the way everything is holding up. I'm sure you could use 1x4's if you wanted, I just went the 2x4 route.
post #390 of 507 Old 07-20-2014, 06:09 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I just finished my 1x4" goalpost screen wall. I made "legs" for the back of it so I wouldn't have to screw through the carpet. Seems rock solid to me.Click image for larger version
wraunch is offline
