Minimalist Approach to Screen Wall - Page 14 - AVS | Home Theater Discussions And Reviews
 18Likes
post #391 of 419 Old 07-21-2014, 02:06 PM
ADDUpstate's Avatar
Originally Posted by wraunch View Post
I just finished my 1x4" goalpost screen wall. I made "legs" for the back of it so I wouldn't have to screw through the carpet. Seems rock solid to me.Attachment 172338
I will interested in seeing how this comes together. You have a lot of interesting elements to build around. Soffit/Crown and doorway on the other side. How will you address the doorway?
ADDUpstate is offline
post #392 of 419 Old 07-22-2014, 11:52 AM
wraunch's Avatar
Quoted: 78 Post(s)
Liked: 32
I will have a black panel on the side of the left upright. That will box in the screen wall. The door there won't be an issue once it goes up as I might just paint it the room wall color to help it disappear when the lights go down.
wraunch is offline
post #393 of 419 Old 07-23-2014, 01:37 PM
sillywilly's Avatar
When framing up the front wall (not the screen wall) I should decouple it from the joists, correct?
However, when doing the screen wall, if I am doing channel+clips+DW+GG+DW on the ceiling, I would assume that I don't need to further decouple the false screen wall with clips, correct?
My Home Theater and Game Room Build -- IN PROGRESS
THE SPUD CELLAR
sillywilly is offline
post #394 of 419 Old 07-23-2014, 02:56 PM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
correct as long as you just connect the top to the decoupled ceiling.
BIGmouthinDC is online now
post #395 of 419 Old 07-23-2014, 03:31 PM
sillywilly's Avatar
Thanks BIG!
THE SPUD CELLAR
post #396 of 419 Old 07-28-2014, 08:18 AM
wraunch's Avatar
Quoted: 78 Post(s)
Liked: 32
BIG/et al, What do you recommend using for the black wall panels around the screen? Mine need to be AT but I want them to black it out as much as possible.
wraunch is offline
post #397 of 419 Old 07-28-2014, 09:31 AM
BllDo's Avatar
Quoted: 136 Post(s)
Liked: 109
I just used some black GOM FR701 for the side/top/bottom panels. The Rose brand speaker cloth would also work for a little less $$. I used it to cover the back wall behind my screen. It's not quite as thick, but I would say it's passable.
Is it solipsistic in here, or is it just me?
BllDo is offline
post #398 of 419 Old 07-28-2014, 10:05 AM
wraunch's Avatar
Quoted: 78 Post(s)
Liked: 32
Should I use Velvet above the screen to black out the crown then use the speaker cloth or something similar on the sides and the bottom?
wraunch is offline
post #399 of 419 Old 07-28-2014, 10:16 AM
BllDo's Avatar
Quoted: 136 Post(s)
Liked: 109
From an aesthetics point of view, I don't know that I would use different fabrics. Are you asking about the crown behind your screen or the crown above it?
If it was me, I would be looking at covering the wall behind your screen anyway with some sort of absorptive material. You could use that opportunity to mask the crown behind your screen. Alternatively, you could fill the empty area in the top panel with cardboard or foam insulation to prevent light reflecting through.
BllDo is offline
post #400 of 419 Old 07-28-2014, 11:14 AM
wraunch's Avatar
Quoted: 78 Post(s)
Liked: 32
I am mostly focused on blacking out the area immediately around the screen for now. I agree the area behind the screen needs to be darkened in areas also. Should I just wrap the crown above the screen in black velvet or speakercloth?
wraunch is offline
post #401 of 419 Old 09-11-2014, 10:57 AM
mulliganvi's Avatar
Liked: 5
Thank you for the guidance from this thread. I framed the space for my false wall. The screen is on order and I should have it this next week or so. Thank you all for your help.
mulliganvi is offline
post #402 of 419 Old 09-13-2014, 05:16 PM
mulliganvi's Avatar
Liked: 5
post #403 of 419 Old 11-04-2014, 03:24 PM
ChldsPlay's Avatar
Quoted: 106 Post(s)
And if the ceiling is not decoupled, attach the top with RSIC-04 clips?
The Hodor Theater - In Progress
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT
Surround/Back Speakers - Klipsch Pro Cinema KPT-8000M
Subwoofers - Dual Passive JTR Captivator Pros
Receiver - Onkyo TX-SR608
ChldsPlay is online now
post #404 of 419 Old 11-04-2014, 04:02 PM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
I'm not convinced that degree of isolation is really necessary,
post #405 of 419 Old 11-05-2014, 12:41 PM
ChldsPlay's Avatar
Quoted: 106 Post(s)
So, in your opinion, if complete sound isolation wasn't done on the ceiling walls, there's still no need to decouple the screen wall from the ceiling?
post #406 of 419 Old 11-05-2014, 04:55 PM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
post #407 of 419 Old 01-02-2015, 08:44 AM
blipszyc's Avatar
Quoted: 87 Post(s)
Liked: 43
I'm finally at the screen wall phase and have tried 3 of the big box stores looking for 5/4 FJP. All I can find is the 1x stuff. Any reason not to use that? Screen size is 126" diag. 16x9 from Seymour. Not sure of the weight, but hoping the 1x material will suffice.
Also, approximately how far from the top of the screen frame is the mounting bracket? Trying to figure out exactly where to mount the cross member.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #408 of 419 Old 01-02-2015, 08:54 AM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
On Falcon screens I plan the top of the clip will be 1/4 inch below the top of the screen frame. Most other brands are about the same.
post #409 of 419 Old 01-02-2015, 09:09 AM
blipszyc's Avatar
Quoted: 87 Post(s)
Liked: 43
Thanks. Is the 1x material OK to use?
blipszyc is offline
post #410 of 419 Old 01-02-2015, 09:29 AM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
I haven't tried using 3/4 inch thick material. I can see it working but I would use one or two mid span supports for the cross piece of the goal post to be sure it doesn't sag.
post #411 of 419 Old 01-02-2015, 09:47 PM
dabsabre's Avatar
Quoted: 12 Post(s)
I'm dealing with a sloped/vaulted ceiling at the front wall and was thinking of squaring it off with a soffit equal to the depth of the false wall.. the ceiling slope goes about 32" into the room but I've only got about 20" for the depth of the false wall so I was going to run a 2x4 the length of the room along the slope at 20" from the wall and screw into the ceiling joists and then rip the uprights at the ceiling angle and screw into the mounted 2x4 on the ceiling slope.. then attach a 1x4 to the face of the uprights at the height of the top of the screen and use that as the top anchor for the goal post to avoid any sagging.. I'll try to come up with some crude drawings to better convey things but that does make sense?
dabsabre is offline
post #412 of 419 Old 01-03-2015, 04:33 AM - Thread Starter
Quoted: 708 Post(s)
Liked: 793
Sounds like it should work, need to see the sketch
post #413 of 419 Old Yesterday, 09:54 AM
Diesel 48's Avatar
Quoted: 52 Post(s)
How is everyone getting the two up rights tight to the floor and ceiling? Do they need to be pounded into place? Cutting them and .125 short? Just thought you would run into the same issue if the columns were not cut short. I could only find 1x4 fjp at my local stores as well. I will plan putting 2 supports on the main horizontal hanger.
Diesel 48 is online now
post #414 of 419 Old Yesterday, 10:27 AM
24Changer's Avatar
Quoted: 61 Post(s)
Liked: 70
I set my uprights on a top & bottom plate and screwed that the floor/ceiling. You can somewhat see it in the picture. The uprights were cut to fit and tapped into place with little effort.
Creekside Stone Cinema
24Changer is offline
post #415 of 419 Old Today, 04:12 AM
MysticalJet's Avatar
Sounds like it will work. I was also dealing with a sloped ceiling. You can see how I dealt with it in my theater build thread starting here.
MysticalJet is online now
post #416 of 419 Old Today, 07:22 AM
Diesel 48's Avatar
Quoted: 52 Post(s)
My HD does not have the 5/4 material. I am installing a 12' wide screen. I used 1x4 FJP for the struts but am looking for a wood type to use for the horizontal bar. The FJP was only available in 8' lengths. I could splice the pieces of trim together but it would be a lot easier to get a 12' board and cut a few inches off. Any suggestions? Headed to HD this afternoon to see what I can find. If they have MDF trim in 12' lengths that could potentially work.
post #417 of 419 Old Today, 10:15 AM
Diesel 48's Avatar
Quoted: 52 Post(s)
Bought some 1x4x12 primed MDF. Should work out great.
post #418 of 419 Old Today, 11:16 AM
AVS Club Gold
LeBon's Avatar
Quoted: 60 Post(s)
Liked: 40
I would worry about a 12-foot span of 4" MDF!
LeBon is online now
post #419 of 419 Old Today, 11:25 AM
Diesel 48's Avatar
Quoted: 52 Post(s)
I plan on adding 2 supports to the horizontal to avoid sagging.
