Minimalist Approach to Screen Wall - Page 15 - AVS | Home Theater Discussions And Reviews
 22Likes
post #421 of 429 Old 02-01-2015, 11:09 PM
DrBabs's Avatar
Quoted: 37 Post(s)
I would try securing the screen wall to the stage with more screws, 20+. If it is tight it can't rattle. If that doesn't work take it apart and insert some rubber (Carpet pad or hardwood underlay) I would also set the subs on sand filled stands and decouple from the screen wall frame.
You could try just buying a package of the plastic composite shims and forcing underneath the bottom plate.
If the stage itself is rattling you definitely need to decouple the subs from the stage, back to the sand idea
Big, how do you suggest that I decouple the stage from the framed screen-wall , if the screen wall sits on top of the stage? would i attach the screen wall horizontally to the sides and the ceiling and just suspend the wall/ goal posts?
DrBabs is offline
post #422 of 429 Old 02-02-2015, 06:51 AM - Thread Starter
Quoted: 970 Post(s)
Liked: 943
IMHO decoupling A goal post minimalist design screen frame from the stage or ceiling overhead is at best an academic exercise with no audible result.
I build my uprights a little less than the area height, you could leave a gap and insert a rubber pad if you wanted on the top and bottom, then drill holes in the top and bottom attachment blocks bigger than the screw diameter and when you screw it don't over tighten. Then the frame is actually just floating on rubber. The screws would just keep it in position and from tipping over.
DrBabs likes this.
post #423 of 429 Old 03-27-2015, 09:24 AM
Brian Fineberg's Avatar
Quoted: 1352 Post(s)
Liked: 1293
quick question...
If i am building this..the top of the goal pasts will go into blocks attached to ceiling..how should I secure the bottom of the posts if Im going onto concrete? I want the wall to sturdy yet removable if needed
thanks in advace
Panasonic 65VT30 | Panasonic AE8000 HD PJ | Denon x4100 ATMOS 5.2.4| Emotiva XPR-5 | PSA MT110 x 3 FL/C/FR | PSA MT110sur surrounds | DUAL PSA XS30 | OPPO 103 | minidsp
the SadieMax HT build thread - my first build
Brian Fineberg is online now
post #424 of 429 Old 03-27-2015, 09:39 AM
genofive0's Avatar
Quoted: 29 Post(s)
Originally Posted by Brian Fineberg View Post
quick question...
thanks in advace
If I had to build on concrete I would drill a hole and use a concrete anchor
Like this and still use a rubber pad underneath, Then again I would hate drilling into my slab :/ almost makes more sense to build up the floor
genofive0 is offline
post #425 of 429 Old 03-27-2015, 09:52 AM
Liked: 1293
yeah not doing that! haha
maybe I will put it on plywood "feet" to give it more stability
post #426 of 429 Old 03-27-2015, 10:13 AM
blipszyc's Avatar
Quoted: 100 Post(s)
Liked: 48
quick question...
thanks in advace
If you use just enough pad underneath the posts, the friction alone should hold them in place with screws into the ceiling for extra security. Then you only need to remove the top screws to remove them, if needed.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #427 of 429 Old 03-27-2015, 10:21 AM
Liked: 1293
cool.. should I drill holes before screwing into the FJP ?
post #428 of 429 Old 03-27-2015, 10:41 AM
blipszyc's Avatar
Quoted: 100 Post(s)
Liked: 48
I always drill first to prevent splitting.
blipszyc is offline
post #429 of 429 Old 03-27-2015, 12:56 PM
genofive0's Avatar
Quoted: 29 Post(s)
Agree 100% drill first. I just finished mine a few hours ago. I counter sunk and also used titebond glue
