Minimalist Approach to Screen Wall - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 112Likes
post #451 of 531 Old 06-25-2016, 08:00 AM - Thread Starter
Quoted: 3726 Post(s)
Liked: 3154
Originally Posted by Patriot666 View Post
Where can I buy the mounting brackets or 'zbar'. Is it better to use z or j style brackets? A link would be great, I'm having trouble finding it.
Both Home Depot and Lowes have a few different sizes, You can buy a long one and cut it. They are on Amazon too.
http://www.homedepot.com/p/OOK-Hangm...5312/202341625
https://www.amazon.com/gp/product/B0...pf_rd_i=511352
post #452 of 531 Old 06-25-2016, 08:33 AM
Patriot666's Avatar
Quoted: 127 Post(s)
Liked: 81
Thanks again! So if you buy the french cleat one on amazon you only use the one side of it correct? You don't attach other side to the screen do you?
Patriot666 is offline
post #453 of 531 Old 06-25-2016, 08:49 AM - Thread Starter
Liked: 3154
most screens come with cleats, correct you only need one side with most extruded screen frames
Patriot666 likes this.
post #454 of 531 Old 07-04-2016, 09:54 AM
caseyparsons's Avatar
Quoted: 41 Post(s)
This looks incredible! My dream, wish I could afford it!
dRwOOD73 likes this.
n00b
Theater Under Construction
Childhood Home Theater Build
caseyparsons is offline
post #455 of 531 Old 07-28-2016, 11:04 AM
Patriot666's Avatar
Quoted: 127 Post(s)
Liked: 81
Update, I did swap out the blocking
Hey Big do you use screws in the crossbeam and block to secure it in place? Or does the crossbeam just rest on the block?
post #456 of 531 Old 07-28-2016, 12:32 PM - Thread Starter
Liked: 3154
it is screwed as well, the blocking pretty much holds it in place while I do the screwing and later just makes it even more secure.
post #457 of 531 Old 07-28-2016, 12:34 PM - Thread Starter
Liked: 3154
I assume you saw the picture with the speakers raised on stands and the 8 subwoofers.
post #458 of 531 Old 07-28-2016, 01:18 PM
Quoted: 41 Post(s)
Uhh no. I'm listening...
n00b
post #459 of 531 Old 07-28-2016, 07:03 PM - Thread Starter
Liked: 3154
this picture should only be viewed if you are wearing a bib to protect your shirt from the drool, then consider that there are 8 matching subs along the back wall and you get the idea.
post #460 of 531 Old 07-28-2016, 11:05 PM
jjackkrash's Avatar
Quoted: 952 Post(s)
Liked: 821
JBL 4722n LCR and Captivator S2s?
Rock & Roll
jjackkrash is offline
post #461 of 531 Old 07-29-2016, 04:05 AM
VicTorious1's Avatar
Quoted: 501 Post(s)
Liked: 519
@BIGmouthinDC - I didn't have a bib on, and I was not ready for that pic. Wow! One quick question, what's the benefit of having a stage? Purely aesthetics?
VicTorious1 is offline
post #462 of 531 Old 07-29-2016, 05:16 AM - Thread Starter
Liked: 3154
In this case purely aesthetics, but we did make it a bass absorber and it helps elevate the speakers to the correct height, the project has a thread, the White Oaks theater. The subs are DIY by the homeowner
White Oaks Cinema House and Theater Build
4AlexF, dRwOOD73 and Movie78 like this.
post #463 of 531 Old 07-29-2016, 06:56 AM
Patriot666's Avatar
Quoted: 127 Post(s)
Liked: 81
When I looked into the flame, this is what I saw.
akoutin likes this.
post #464 of 531 Old 07-29-2016, 07:20 AM
Quoted: 41 Post(s)
n00b
post #465 of 531 Old 07-29-2016, 08:32 AM
Quoted: 501 Post(s)
Liked: 519
Sixteen 18" subs? I am putting two 18" subs and two SVS 12s into my HT. I feel woefully inadequate. Maybe I need to add a few more 18" subs. Hmmm...
post #466 of 531 Old 08-02-2016, 09:47 AM
Patriot666's Avatar
Quoted: 127 Post(s)
Liked: 81
One more question for you Jeff. With these Z bar hangers do you use both pieces in the pack? The one piece has the channel in it for the little level, can you use both pieces?
post #467 of 531 Old 08-02-2016, 09:56 AM
thrillcat's Avatar
Quoted: 202 Post(s)
Liked: 252
There are two pieces, one attaches to the screen frame, the other attaches to the wall. Level the one on the wall.
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #468 of 531 Old 08-02-2016, 10:36 AM
Patriot666's Avatar
Quoted: 127 Post(s)
Liked: 81
Assuming I won't need to attach one to the screen frame as it will be aluminum, I'm wondering if both pieces can be used on the screen wall side, or if only one of the pieces in the kit will work. Does the center channel for the level get in the way? These are the two pieces I'm talking about:
post #469 of 531 Old 08-02-2016, 11:18 AM - Thread Starter
Liked: 3154
you'll have to check with your screen frame to make sure that channel doesn't get in the way.
post #470 of 531 Old 08-12-2016, 09:39 AM
Quoted: 12 Post(s)
Has anyone successfully built a minimalist screen wall without a stage or floor to attach the posts to? I do not have a stage and only carpet over concrete for a floor. My wall is not that big, 12' wide 7.5' high, I was thinking of just letting the posts rest on the carpet or perhaps use speaker spikes on the bottom to keep the posts off of the carpet and in place. i don't have small children that would be running into the wall.
Newt1822 is offline
post #471 of 531 Old 08-12-2016, 09:43 AM - Thread Starter
Liked: 3154
There isn't any reason your plan shouldn't work.
post #472 of 531 Old 08-12-2016, 08:00 PM
kmhvball's Avatar
Quoted: 531 Post(s)
Liked: 297
My posts aren't attached at the base, but I think I ran a few screws into the drywall at top. They are a tight fit, so, I think I compressed the carpet/ pad down a little to get it vertical.
kmhvball is offline
post #473 of 531 Old 08-20-2016, 02:50 AM
Quoted: 501 Post(s)
Liked: 519
@BIGmouthinDC - I was initially planning on building a baffle wall and a minimalist goal post (like your design) in front of the baffle wall. However, considering that my speaker designer suggested having my speakers as close to the screen as possible, do you think it would work to combine the baffle wall and the false wall?
I'm planning on doing a sketch, but essentially, instead of the two support posts, I'd have 6 floor to ceiling posts with my LCR speakers in between each pair of posts. I'd still do the cross post (with Z hangers to hang the screen and with mid supports). I'd then attach acoustic treatment panels for the baffle wall similar to how you attached the frames with GOM fabric. However, I'd wrap the acoustic treatment panels in the black GOM fabric.
post #474 of 531 Old 08-20-2016, 08:09 AM - Thread Starter
Liked: 3154
baffle walls should be sturdy rigid structures, the front face should be solid with multiple damped layer construction, the front surface of the baffle should have at least one inch of a material like Linacoustic. You can add furring on the front surface to hold the screen z clips and fabric panels as necessary. Forget about trying to mimic the minimalist goal post and just build a sturdy baffle wall.
one reference: http://www.acousticfrontiers.com/201...ers-demo-room/
post #475 of 531 Old 08-20-2016, 01:11 PM
Quoted: 501 Post(s)
Liked: 519
Thanks, Big. I was planning on doing a proper baffle wall, just without drywall being used on the baffle wall. The area behind the baffle wall would be drywalled of course. Perhaps my question should've been "Can I just affix the screen with Z hangers to the baffle wall?"
Alternatively, I picked up 5/4" primed pine. It's not finger joint pine, but it's straight (at least now). I found 1" (really 3/4") finger joint poplar which I plan to use as the cross post. Looks like I may just do a minimalist screen wall in front of the baffle wall. Poplar should be stronger than pine (but slightly pricier).
post #476 of 531 Old 08-20-2016, 01:22 PM - Thread Starter
Liked: 3154
A baffle wall without the baffle (drywall) is just a speaker stand. Now I understand your vision. Yes, you can attach the screen and fabric panels to your speaker stands
post #477 of 531 Old 08-20-2016, 02:04 PM
Quoted: 501 Post(s)
Liked: 519
Hmm... I thought drywall want necessary. I was planning on using MDF as the baffle. I guess I can switch it to drywall if needed. The speakers would back up to the double firecode drywall that has GG between. If I switch the baffle to drywall, should the entire speaker except the front/baffle be surrounded by drywall?
post #478 of 531 Old 08-20-2016, 02:22 PM - Thread Starter
Liked: 3154
drywall = MDF from a baffle wall perspective. proceed. it sounded like you weren't using anything.
post #479 of 531 Old 08-24-2016, 12:07 PM
sigma722's Avatar
Quoted: 437 Post(s)
Liked: 237
To have a false screen wall, minimal or not, it's pretty much a requirement to have 1 layer of osb if you are using rsic + hat channel, correct?
sigma722 is offline
post #480 of 531 Old 08-24-2016, 12:55 PM - Thread Starter
Liked: 3154
Incorrect, why? I don't have OSB on my ceiling.
