Minimalist Approach to Screen Wall - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 100Likes
post #511 of 519 Unread 02-15-2017, 01:16 PM
Gouie's Avatar
Quoted: 177 Post(s)
Liked: 57
I have pictures of fitting the panels around the screen sharing the same supports as the screen. I'm out of the country back in my office Monday.
See post 485
On vacation but still "working". I'm on the beach as we speak but can't shake thinking about the finer details of the build. Thanks Big.
Gouie is online now
post #512 of 519 Unread 02-15-2017, 01:18 PM
Gouie's Avatar
Quoted: 177 Post(s)
Liked: 57
Final product - I'm really happy with how it all turned out!
Nice looking wall, thanks for the reference.
PTAaron likes this.
Gouie is online now
post #513 of 519 Unread 02-15-2017, 01:21 PM
Gouie's Avatar
Quoted: 177 Post(s)
Liked: 57
See post 485
So does the screen mount in front of or behind the framing shown in post 485? Is that the White Oaks build?
Gouie is online now
post #514 of 519 Unread 02-15-2017, 06:01 PM - Thread Starter
Quoted: 3361 Post(s)
Liked: 2837
The screen mounts on the front surface of the wall frame with z clips on the top edge. Yes that is white oak which was an extreme variation of the minimal screen wall concept.
post #515 of 519 Unread 02-16-2017, 05:26 AM
Liked: 9
Big, you mentioned you use linacoustic on the front wall. Others have used Owens Corning 703/Roxul Comfortboard or Roxul Safe 'n Sound.
Why do you prefer linacoustic? Do you know how that would compare with the OC703?
If anyone else used a different solution, please let me know.
Spawnstar78 is offline
post #516 of 519 Unread 02-16-2017, 05:58 AM
69glamboy's Avatar
Quoted: 182 Post(s)
Liked: 65
You may want to review the acoustic treatment thread at the top of the forum to see the flavor of the month for screen walls. It used to be two layers of linacoustic with a layer of poly in between. Things have changed a bit. For myself, I will be using Roxul S&S in between my front studs, then a layer of linacoustic in front. Then I will be layering a wall of speaker cloth in front of that to stop any fibers from floating around. But again, check the acoustic thread unless one of the heavy hitters answers next and fast tracks you some more info.
69glamboy is offline
post #517 of 519 Unread 02-26-2017, 07:54 AM
gogunbaba's Avatar
Liked: 67
Here is my conribution. I used 1" (actually 3/4") FJ pine board. I glued and screwed them together. The middlempiece on the top is 107" wide. It feels really really solid when Itry to shake it or pull down. I am not using any support, we will see if it will sag over time.
Patriot666 likes this.
gogunbaba is online now
post #518 of 519 Unread Today, 07:19 PM
scotty3x3's Avatar
Quoted: 24 Post(s)
See post 485
I'm having trouble envisioning this myself. I understand the goalposts are screwed into the ceiling and floor for support with the cross member between and supported with a center brace screwed into the ceiling. I understand the screen rests on the goalposts about half way. But is there more "framing" on the sides that are screwed into the goal posts and the side walls and then the panels tensioned on top? After looking at post 485, I think I'm more confused. I thought the panels were tensioned into place pressing up against each other, not attached to more framing behind?
I really love the clean minimalistic look this provides, I'm just not sure I have the know how to do it. lol
scotty3x3 is online now
post #519 of 519 Unread Today, 08:49 PM - Thread Starter
Liked: 2837
you've got the goal posts and then I run a 2x2 on the side walls. That is usually enough to hold everything in place unless you have a really wide screen then some mid span supports of the panels above and below the screen might be required.
