Minimalist Approach to Screen Wall - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 121Likes
post #541 of 546 Old 10-04-2017, 05:36 AM - Thread Starter
Quoted: 3898 Post(s)
Liked: 3333
I routinely hang soffits off of decoupled drywall ceilings, Not a problem. A screen wall would be easy. Nearly all of the screen walls I've built have been below decoupled ceilings. What do you see as the issue?
Mr. Sir likes this.
post #542 of 546 Old 10-04-2017, 05:43 AM
trpltongue's Avatar
Quoted: 39 Post(s)
I was just concerned about wedging a wall between the floor and decoupled ceiling might compress the RISC clips and no longer decouple the ceiling?
I guess this is where the comment "measure twice, cut once" comes into play
trpltongue is offline
post #543 of 546 Old 10-04-2017, 06:51 AM
iconrl's Avatar
Quoted: 92 Post(s)
Liked: 67
I don't think I ever stopped in here to say "Thanks!" to @BIGmouthinDC for the screenwall idea. Worked like a champ when I built mine about a year ago.
BIGmouthinDC likes this.
Optoma HD37 on 138" DIY AT Screen
Infinity Beta 40s, Infinity Beta C250, Atlantic Technologies 224 SR
BIC H100 (DIY in the works)
Old Pioneer VSX-521
iconrl is online now
post #544 of 546 Old 10-04-2017, 07:01 AM
Ladeback's Avatar
Quoted: 557 Post(s)
Liked: 182
Send a message via MSN to Ladeback
You shouldn't need it super tight like you would want in a support wall. If it is a little lose you could use some shims, that way you won't be pushing on the DD and channel, but I would think it would take a lot to compress them. If you have to beat the wall into place, it it to tight for false wall in my opinion.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
http://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
post #545 of 546 Old 10-04-2017, 09:12 AM - Thread Starter
Liked: 3333
you could put a thick rubber pad under the base and between the top and the ceiling if you want to do everything you can to keep everything decoupled. Another option would be rubber on the bottom, and secure the top with an appropriate RSIC clip. IMHO this is an over the top strategy. But this forum is full of over the toppers. I'm usually standing below cheering them on.
UK Dreamer likes this.
post #546 of 546 Old 10-10-2017, 11:23 AM
Gouie's Avatar
Quoted: 225 Post(s)
Liked: 90
I really like Big's approach to the modified minimized approach used in the White Oaks build. No goal posts, just upper and lower brackets. This would eliminate your concern.
Gouie is online now
