Just to show my theater (big pictures) - AVS Forum | Home Theater Discussions And Reviews
Old 04-24-2007, 03:21 AM - Thread Starter
reaven's Avatar
this is my theater finished build June ..
looking forward for a name to the theater too !! thanks
dvd rack at first
dvd rack few days later
** posters already hang
old Win. XP MCE
old Win. Vista MCE
new Vista Media Center DVD library
new 4-30-2009
XBMC Media Center (Aeon)
My Setup
B&W 603 S3 series x4
subwoofer Velodyne 1210
B&W center channel (coming soon)
Sanyo Z3
100" fixed screen (home made)
Xbox 360 with HD-DVD player
Wii
PlayStation 3
HTPC (need upgrade to get rid of the PS3 )
DishNetwork
CableTV
Sony Receiver (waiting for new receivers with hd sound, Yamaha 3800 or 1800 coming soon )
Pronto 3500 (tired of, will change for another remote more Ergonomic and maybe simpler)
Lutron spacer with IR
battery backup
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
B&W 602 S3 (Rears) *soon to be Niles CM7FX in-ceiling
B&W LCR60 S3 (Center)
Velodyne 12" (Sub)
Samsung Bluray C5500
Mac Mini (XBMC)
XBOX 360 | Wii
Logitech Harmony One | Logitech DiNovo Mini
reaven is offline
Old 04-24-2007, 04:07 AM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 68
for whatever reason, I love this. Are those leather covered walls or just dark paint/stain?? have anymore pictures??
aaronlinkous is offline
Old 04-24-2007, 07:55 AM
Tom Kay's Avatar
Quoted: 12 Post(s)
Yeah, I agree. There's something seriously good about this little space. Looks comfy, complete and perfect for movies with a few friends.
The walls certainly look different with the lights on or off. They look tan coloured with light.
Well done !
Tom.
There's a proper time and place for spontaneity, dammit!
Tom Kay is offline
Old 04-24-2007, 09:20 AM
patrickjherbert's Avatar
What are you using for your jukebox software?
patrickjherbert is offline
Old 04-24-2007, 12:36 PM
Jesse S's Avatar
Looks nice. I don't see a subwoofer...
Jesse S is offline
Old 04-24-2007, 12:41 PM
dachavez's Avatar
Amazing work in such a small space. Very nice job!
Looks like Windows Media Center 2005.
dachavez is offline
Old 04-24-2007, 02:08 PM
hitchfan's Avatar
Quoted: 80 Post(s)
Liked: 77
Looks great to me. A name? How about "Orange-You-Here-For Home Theater"?
Have you ever wished your front side speakers were 5 inches shorter or that you could mount your screen 5 inches higher?
I think small, cozy, well dressed spaces like this create a very special world for movie watching.
hitchfan is offline
Old 04-24-2007, 02:50 PM - Thread Starter
reaven's Avatar
-I use media center 2005
-walls are just paint with matte paint
- the subwoofer is behind the couch in the corner (forget to write it in the setup its a velodyne 12")
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 02:53 PM - Thread Starter
reaven's Avatar
thanks for all your comments still need a good name and any suggestion is welcome ..
have a tons of pictures , what you want to see ??
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 02:59 PM - Thread Starter
reaven's Avatar
the walls are concrete the roof is the same color as the walls
-the effect is exactly what i was looking for with lights on 100% looks very bright the pictures looks orange its because of the camera filter , and with lights off you can see anything completly dark no bounce light at all.
- the screen its a MDF panel paint with Behr silverscreen paint, get the advice from the forums
by the way this is an apartment .
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 03:54 PM
BishopLord's Avatar
Your set up looks great. I want to turn my master bedroom into my home theater - it's about the same size as your theater room, maybe a little bigger. Anyhow, please excuse my ignorance as I'm new to the board, but what type of projector are you using?
BishopLord is offline
Old 04-24-2007, 04:01 PM - Thread Starter
reaven's Avatar
first post
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 04:07 PM - Thread Starter
reaven's Avatar
Sanyo Z3 lcd 720p
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 04:14 PM
NeoOiler's Avatar
Hi Reaven your room looks awesome. Very similar to mine actually. Did you add any extra ventilation for your projector?? I am building that part of my room right now.
And I think after looking at yours I may need to put some little soffet lights in..it looks awesome on yours.
Ryan
IM FINALLY FINISHED...(WELL ALMOST)
THE PITT CONSTRUCTION THREAD
NeoOiler is offline
Old 04-24-2007, 04:49 PM - Thread Starter
reaven's Avatar
Ryan
am using 2 computer like fans 60mm fans, for my projector model 1 fan in the back for intake and one on the side for exhaust . i was going to built a thermostat sensor but drop the idea when found hard time looking for the components. my fans are running 24/7. almost a year in june without problems.
it runs so cool that when turn it off the internal fans keep running like few seconds only..
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 05:05 PM - Thread Starter
reaven's Avatar
hey NeoOiler what you use to make your design drawing , sketch it ?? i use visio but i like the perspective look what you use ?
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-24-2007, 08:38 PM
NeoOiler's Avatar
I used Sketchup for the first few, then Autocad for the rest. I do autocad as a profession so I am more comfortable with it.
Ryan
NeoOiler is offline
Old 04-25-2007, 03:19 PM - Thread Starter
reaven's Avatar
i was thinking about raised my rears speakers over the couch back and a little further from it??
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-25-2007, 04:18 PM
McCall's Avatar
yes you want those rear speakers higher.
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
Old 04-25-2007, 07:22 PM
NeoOiler's Avatar
For your opening in the soffet, did you just use drywall for the bottom or plywood??
Ryan
NeoOiler is offline
Old 04-25-2007, 08:17 PM - Thread Starter
reaven's Avatar
Ryan
drywall !
i know but what can I do make a complete raiser or just two boxes for the speakers ?
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 04-26-2007, 08:23 AM
Randito3's Avatar
Great job on the room, I know pictures sometimes come out darker than seeing it in real life but It seems to have a great atmosphere. Two thumbs up.
Randito3 is offline
Old 04-26-2007, 02:37 PM
Avatar8481's Avatar
very cool, I hope to achieve a similiar effect in my small space (smaller screen for one) but great space and I love the colors.
Avatar8481 is offline
Old 05-08-2007, 12:50 PM - Thread Starter
reaven's Avatar
whats a good way to rise the rear speaker ??
need options, make a wood box individually or a big raiser in the back of the couch ?
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 05-09-2007, 12:42 AM
Quoted: 55 Post(s)
Liked: 68
just boxes i would think... if you build a riser for the couch, then your speakers are still the same level as they were before (relatively)
Old 05-09-2007, 03:14 AM - Thread Starter
reaven's Avatar
the problem i was thinking is that the floor already have a rug if i build a simple wood box i dont think it will sit flat on the floor dont know if you know what i mean , i have to in someway make the box to have some weight beside the speaker because if not the speaker will fall from the box.
i hate sand its a mess so fill the box with sand is not an option.
so......?
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 05-09-2007, 05:40 AM
cnickersonjr's Avatar
Location: Missouri City, Texas (Next door to SUGARLAND)
Nice setup reaven!
cnickersonjr is offline
Old 05-09-2007, 11:29 AM - Thread Starter
reaven's Avatar
Originally Posted by cnickersonjr View Post
Nice setup reaven!
Thanks man !!
SHARP LED 70"
Yamaha RX-A2000
B&W 603 S3 (Fronts)
Velodyne 12" (Sub)
Mac Mini (XBMC)
XBOX 360 | Wii
reaven is offline
Old 05-09-2007, 01:30 PM
griff32's Avatar
so......?
Screw the box to the wall. shouldn't take many to keep it rigid enough to keep it from falling.
griff32 is offline
Old 05-09-2007, 08:09 PM
ksil's Avatar
Looks great!
ksil is offline
