HVAC - # of Returns for 24x13'8 room - Page 2 - AVS Forum
post #31 of 42 Old 05-30-2007, 04:39 AM
hevac's Avatar
Sorry I left out cause it is heavier & cause it is lighter. I did not think I had to be that clear and assumed people here had common sense. Hot air rises & cold air drops I thoght would be enough.
hevac is offline
post #32 of 42 Old 05-30-2007, 06:04 AM
AVS Club Gold
Flip_5's Avatar
Originally Posted by Dennis Erskine View Post
As it rises, the temperature drops and at the point where the temperature and dew point are the same, the cloud (visible moisture) forms. As the air cools (when it rises), and moisture droplets become larger, they fall. We call it rain (and we need more of it).
So you're saying we want it to rain in our Home Theater?
j/k
Flip
Flip_5 is offline
post #33 of 42 Old 05-30-2007, 10:59 AM
AVS Club Gold
Dennis Erskine's Avatar
Liked: 43
...absolutely. All you need are 40,000 foot ceilings.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
www.CinemaForte.net
Dennis Erskine is offline
post #34 of 42 Old 06-12-2012, 06:24 AM
j baldwin's Avatar
Thanks for discussion as my HT is gutted and in process of moving air from attic to basement and probably doing seperate trunk for upstair and seperate trunk and zone for basement so i can make my HT air"perfect" by having hvac guys follow ur best practices if i can figure out is is most right.....LOL
http://www.avsforum.com/t/1415166/bluff-rock-cinema-buildnow-under-way#post_22181478 Bluff Rock Cinema build and whole basement renow for fun and games
From moldy/musty mess to magnificent wonder(i hope)
j baldwin is offline
post #35 of 42 Old 06-12-2012, 10:42 AM
blipszyc's Avatar
Liked: 32
So I getting ready to finalize quotes and plans for HVAC and here's what I think I took away from this thread.
My room is 13x23, with the PJ mounted about 16-18 feet back.
1. Keep CFM <150 at the supply side (so far quotes are for 2 6" flexduct supplies, I'm told these are 100 CFM each.)
2. Supplies in the front, but away from screen - up high (Where should these be room wise? In the soffits up front, one on each side? Can they be behind the false wall?)
3. Returns in the rear - up high and oversized (so far the quotes are spec'ing 1 single 8" or 10" duct)
4. Minimize duct entrance into sealed room - use soffits for maneuvering.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #36 of 42 Old 06-12-2012, 12:06 PM
AVS Club Gold
LeBon's Avatar
Liked: 25
I think the critical HVAC number for acoustic purposes is to limit the velocity of the air flow to <250 ft/min. The volume (CFM) should be sized to provide the required number of air changes per hour (probably about 6).
Might be better off to specify the temp range and noise level (for example, NC 21) than to try to design the HVAC system and spec that.
LeBon is online now
post #37 of 42 Old 06-12-2012, 12:23 PM
235
235's Avatar
I have a similar sized room. I plan on having 2 supplies venting from side soffits next to the screen - avoid putting them in front of screen. Add some 90 degree bends behind some mass (soffits) for better low-frequency sound isolation. Don't put supplies behind false wall, others have had problems with proper air movement with this approach. You can optimize returns by having two of them, one high and the other low. This allows you to choose which one should be open depending on the heating/cooling needs of the room. You might also want to consider a variable speed inline return duct fan to give you some insurance against having insufficient air flow. Here's a sketchup of my current plan: http://www.avsforum.com/t/1383183/235-build/60_60#post_21950547
235 is offline
post #38 of 42 Old 06-12-2012, 12:33 PM
NicksHitachi's Avatar
Quoted: 24 Post(s)
Liked: 90
I would suggest at least 4 8" Supplies and one return at least 12x18....  More is usually quieter also.
My room 14x24.
One 12x18 return
Two 8" flex duct supplies
All Equipment and projector in room and its HOT.  I need more supply. :(
Don't waste time reading signatures.....
NicksHitachi is offline
post #39 of 42 Old 06-12-2012, 03:51 PM
Mr.Tim's Avatar
Liked: 47
HVAC is science and math just like acoustics.
Lots of suggestions, but no real details on the room. Does it face south with 100 sq.ft. of glass? Is it in the basement, second floor? Are you seating 3 or 13?
Just like acoustics, you can take a best guess based on what has worked for others. Honestly, a lot of what I have seen done works, but at what expense. Slot diffusers are expensive, so did you actually need 8 feet? Do you need 2-slot or 4-slot diffusers?
Oversizing the diffuser reduces throw and can decrease efficiency. It's like washing your car with no nozzle on the hose. The whole car gets wet. Eventually. Best to have the proper size meeting the NC and velocity without making it larger than need be.
Did you really need to run a 10" duct that was difficult and time consuming, or would a 8" have done the job?
Figuring out the cooling load for a single room with only the projector should be a piece of cake (I suspect at least one person posting in this thread can do it for you). Are you doing all the work yourself, or are you going to spec it for a HVAC contractor? [rhetorical question] If you are involving a contractor I would make him figure out the load. Once you have that you can come here and get some great advice on sizing.
But everything depends on what the heat gain is... IIRC you can figure about 1000 btu for the projector and 350 btu per person. Then you need to figure the heat gain for the room based on where it is. Once you have total btu you can determine required cfm and progress to duct size and diffuser size. Two 6" flex ducts? Maybe, but that's pushing the limit for 100CFM, especially in a theater. That's if you need 100CFM and if the length of the run is acceptable. I don't think you'll get 100 CFM through 100 feet of 6" flex.
As for returns (sorry, was your OP and neglected to answer it), I never heard of an issue oversizing it as long as you have a damper to balance it. The return register really can't be too big, AFAIK, other than expense and the size of the hole you're punching through your aquarium.
Not a HVAC professional.. but seen my share.
Tim
Mr.Tim is offline
post #40 of 42 Old 06-13-2012, 06:12 PM
Elill's Avatar
Interesting thread, in summary (have I got this right?)
Supplies – larger the better - 8” is good and two (front and high and away from screen)
Returns – at least the same size as the supplies and two (rear and high and away from seats)
Do the plenums need to be the same size as the ducting? Or larger? Say for supplies you’ve got 8” going into a box containing a 4” x 24” bar diffuser. Should the plenums be say 8” x 8” x ~24” internally (so say two layers of 18mm ply/osb with GG plus say 50mm (2 inches) of duct liner that makes it about 14” x 14” x 30” external plenum size?)
Do both returns need to feed into the HVAC unit or can you have one powered by an inline fan?
I had planned 2 x supplies, 1 return going into the unit and 1 inline fan return ducted out (with 1 powered or maybe passive fresh air supply in addition)
Also, what should be the minimum length of ductwork for isolation purposes?
Peter the Greek
Downunder Theatre MkII
Redefining snail pace construction
Elill is online now
post #41 of 42 Old 07-21-2012, 06:49 PM
cdika17's Avatar
Would love to hear some answers to these questions as well.
Chase "Fetch"
Current Theater Build
New House Build
cdika17 is offline
post #42 of 42 Old 07-22-2012, 03:24 PM
jedimastergrant's Avatar
Liked: 40
Also interested.
Is it a terrible idea to tie into the return system bc of noise concerns? Making the only quiet option a dead vent?
jedimastergrant is offline
User Tag List
