What I'd do differently next time. - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 223Likes
post #631 of 1109 Old 01-13-2011, 07:28 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 84
While not entirely discounting the whole 'make noise while the baby is young' theory entirely, I think you might be over estimating the whole whole cause & effect of that. I noticed that despite similar noise exposure in infancy, each of our kids seemed to have different noise tolerance as they grew older, and that if anything it seemed to vary according to their age more than anything - even those who woke early or easily as toddlers seemed to sleep through anything and everything as teens or young adults. Go figure.
In any case, soundproofing a HT while doing the construction at least gives you the option of containing or minimizing the noise down the road if you want to ... and my money would be on the likelihood that there will be plenty of times when you - or your wife - will want to do that. Conversely, if you don't do it now and decide later that you want it, it will cost a lot more to retrofit it.
FWIW, I read somewhere here that one of the HT gurus - perhaps it was Dennis Erskine? - listed the top reasons why people stop using their HT regularly, and one of the top 3 reasons was the lack of sound containment.
As for your other question, sound proofing/containment is NOT a substitute for acoustic treatments within a room. Two different issues.
The Un-Theater Un-Build
hanesian is offline
post #632 of 1109 Old 01-13-2011, 07:56 AM
miltimj's Avatar
If your audio components are high quality, they should be capable of producing quality sound in a smaller room as well as large. You just don't turn them up as loud.. :P
There are two ideas that are typically used for the projector mounting (other than getting it at the right height.. in your case, as high as possible, which should be about 3-4" from the ceiling). The best method is a long throw projector that goes in a room behind the theater and projects through a hole. It's quieter, easier to direct cooling to it, and keeps it out of sight and out of the way. If it must be in the room, mount it directly above a row of seating, since you'll never be standing on the seat.
Soundproofing the walls helps with the room acoustics by providing mass and minimizing possible rattling/vibration, but it's really more about isolating noise for the theater (keeping other noises out and keeping the audio from escaping). It's definitely not a substitute for good acoustic treatments. A well soundproofed drywall box is still going to sound like an echo (not anechoic ) chamber.
miltimj is offline
post #633 of 1109 Old 01-13-2011, 10:17 AM
Sideofpotatos's Avatar
Great, I really appreciate the input. I will definitely include plans for acoustic treatments and/or curtains for the budget planning.
Sideofpotatos is offline
post #634 of 1109 Old 01-14-2011, 05:21 AM
runback22's Avatar
Quoted: 18 Post(s)
Originally Posted by miltimj View Post
That reminds me. Whatever you do Sideofpotatos, make as MUCH noise as possible in their first couple months or so of life at home. You'll be glad you did. I remodeled our basement right under my daughter's room (just plywood between us) from the time she was 2 days old, and used all of the following right under her at various times prior to or during her sleeping: miter saw, framing nailer, table saw, grinder, recip saw, circular saw, framing hammer, sledge hammer, 22 caliber concrete nails, hammer drill through concrete.... I am absolutely dead serious. I had my hearing protection on, and she slept through the whole thing. She's now 26 months and has been able to sleep through anything.
Our second daughter.. not so much. Goes along with "what I would have done differently"... I was too busy taking care of the older daughter and doing some other things (not remodeling), and she's a lighter sleeper. I'm slowly ramping up the noise, though.
I have to agree as well. My daughter had to spend the first week of her life in the Newborn ICU. It was never quiet in there since all the machines the babies were hooked up to kept beeping loud constantly. Throw in workers, parents, and the phones, and you have a pretty loud room. Anyways, for the first 6 months of her life i was afraid she was partly deaf because loud noises, really loud, would not wake her up. She slept through a noisy dave and busters meal, she has slept through a movie at home with loud bangs, pretty much anything.
runback22 is offline
post #635 of 1109 Old 01-17-2011, 06:48 PM
cavedirt's Avatar
Hi to everyone, just embarked on dedicated HT in basement, working in a bar also,
enjoy your commentary and insightful replies Im just finishing up prewire, insulation,
support nailers etc. Next step is drywall, somewhat apprehensive to take this step
as thinking about all the what-ifs, why didnt-I's etc.
chat soon.
cheers
cavedirt is offline
post #636 of 1109 Old 01-17-2011, 10:56 PM
bh285's Avatar
@cavedirt, Start a build thread so we can follow and give advice. Just curious, do you work in a bar, or are you working a bar into your build... ?
bh285 is offline
post #637 of 1109 Old 01-18-2011, 03:24 PM
cavedirt's Avatar
oops......meant building a bar as well as theatre...will round up all necessary info..
thanks bh285
cavedirt is offline
post #638 of 1109 Old 01-18-2011, 07:36 PM
bh285's Avatar
Cool. I'll keep an eye open for your build thread. Lots of pictures helps!
I'm working on my build as well, but have not started a thread myself.
bh285 is offline
post #639 of 1109 Old 01-19-2011, 07:33 AM
thetootall's Avatar
This is an awesome post guys, thanks for the advice!
Ill definitely get a 2" conduit going from my main level downstairs for cabling as well as one going from the media rack to the back wall in the basement - before I close off the space with drywall! Also it looks like HDMI covers are the way to go VS plugging the cables directly into my devices.
My Blackburn 30 Day Basement Project (1/11-2/11)
http://www.avsforum.com/avs-vb/showt...php?p=19917865
thetootall is offline
post #640 of 1109 Old 01-23-2011, 02:19 PM
johnbomb's Avatar
...Not make decisions on an empty stomach. Those decisions will be in the best interest of said empty stomach.
John
johnbomb is offline
post #641 of 1109 Old 02-01-2011, 08:28 PM
SPDSpappy's Avatar
1) Like others have stated, room gets pretty warm with large parties & projector running: some sort of hvac add on (another complete zone/system -- very expensive from what I understand)
2) Place room under kid's rooms instead of mine -- even though the room is very soundproof, when system is cranked, wife complains when she's directly above it and hears the bass (even though it's not THAT loud upstairs -- a tv at regular volume drowns it out -- not that I'm bitter or anything
3) Use backing behind screen -- on certain movies with black background & white text (think Star Wars beginning scenes), I can see the text being lit through the screen (should I spray paint the OC 703 behind the wall black???)
Check out my "Too many decisions" build here:
Too many decisions...
SPDSpappy is offline
post #642 of 1109 Old 02-01-2011, 09:11 PM
Brad Horstkotte's Avatar
Liked: 71
Just cover with some cheap FR black fabric.
Brad Horstkotte is offline
post #643 of 1109 Old 02-02-2011, 08:59 PM
HuskerOmaha's Avatar
Quoted: 61 Post(s)
Liked: 55
Different Next Time:
Build a false wall and utilize an AT screen like everyone told me too. (And I'll just pretend the wife gave me permission).
HuskerOmaha is offline
post #644 of 1109 Old 02-02-2011, 09:51 PM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
Yes. AT's are great for so many reasons and as projectors get brighter they become more practical. I went the AT route and am very pleased.
erkq is offline
post #645 of 1109 Old 02-08-2011, 08:45 PM
DIYHomeTheater's Avatar
Originally Posted by Dennis Erskine View Post
5. Screens
---- Screen too big for the room. Screen widths should never be more than 80% of the room width. Keep the screen at least 3' off the floor (if not more) and don't mount it within inches of the ceiling. Big is not always better.
Isn't 3' somewhat subjective? Does it not depend on viewing distance? If you are 15' away from screen, you might be able to get away with 2' off the floor. (I know, you'd need a huge screen and a light cannon, but let's assume you can get that)
DIYHomeTheater is offline
post #646 of 1109 Old 02-08-2011, 09:07 PM
nathan_h's Avatar
Quoted: 1320 Post(s)
Liked: 862
Among other things 2' off the floor means you better have an AT screen and at least the center speaker behind it. A speaker at two feet off the floor is typically compromised. And there better be room aside the screen for the left/right, or an AT screen with them behind, or... again, a compromise on sound.
But perhaps more important -- since one assumes one has an extra large screen because image is what matters -- if you like to recline when watching a movie, you'll possibly have trouble comfortably seeing the bottom of the screen when it's that low...
Buy my Triad LCR or corner speakers or check out my current theater & gear.
Listen to the best movie review podcasts: the /filmcast and the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is offline
post #647 of 1109 Old 02-09-2011, 04:19 AM - Thread Starter
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 109
Yes .... 3' can be somewhat subjective; but, OTOH, it is also not incorrect considering the eyes are generally 42" AFF when seated. Viewing angle is the criteria. That will generally place the center of the screen at about 10 - 12 degrees above eye level for the first row. You have more than two rows? ... then things change a bit.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #648 of 1109 Old 02-09-2011, 04:31 AM
tony123's Avatar
Liked: 38
My screen is huge by most standards. 168" wide 2.35 in a 208" wide room. I was about to put a comment in that Dennis's recommendation of not exeeding 80% of the room width could be stretched. Then I did the math. I'm right at 80%.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #649 of 1109 Old 02-09-2011, 04:37 AM
Thanks. I think that it also depends on viewing distance. Your 10-12 degree criterion is appropriate and I think that one should stick with that. As you sit further back, the screen can drop a bit while still being in that viewing angle range.
post #650 of 1109 Old 02-09-2011, 04:39 AM
I am planning a nearly identical screen. Which screen and projector do you use? What's the screen height from the floor and your viewing distance? Thanks
post #651 of 1109 Old 02-09-2011, 05:09 AM
tony123's Avatar
Liked: 38
DIY, I don't want to take this thread off topic, so please PM me or visit my construction thread if you have any other questions. I'd be happy to talk.
Briefly, I have an AE4000 with the SeymourXD material. 20" off the floor and seating distances of 12', 19' (primary seating) and 24' (bar).
Construction Thread
tony123 is offline
post #652 of 1109 Old 02-09-2011, 05:19 AM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
What I would do differently...I had roughly a 15.0' wide area for my HT. I made a built-in for this area. I was short sighted on additional cabling that I had not considered (LAN cable, front height speaker cable, etc.). I either should have added this in the first place or made a cable tunnel in the bottom of the built-in cabinets with access to more easily and cleanly run these additional cables. It took a lot of "Fishing" and frustration to add these after the fact and took a lot of work to hide the cables.
btinindy is offline
post #653 of 1109 Old 02-09-2011, 08:06 AM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
I have heard the eyes should be 1/3 up the screen. That would give similar results to yours at certain viewing distances. I'm too lazy to do the math. In any case, that puts my 10' wide 16:9 screen 2' up off the floor. While it works well with my seating and a 15" riser for the second row, I am considering raising it to make the front row better suited to tall people. The 3' height may be a good compromise for me.
erkq is offline
post #654 of 1109 Old 02-19-2011, 10:36 PM
R Harkness's Avatar
Quoted: 2071 Post(s)
Liked: 1776
I prefer eye level to the center of the screen if possible. That presents the most "correct" and believable image geometry to the eye. All the perspective cues are captured directly on by the camera. The more off-axis you place yourself, vertically or horizontally, the more you introduce tell-tale shifts in perspective that tell your mind "I'm looking at a flat image."
I had a pretty complicated system for trying to achieve that (since my image size varies, as does my image center to some degree). But I got pretty close.
Occasionally someone comes in the room and says "wow, your screen is pretty low" since many people are used to looking up at a screen to some degree. But once they sit down the angle suddenly makes sense and they go "Oh...now I get it, this feels perfect!"
R Harkness is offline
post #655 of 1109 Old 03-15-2011, 08:51 AM
stepyourgameup's Avatar
Liked: 29
Make sure my outlets on the front wall are level with each other. Pay someone to do the drywall.
Alcohol. The cause of and solution to all of life's problems.
stepyourgameup is offline
post #656 of 1109 Old 03-15-2011, 10:48 PM
nathan_h's Avatar
Liked: 862
Originally Posted by stepyourgameup View Post
pay someone to do the drywall.
+1
nathan_h is offline
post #657 of 1109 Old 03-16-2011, 12:47 AM
Liked: 29
Originally Posted by nathan_h View Post
+1
I just can't justify paying someone $800 to do the drywall.
post #658 of 1109 Old 03-16-2011, 02:21 AM
Iusteve's Avatar
Unless your good at it yourself then it is money WELL spent and the professional results in such a little time frame cant be beat.
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is online now
post #659 of 1109 Old 03-16-2011, 05:21 AM
Liked: 29
Very true, however, when the lights go down nobody will see the drywall. I would rather put the money into a new projector or an Epik Empire.
post #660 of 1109 Old 03-16-2011, 09:27 AM
erkq's Avatar
Quoted: 658 Post(s)
Liked: 462
You can if you've ever done it yourself. If you haven't done it yourself I'd get someone to mud it for you at least. But that's just me.
erkq is offline
