What I'd do differently next time. - Page 35 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #1021 of 1038 Old 06-27-2016, 01:18 AM
erkq's Avatar
Quoted: 470 Post(s)
Liked: 363
Originally Posted by KanosWRX View Post
I have a rear entrance, but its at the rear corner, still can fit a row of seats in the back.. how wide is your room? I guess if its less then 16' wide or so then I could see how that would be hard.
Yeah... this is what I do too. The door at the rear opens onto the right isle. And my theater is 16' wide too. It's comfortable, not cramped.
erkq is online now
post #1022 of 1038 Old 07-03-2016, 05:23 AM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
I would have gone with theater seats with shorter backs. The higher backed chairs tend to block sound from the surrounds and possibly other detrimental effects. On the plus side. I did get a great deal on them and they're very comfortable!
healthnut is offline
post #1023 of 1038 Old 07-03-2016, 03:50 PM
Gary Sedlack's Avatar
What we are doing different this time. Our new home will have another dedicated room, it will be larger. Our current room is 23.8 long, 12.8 wide and 10 ft ceiling. The new room will be 24.2 long, 15.6 wide with a 9 ft ceiling. Also we are prewiring for Atmos.
We are looking at running HDMI in wall instead of using a switcher like we are now that is run via cat 5 in wall. Therefore going directly from the source to the HD or 4K TV that we will be using.
Have fun with music and HT
Gary
Gary Sedlack is offline
post #1024 of 1038 Old 07-04-2016, 03:51 PM
nickbuol's Avatar
Quoted: 442 Post(s)
Liked: 523
Ha. And I would have picked seats with taller backs and longer foot-rests for comfort. Speakers can be moved, but comfort is more limiting.
nickbuol is online now
post #1025 of 1038 Old 07-29-2016, 03:10 PM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
One important consideration for basement theaters: dehumidification. I have a sensor switch and fan to to the outside that turns on automatically in the event it senses excessive humidity. Moisture is not only bad for the basement, but for all your valuable electronics and speakers as well. It can be shut off when watching a movie, but it runs fairly quietly.
post #1026 of 1038 Old 07-29-2016, 05:00 PM
Patriot666's Avatar
Quoted: 94 Post(s)
Liked: 68
I run a GE dehumidifier in the basement. It runs constantly. I'm a bit obsessive about dehumidifying as well as humidifying in the winter to maintain a constant upper 40's. You are running a fan outside the house to dehumidify? Is it like a radon system fan? I haven't heard of this method. Thanks for sharing I'll have to investigate this.
Patriot666 is online now
post #1027 of 1038 Old 07-29-2016, 05:22 PM
sbowers2's Avatar
Don't move into a senior mobile home park, and hope to run a full-blown, THX-esque HT! Already had the sheriff visit . . . Got flex walls?
Current HT setup: AMD-based HTPC running Windows 10 Pro and Plex, Yamaha RX-V575 AVR, Vizio 65" LCD TV, Panasonic DMP-BDT225 Blu-Ray Player, Infinity SM-122 L-R Speakers, Klipsch RP-450C Center, Axiom QS-8 Surround Speakers.
sbowers2 is offline
post #1028 of 1038 Old 07-29-2016, 05:38 PM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
There was a pail-type dehumidifier in he basement when we moved in. It was noisy, almost always on, and had to be emptied frequently. I replaced it with a Panasonic fan I found on Amazon, you connect the fan to the ceiling and run ductwork to the outside (be careful to seal the outside vent carefully or water can come into your basement walls). You can buy several sensing switches (or manual only). I wanted one that sensed automatically and turned the fan on when humidity was sensed, but that I could also adjust the sensitivity of and manually turn on and off. I bought the Leviton, for around $20. Now, I'm good to go. Unfortunately for me, excessive humidity from pervious owners caused moisture problems in the walls, which I replaced (sound proofing and properly insulating as I went). The new walls should stay moisture free and I'm confident now my equipment will not be damaged by moisture.
post #1029 of 1038 Old 07-29-2016, 06:00 PM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
Btw, the Panasonic is strictly a dehumidifier, it's not a radon system fan. Heard about it on a home improvement radio program. (Glen Haege). Really surprised no one's mentioned the value of a ceiling mounted dehumidification system for a basement home theater, it's quite important.
post #1030 of 1038 Old 07-29-2016, 06:29 PM
Patriot666's Avatar
Quoted: 94 Post(s)
Liked: 68
My GE has an internal pump that auto drains out to my washer drain. It works well but runs constantly. I'm not sure it'd be worth it to cut a hole in the wall to the exterior to do what you did. It's something to consider though, thanks. I am considering doing that to run a backup water powered sump pump. Ie the sump pump that needs no electricity, just water pressure from the public water supply. Also it will work indefinitely, even if power is out for weeks, whereas a battery backup would run out of juice eventually. After lots of research it seems like a great solution to me as you're much more likely to lose electricity than water. https://www.amazon.com/Basepump-Wate...ater+sump+pump
rhodesj and healthnut like this.
post #1031 of 1038 Old 07-30-2016, 04:52 AM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
My GE has an internal pump that auto drains out to my washer drain. It works well but runs constantly. I'm not sure it'd be worth it to cut a hole in the wall to the exterior to do what you did. It's something to consider though, thanks. I am considering doing that to run a backup water powered sump pump. Ie the sump pump that needs no electricity, just water pressure from the public water supply. After lots of research it seems like a great solution to me as you're much more likely to lose electricity than water. https://www.amazon.com/Basepump-Wate...ater+sump+pump
Sump pumps are also an important, (though often overlooked), part of properly maintaining a basement. This is valuable information for sure, thanks for posting!
post #1032 of 1038 Old 08-02-2016, 07:24 AM
Scott 44's Avatar
Quoted: 38 Post(s)
Liked: 35
I would have use liquid nails on all my soffits. The 2 12 SVS subs are starting to rattle the wood veneer that was brad nailed and wood glued. where there are low spots the glue did not adhere:disappointed::weary:
ID:	1579369   Click image for larger version
Scott 44 is online now
post #1033 of 1038 Old 08-13-2016, 08:23 AM
Liked: 3
what I would do different is hire a dedicated theater designer
GreySkies and hatlesschimp like this.
SeanP48072 is offline
post #1034 of 1038 Old 08-13-2016, 09:17 AM
healthnut's Avatar
Quoted: 319 Post(s)
Liked: 174
You might have been better served using screws rather than nails also.
post #1035 of 1038 Old 08-13-2016, 12:16 PM
Scott 44's Avatar
Quoted: 38 Post(s)
Liked: 35
I would love to see how you hide wood screws on a finished veneer paneling and crown molding:stuck_out_tongue_winking_eye::joy::joy:
post #1036 of 1038 Old 08-13-2016, 01:16 PM
LastButNotLeast's Avatar
Quoted: 1240 Post(s)
Liked: 888
I think he meant to say you're screwed.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #1037 of 1038 Old 08-15-2016, 05:32 AM
GreySkies's Avatar
Quoted: 616 Post(s)
Liked: 428
I used wood plugs and a little bit of filler with all the wood trim I put in the media room in my last house.
GreySkies is offline
post #1038 of 1038 Old 08-15-2016, 09:09 AM
erkq's Avatar
Quoted: 470 Post(s)
Liked: 363
Yes, that's a common method, but not without compromise, depending on how detailed you want to be. It's hard to have continuous grain through a plug! But it's the way I'd do it too if I had wood trim.
erkq is online now
