Worth it to Install new floating sub floor solely for tactical Sub Bass feeling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-06-2007, 10:52 AM - Thread Starter
John Ballentine's Avatar
I'm thinking of removing my carpet/pad (over concrete floor) and installing a floating plywood sub floor. This would be solely for the purpose of possibly obtaining back that tactical sub-bass feeling I had previously when my theater was located in an upstairs room where the floor was ¾" plywood on joists.
Problem:
I only have 1" height to work with. I'm thinking of using ¼" rubber isolation pads and one layer of ¾" T&G AC plywood. With the carpet reinstalled on top.
Or would I be better off using 2 sheets of 3/8" AC plywood ? I could use construction adhesive and 5/8" drywall screws to sandwich the sheets together - staggering the joints w/ the second layer. But would this "feel" stable under foot? Would it generate the effect I'm looking for?
Any other ideas?
Thank you for your time!
John Ballentine is offline
post #2 of 8 Old 06-06-2007, 10:55 AM
drin's Avatar
Why not just put buttkickers in your chairs? Nice tactile feeling, FAR less work...
-drin
Resident curmudgeon
drin is offline
post #3 of 8 Old 06-06-2007, 11:05 AM - Thread Starter
-drin
I do have buttkickers in each of my chairs (Berkline 090). They work great - but they just don't give me the "feeling" I'm looking for. Hard to describe.
But your right - adding a sub-floor is a tremendous amount of work and expense. And I want to make darn sure it will work out for me before I proceed.
post #4 of 8 Old 06-06-2007, 11:14 AM
Plasma George's Avatar
You have 1" or 1' ? to work with ?
Search "Thunder Deck", and you'll see my thread...(I'm going to update it soon cause I drywalled) I did a 2x10 subfloor for just this reason, a 10" and a 12" enclosure built between the studs to perfect volumes.
I can't wait to hear the Millenium Falcon flying overhead !
There are 2 types of people in this world - home theater enthusiasts and idiots
Plasma George is offline
post #5 of 8 Old 06-06-2007, 11:40 AM
McCall's Avatar
Do you have a riser? I read a thread here somewhere about putting a second sub on the riser for that purpose and I tried it. And it is fantastic. That would probably be a good way to go, though. I have Bass shakers also in the riser and on the mounting plate of the front row which is mounted to a board to which the front row seats are mounted on the floor. Actual Floor is concrete covered with underlayment.
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
post #6 of 8 Old 06-07-2007, 12:17 PM - Thread Starter
Yes - I may bolt a second sub to the riser to help out row #2. But that will do nothing for my first row. So I'm gonna plan to go ahead and do the double 3/8" plywood on 1/4" isolation pads. (Even though my wife is gonna think I've lost it when she sees me tearing up the freshly laid carpet!)
post #7 of 8 Old 06-07-2007, 12:36 PM
I don't see you getting much improvement with a 1" space between the new floor and concrete.
I'm doing 2x10s, so what vibration you feel in the explosions is big volumes created by the joist spacing....you're not going to have that.
You're gonna get a rumbling effect of a 1" deep enclusure ???
post #8 of 8 Old 06-08-2007, 11:02 AM - Thread Starter
I'm thinking the Bass frequencies will travel through the plywood energizing the chairs that are sitting on top. The floating floor will also isolate the floor from the walls. Subs will be putting all their Bass energy into the new plywood floor/chairs - instead of into the concrete floor/walls. Has nothing to do w/ volumes created by joist spacing. But I know what you are saying. I may do a mock-up test and place some (sandwiched double 3/8") plywood on top of my carpet w/ the sub sitting on one end and a chair sitting on the other end - and see what I see. Before going to the trouble of tearing out my carpet. (or am I thinking like a crazy man?)
