Looking for CAD symbols - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 08-03-2007, 07:29 AM - Thread Starter
tony123's Avatar
Liked: 38
Does anyone have nice looking home theater symbols in .dwg format?
I'm looking specifically for home theater recliners. Plan and side elevation views.
I've searched the net and come up with nothin'
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #2 of 32 Old 08-03-2007, 11:22 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I posted .dwg's of berklines a while back. I'm sure they're in the archive now. Try searching the archive.
Tim
Mr.Tim is offline
post #3 of 32 Old 08-03-2007, 01:32 PM - Thread Starter
tony123's Avatar
Liked: 38
I've spent a half hour searching in various ways and turned up nothing.
Construction Thread
tony123 is offline
post #4 of 32 Old 08-03-2007, 02:01 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
The thread was in the archive
http://archive2.avsforum.com/avs-vb/...d.php?t=649741
However, I see that the link I posted in the archived message does not work. I will post a new link here:
Berkline Seats in DWG format
Tim
Mr.Tim is offline
post #5 of 32 Old 08-03-2007, 07:37 PM
drunkpenguin's Avatar
Quoted: 1351 Post(s)
Liked: 1369
The search engine here really doesnt work well. Try using google and more often than not the thread you want from this site will show up.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #6 of 32 Old 08-03-2007, 09:28 PM
evaluator's Avatar
Sometimes I use the CAD Block Exchange Network. It's free and it's not warez. Since this is my first post I can't include the link so you'll need to google it.
_________
Patrick
evaluator is offline
post #7 of 32 Old 08-04-2007, 03:39 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
Well if something is in the archives you need to enter the archive, then search.
The search works fine; you have to read the advanced search instructions to make your search AND/OR etc.
Tim
Mr.Tim is offline
post #8 of 32 Old 08-04-2007, 06:56 AM - Thread Starter
tony123's Avatar
Liked: 38
Thanks for your efforts Mr. Tim!
I had entered the archive and searched. Maybe I didn't follow some of the detailed rules.
However, the link you just posted is not going anywhere for me.
I'm not a computer wiz, but not illiterate either. This is embarrassing.
Construction Thread
tony123 is offline
post #9 of 32 Old 08-04-2007, 11:11 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I just tried them both, they both work (they being the link to the old thread and the link to the dwg file).
Tim
Mr.Tim is offline
post #10 of 32 Old 08-04-2007, 06:21 PM - Thread Starter
tony123's Avatar
Liked: 38
Well, I've troubled you guys enough, but the link to the drawing is still not working for me. I've tried it through IE and Firefox. This is the error I'm getting "The requested URL /AVSforum/berkline_seats.dwg was not found on this server."
The link to the previous thread does work for me.
Thanks for your efforts here Tim, but I don't want to put you through anymore trouble.
Construction Thread
tony123 is offline
post #11 of 32 Old 08-05-2007, 04:48 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
You have to right-click and "Save As"
Tim
Mr.Tim is offline
post #12 of 32 Old 08-08-2007, 08:56 AM
CJO
CJO's Avatar
The second link as well as the link inside of the archived post don't work for me either.
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
post #13 of 32 Old 08-08-2007, 09:16 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
The new link, in post #4 does work.
If you click on it as normal (ie left-click) you will receive the error "no such" whatever, because apache doesn't parse .dwg files.
However, if you right-click and select "Save As" per post #11, you can download the file.
Tim
Mr.Tim is offline
post #14 of 32 Old 08-08-2007, 09:30 AM
G-Bull's Avatar
Here's a seldom-used feature of google...
If you want to use google to search for results from just one website (such as avsforum.com), precede your google search with "site:avsforum.com"
So if you google "site:avsforum.com .dwg seats" you'll get to the threads previously mentioned...
G-Bull is offline
post #15 of 32 Old 08-08-2007, 10:38 AM
CJO
CJO's Avatar
Tim
That is what I tried to do. When trying to save the link target, you get the error "Inernet Explorer cannot download berkline_seats.dwg from plattco.net. Internet Explorer was not able to open this Internet site. The requested site is either unavailable or cannot be found. Please try again later."
CJ
CJO is offline
post #16 of 32 Old 08-08-2007, 10:43 AM
CJO
CJO's Avatar
Mr. Tim- what browser are you using? I just looked at the .jpg's that you posted and the options are similar to, but not exactly what I have when right-clicking on an item. Here are the options that I have.
CJ
CJO is offline
post #17 of 32 Old 08-14-2007, 11:41 AM - Thread Starter
tony123's Avatar
Liked: 38
I've tried all of the above options and still no access.
Construction Thread
tony123 is offline
post #18 of 32 Old 08-14-2007, 12:09 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
That's a problem with internet exploder.
I use firefox, it works. I thought you were all nuts, until i blew the dust off of IE and I get the same error.
You could research the ms knowledge base for an answer or just use a different browser.
Tim
Mr.Tim is offline
post #19 of 32 Old 08-14-2007, 03:10 PM - Thread Starter
tony123's Avatar
Liked: 38
I tried Firefox, and did get the link to work. I got to the thread, and was able to download the dwg file. So, it was, an IE issue. However, it came up as "file not valid" when trying to open in ACAD. I'm in 2006, so maybe can't open r12? and it seems the dxf file is no longer there.
I'm sure they can build the chairs quicker than I can get to these files Thanks for continuing to try.
tony
Construction Thread
tony123 is offline
post #20 of 32 Old 08-14-2007, 05:45 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
This is my last ditch effort.
Berkline Seats dxf and dwg zip file
The file contains the dxf and the dwg.
The previous dwg file was corrupt, I downloaded it and tried to open it... got the same error.
Tim
EDIT: I downloaded the file, unzipped and loaded them in AutoCAD 2005. THey are confirmed to work. I also tried IE and if you left-click on the link it will prompt to save or open. IE also successfully downloads the files.
Mr.Tim is offline
post #21 of 32 Old 08-14-2007, 07:13 PM
evaluator's Avatar
If you're looking for something more traditional, in the CAD Block Exchange Network under furniture on page 13 there's one titled "wicked theatre chair". Haven't used it yet but the thumbnail looks good.
...or even more traditional is the "butaca" on page 19.
_________
Patrick
post #22 of 32 Old 08-15-2007, 07:47 AM
CJO
CJO's Avatar
That worked- thanks!
CJ
CJO is offline
post #23 of 32 Old 08-16-2007, 08:31 AM - Thread Starter
tony123's Avatar
Liked: 38
Yep, that did it! Confirmed to work in 2006 too.
Thanks for your persistance Tim.
Construction Thread
tony123 is offline
post #24 of 32 Old 08-16-2007, 03:36 PM
evaluator's Avatar
There's a sweet 3-D, dimensionally correct Lazy Boy recliner at CAD Block Exchange Network> Furniture>3D>page 5.
_________
Patrick
post #25 of 32 Old 08-17-2007, 05:12 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
No problem guys, hope they are useful.
Tim
Mr.Tim is offline
post #26 of 32 Old 03-07-2013, 07:08 PM
Mntneer's Avatar
Quoted: 40 Post(s)
I hate to resurrect such an old thread, but the links in this one have since expired and I was wondering if anyone has any links to some good theater seat autocad files.
Mntneer is offline
post #27 of 32 Old 03-08-2013, 03:23 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I will upload them again if nobody else chimes in in the meantime.
Tim
Mr.Tim is offline
post #28 of 32 Old 03-08-2013, 07:42 AM
Mntneer's Avatar
Quoted: 40 Post(s)
Thanks Tim.
Mntneer is offline
post #29 of 32 Old 03-08-2013, 04:39 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
The link in post 22 should work again.
Mr.Tim is offline
post #30 of 32 Old 03-11-2013, 08:28 AM
NickTheGreat's Avatar
Quoted: 435 Post(s)
Liked: 307
Link worked for me. Don't know if I'll need it, but I'll have it if I do biggrin.gif
NickTheGreat is offline
