Thoughts on Baffle Walls - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Don_Kellogg
post #1 of 29 Old 08-22-2007, 12:39 AM - Thread Starter
Don_Kellogg's Avatar
I've done a little research on this topic and have the idea of how it needs to be built. The one thing I have not found is how thick the insulation should be on the front and back of the baffle. At this time I plan on using Lin RC 1" do you guys think this will be enough? Second how far from the screen should I put the baffle wall?
"Anyone who lives within their means suffers from a lack of imagination."
Don_Kellogg is offline
post #2 of 29 Old 08-22-2007, 11:30 AM
dc_pilgrim's Avatar
Hasn't BasementBob played around with baffles? I'd PM him.
Googling his site I came up with this link:
http://www.bobgolds.com/Baffel/home.htm
dc_pilgrim is offline
post #3 of 29 Old 08-22-2007, 11:59 AM
Quoted: 3255 Post(s)
Liked: 2743
Don, interesting concept, I had to do some research to figure out what you were talking about.
http://www.thx.com/cinema/builtTHX/baffle.html
I'm curious about the improvement over just covering the entire front wall behind the speakers.
I seem to remember that Ruben talked about how far back from the screen the speaker faces should be but I forgot. Once you have that dimension then you should figure out how far back from the face of the speaker you want the baffle wall if not even. I'm not certain what material to use.
You might look at all of the various alternatives here for the wall.
http://www.bobgolds.com/AbsorptionCoefficients.htm
The IIG 1.5 inch thick mineral wool board has some interesting numbers compared to the 1 inch Linacoustic RC
You have given me some food for thought as I plan my HT 2.0 with AT screen.Please keep us apprised of your progress and listening impressions.
post #4 of 29 Old 08-22-2007, 12:01 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
You need to be careful with baffle wall construction. The depth of fiberglass on the face of the baffle will be a function of the speaker's performance. For example, Wilson Sophia's only "want" 1" because of their mid-range dip. Your mileage on other speakers will vary.
We also curve our baffles.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #5 of 29 Old 08-22-2007, 07:20 PM - Thread Starter
Thank you for chiming in Dennis, I have Klipsch RF7 speakers with horns. I planned on a slight curve as well.
post #6 of 29 Old 08-22-2007, 07:25 PM - Thread Starter
I'm curious about the improvment over just covering the entire front wall behind the speakers.
As with all my home theater adventures I will share my experience with the masses. At this time I plan on building a baffle wall using plywood, slightly curving the wall. The openings will be about 1" bigger than the speakers, and I'll probably use 1 inch Lin shield or Lin RC.
Today I finished 99% of the remaining drywall for the equipment room. I hope to finish the fabric and the other finishing tomorrow. I can't wait to install my Slim 5 rack, UPS delivered it today. The rest of the drawers and shelves will be here next week. I forgot to order the XBOX 360 custom plate and some other stuff.
post #7 of 29 Old 08-22-2007, 07:58 PM
Liked: 2743
Don, What effect do you think you will have on the overall sound performance of those speakers with the rear ports buried behind the baffle wall??
Just asking I don't have a clue.
post #8 of 29 Old 08-23-2007, 10:50 PM - Thread Starter
I would expect the imaging of the highs to be slightly better. Since the sides of the screen wall are still going to be open I would figure the porting on the lows would be fine. At this time I have really good imaging, but I'm hoping the baffle wall will add to the clarity even if only a little. From what I have read a baffle wall prevents the sound waves from traveling behind the speaker, I think this is cabinet effect? Preventing this reinforces bass, and helps with imagining.
Now of course I didn't major in speaker design, or acoustic design so...
post #9 of 29 Old 08-24-2007, 06:14 AM
Liked: 2743
Will you be treating the wall areas behind the baffle and the rear side of the baffle so that area doesn't become a big echo chamber for the port sounds?
post #10 of 29 Old 08-24-2007, 12:52 PM - Thread Starter
The whole room has treatments, sides and rear have 1" LIN RC on lower half 16 oz bat on upper part. The front wall, and sides behind stage have 2" of LIN RC top to bottom. Of course the soffits are treated as well.
post #11 of 29 Old 08-24-2007, 01:12 PM
Liked: 2743
You had mentioned using plywood for the baffle wall, I would stick a layer of LIN RC on the back side as well.
post #12 of 29 Old 08-24-2007, 01:31 PM - Thread Starter
THX Tech Pages
for most viewers physical discomfort begins when this angle exceeds 35 degrees. We strongly recommend that the layout of the auditorium adheres to this engineering guideline.
III. Sound System
A. Baffle Structure
1. Construction
With each site specific baffle drawing set supplied by the THX design office, the overall dimensions, materials specification, and installation directions must be closely followed. Also please note a minimum of 4'-3 " (1.3 meters) of available room is necessary behind the screen to construct the baffle.
2. Speaker Holes
a) Placement
The placement of the speaker holes in a THX baffle structure is very specific and is determined by the image sizes. A new baffle drawing must be generated by the THX design office if the image sizes change.
b) Size
The size of the speaker holes is determined by the equipment chosen from the THX approved equipment list.
3. Isolation Pads
One Mason "Super W" pad (Durometer 40) is used under each corner of the screen woofers and the subwoofers to isolate the vibrations of the speakers from the baffle structure. A list of Mason Industries' representatives is available from the THX design office.
4. Absorption on Face
The entire face of the baffle structure is covered with 1" (25 mm) Coated InsulSHIELD" Black, a product manufactured by Schuller International, Inc. This is a specific product. No substitutes are accepted unless the acoustical properties of the material in question are the same as that of the 1" (25 mm) Coated InsulSHIELD'" Black. In this case, a sample and specification of the material must be submitted to THX for approval.
5. Exit Corridors Behind Screen
In general, corridors behind the screen are difficult to deal with but they can be accommodated in most cases. If your theatre has screen wall exit corridors, make sure to send elevations to the THX design office for coordination.
Rev. 1/98 Page 9
6. Absorption on Demising Wall
The area behind the baffle structure should be covered with 2" (5 cm) of fiberglass. This should include the rear wall, one side wall, and the ceiling.
B. Surround Speakers
The surround speaker array is designed by THX to provide uniform coverage of the audience. THX supplies spacing, height above finished floor, and aiming angle for the loudspeakers.
If you have any sidewall treatments or interior design details with which you would like to coordinate the speaker layout, please let the THX design office know.
IV. What Architects Should Expect From THX
A. Drawings
1. Baffle
2. Surround Speaker Layout
3. Single Line Electrical
B. Reverberation Limits Curve
C. Equipment List
D. Resource Materials
1. EG-18
2. THX Architect's and Engineer's Manual
E. General Advice
1. Equipment 2. Construction
a) Common Wall b) Baffle c) Absorption Material
3. Installation 4. Projection
a) Images b) Sight Lines
hatlesschimp likes this.
post #13 of 29 Old 08-24-2007, 01:33 PM - Thread Starter
Hope the above helps clear things up. I'm probably going to use 1-1.5" MDF to maintain over kill status. I'm still reading to see if I can find the calculation for speaker hole placement, it's depends on the speakers and image size.
post #14 of 29 Old 08-24-2007, 03:32 PM
Liked: 2743
Do you have the 4ft 3 inches behind the Baffle?
post #15 of 29 Old 08-24-2007, 08:49 PM - Thread Starter
Yep sure do give or take 1/4 of an inch. Not only for spec but for all the SVS PB13u's I'm putting back there. My intent is to have 5 of them when I'm done.
post #16 of 29 Old 05-01-2009, 06:39 AM
Tedd's Avatar
Quoted: 922 Post(s)
Liked: 339
Bumping this thread, I am contemplating a DIY baffle wall and curious on anyone else's experience.
Tedd is online now
post #17 of 29 Old 05-30-2013, 08:46 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Can I ask a very noob question ? What is the purpose of building a baffle wall ? I'm not sure I'm understanding ... But I'd like to.
Mfusick is offline
post #18 of 29 Old 05-30-2013, 09:04 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
Baffle walls are built to hide your speakers behind when you are using an acoustically transparent screen. They are generally very minimalistic in structure and covered with acoustically transparent fabric (in locations where the speakers would fire through the wall) or some type of black felt material which provides more light absorption than the fabric will. Hope that helps.
vanice is offline
post #19 of 29 Old 05-30-2013, 10:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
But why can't you just have normal speakers behind an AT screen ? What does the baffle do ?
Mfusick is offline
post #20 of 29 Old 05-30-2013, 10:23 AM
jjhall5150's Avatar
Your center channel would be behind the AT screen, most likely centered to the middle, the L/R speakers would be setup to the left and right of the actual screen and would be exposed. The baffle wall with fabric covering would hide the L/R speakers and the subwoofer if you were to place that behind the screen as well
jjhall5150 is offline
post #21 of 29 Old 05-30-2013, 10:48 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ah.. So if your planning all your speakers behind AT screen then there is no need for baffle wall.
Baffle is to build in a speaker that's not really an in wall speaker to appear as it is an in wall speaker ?
Mfusick is offline
post #22 of 29 Old 05-30-2013, 10:51 AM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
There are good acoustical reasons for building a baffle wall. See my blog post on THX baffle wall design and build.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #23 of 29 Old 05-31-2013, 01:38 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
But it sounds like you need special speakers that are designed to use with a baffle wall.
If you had normal speakers (bookshelf, tower etc.. ) Your probably better off not using a baffle wall ?
Mfusick is offline
post #24 of 29 Old 05-31-2013, 03:02 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Its more that you need a suitable way to EQ them if baffle mounted as speakers not "designed" for baffles have different crossovers as opposed to those that are....
.....on the more pressing point of how to design one of these....NFI
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #25 of 29 Old 05-31-2013, 03:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
That makes sense to me. It seems like baffle speakers are reserved for the high end and are expensive. Are there affordable speaker options for using baffle wall ? (like $5000 speaker system)
Or better- A DIY or build your own option ?
Mfusick is offline
post #26 of 29 Old 05-31-2013, 04:12 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
DIY is a little hard unless you've got a proven design. I'd have a look at Triad's in wall speakers.
If you're thinking about a baffle you'd probably want to speak to someone like The Erskine Group as you've only got one go at getting it right (unless you want to tear it down)
Peter the Greek
Elill is offline
post #27 of 29 Old 05-31-2013, 05:40 PM
Liked: 2743
The 4Pi speaker kits from Wayne Parham are approved for in wall (or in baffle mounting) by the designer. Fits your budget and will perform well. That is a 15 inch woofer
post #28 of 29 Old 08-30-2013, 01:19 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am not sure why I did not see your reply sooner. (it has been a while)
I was looking at those speakers, those and also the SEOS designs. My specific question I think you just answered- would the same be true for like model SEOS ?
The difference with Wayne's is he uses the JBL driver (premium option) with the alternate tweeter (as opposed to DNA360 from DIYsoundgroup). Both Crossovers appear to work well and are tested well with many users.
I am struggling between the two- as the JBL option like you have is more expensive (due to the drive and tweeter costing more) What I am trying to weigh out is three things:
#1.) Is the difference worth the extra cost ? (Is it even noticeably better ? )
#2. ) If the difference is not obviously worth the cost- does SEOS work as well in such a set up ? (if not back to the pi )
#3.) Worth bothering with a baffle wall versus just a fake screen wall.
Thanks for the reply you have already provided, I wonder-- What do you think ? ^
You have heard both the SEOS and the Pi - what are your personal thoughts on my questions ? (or anyone else ?)
Thanks in advance!
Mfusick is offline
post #29 of 29 Old 02-25-2014, 08:32 AM
nathan_h's Avatar
Quoted: 1007 Post(s)
Liked: 600
Yep
Ok Don, you have been living with your baffle wall for five years now. In retrospect, any lessons learned?
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
