The Arthouse" (fomerly "The Grindhouse") - Planning and Construction Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 06-29-2009, 03:15 PM
heavyflyr's Avatar
Hi Rob,
Like all the others, GREAT BUILD!!! You have saved me from much headache and I have not even begun.
My dimensions are 10.5x17 with 9' ceiling height and in a basement with three concrete walls and and a 2x4 drywall wall. One of the concrete walls has a window that I will be covering. I will attach some pictures.
What did you use for bass traps? I have purchased the Klipsch THX Ultra2 and will have a very serious bass situation. Also, as if you cannot guess, I am going to plagiarize the hell out of your design so consequently I will need to modify the speaker housing in order to accommodate a larger square speaker. Anyone care to chime in here with suggestions?
Would it be a bad idea acoustically to place all the speakers (front) starting left, sub, center, sub, right (read: on the same horizontal plane directly below the screen)? Or aesthetically?
Ben
heavyflyr is offline
Old 08-17-2009, 08:40 PM
heavyflyr's Avatar
Old 12-26-2009, 03:08 PM - Thread Starter
rsprance's Avatar
Liked: 24
Electronic House just did a feature on my theater!
http://www.electronichouse.com/artic..._home_theater/
rsprance is offline
Old 12-26-2009, 06:59 PM
thaxx's Avatar
Great article. I think your room is at the top of all the rooms I've seen here. I did have one question. On the birch panels, I assume it is birch plywood. How did you finish the exposed edges?
Again, Gerat build.
Mike
thaxx is offline
Old 12-27-2009, 10:35 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Robb,
Congrats on making EH!!
Did they send a photographer for the finished photos, or did you provide all of the photos?
Either way a nice article, your theater turned out great!
One question - could you point me to the details for that acoustic panel on your back wall?
Cuzed2
CuznEddy Cinema
cuzed2 is online now
Old 01-05-2010, 05:36 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
chinadog is online now
Old 01-06-2010, 10:47 AM
dpn
dpn's Avatar
Like everyone else I am drooling over your handiwork!
Is the 108" screen dimension a diagonal or horizontal measurement?
Thanks in advance...
DPN
dpn is offline
Old 01-16-2010, 04:31 PM - Thread Starter
rsprance's Avatar
Liked: 24
Again, Gerat build.
Thank you!
They have an iron-on birch edging that you can get at home depot to make the edges look great. You iron it on and trim the excess.
rsprance is offline
Old 01-16-2010, 04:35 PM - Thread Starter
rsprance's Avatar
Liked: 24
Robb,
These were photos that I took. It's not easy taking pictures in a mostly black room!
The acoustic panel on the back wall was made from a light wood frame with thin wood as the frames. I stuffed the inside with an OC703 panel and then wrapped it with the exact material Berkline used on my seats. I ordered it direct through my dealer.
Here are the exact details
http://www.avsforum.com/avs-vb/showt...2#post12644482
rsprance is offline
Old 01-16-2010, 04:37 PM - Thread Starter
rsprance's Avatar
Liked: 24
DPN
Drool is a good thing, as long as it's not on the suede seats!
The screen is a 108" diagonal measurement.
rsprance is offline
Old 05-11-2010, 10:52 AM
NinjaofDoom's Avatar
Amazing theater! I am new to the site and have just started the planning phase. With so many basement theaters on this site, it was nice to see someone else building on the 2nd floor like myself. I have a 19L x 16.5W x 8' H bonus room that will be a dedicated setup. Seems like i will have the room to have a similar setup to yours but with larger columns (Id like the M60 towers). Any pics of how your Center channel is mounted? does anyone hit their head when up on the riser on the side of the room? 10' soffit + 1' riser = 6' ceiling there?
Thanks so much for this thread, as it has given me many ideas!
Cheers,
Mike
NinjaofDoom is offline
Old 12-08-2010, 02:52 PM
dpn
dpn's Avatar
Thanks again for the inspiration...Here's mine...
DPN
dpn is offline
Old 01-05-2011, 11:52 AM
cklinejr's Avatar
Awesome looking home theater!
It really turned out great.
-Charles
cklinejr is offline
Old 04-04-2011, 04:26 PM
heavyflyr's Avatar
Hi Rob,
I just finished my theater that copied many of your ides. Check it out if you have a minute.
Ben
Old 06-19-2012, 12:20 AM
toddshack's Avatar
What are the dimensions of you soffits for sides, front and back?
Todd
toddshack is offline
Old 09-06-2012, 10:10 PM
ohshift's Avatar
Excuse my late entry, and I am guessing this may never get to you, but could you provide the sketchup file you created? If not, I understand!
AMAZING work!
ohshift is offline
Old 01-18-2013, 07:32 AM - Thread Starter
rsprance's Avatar
Liked: 24
It been ages since I looked at this thread. Thanks for all of your kind words!
The theater is still kicking and going strong. Other than some equipment changes for media consumption, the original setup is still going famously (knock on suede Berklines).
rsprance is offline
Old 10-08-2013, 09:54 PM
rogannz's Avatar
Quick thanks. This thread has been hugely helpful for what I'm planning. Hoping to emulate some of it in mine.
rogannz is offline
Old 04-19-2014, 09:50 PM
JJCard's Avatar
Hi There! How wide were your acoustic and plywood panels? I'm currently working on my own setup and was thinking of "borrowing" your stained panel look :)
Jeff
JJCard is offline
Old 06-15-2014, 12:30 PM
Liked: 0
I hope this post is not dead...
First thing first CONGRADULATION, Your setup is nice and that gona be my main model for mine since we have same room size. I have a couple question regard your setup to adapt with my audio gears. I have rf82, rs52, rc-62 and probably 2x ELEMENTAL DESIGN A7s-650 .
1- Did you thing Im gonna have a sound issue if I put my RF-82 and sub insde the coulum? I think they need lot air to breath.
2-Do you have an issue with the center channel? I've heard for best soud quality is good to have it above the screen or not far from ears at seating position.
3-Where did you take your wood panel?
4-do your projector have enough room to breath?
sorry for my english
Thanksto help!
mdpower is offline
Old 10-11-2014, 07:17 PM
Quoted: 16 Post(s)
Liked: 0
Where did you buy your chairs?
Ryan Rosser Byorick is offline
Old 10-11-2014, 07:42 PM
Quoted: 3256 Post(s)
Liked: 2743
the author hasn't been around for 20 months. On the first page he lists them as Berkline 45088. you can google that for current vendors, Just a FYI Berkline went bankrupt and sold the brand name to Lane I think, the chairs are now made in China.
Old 10-12-2014, 06:12 AM
Quoted: 16 Post(s)
Liked: 0
Thanks Jeff!
Old 12-17-2014, 10:33 AM - Thread Starter
rsprance's Avatar
Liked: 24
Thanks for answering in my absence, Jeff. It's so great to see so many people still commenting on the theater.
I use it so much, especially for gaming. PS4 games look and sound so good in this room!
rsprance is offline
Old 11-06-2015, 09:23 AM
helmsman's Avatar
Quoted: 42 Post(s)
Liked: 32
Have to tell you Rob, even though my theater came out looking quite different, your finished theater pics were one of my main inspirations. I actually hadn't seen your build thread before today but your pics came up in a google image search I did before my rebuild and I recognized them in a recent post. Really nice job!
helmsman is offline
Old 05-20-2016, 10:25 PM
Liked: 0
great theater room on the best I have very seen wish I had the knowledge to pull off just a wonderful project.
rogue 01 is offline
Old 08-23-2016, 12:27 PM
Quoted: 156 Post(s)
Just Wow!! From merely a sketchup like image to even better in reality!! Lucky you all who have space to convert to dedicated theaters. I am jealous .
busybe is offline
