What, exactly, is smurf tube? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 35 Old 11-23-2010, 11:55 AM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Originally Posted by Neurorad View Post
Yeah, the 1" conduit is easy to install.
Do any inspectors/AHJs have issues with the blue flex conduit for low voltage, since, I believe, it's rated for line voltage?
It's perfectly legal to "downgrade" materials like that. I do know of one restriction however. You can't use fire alarm cable for anything but fire alarms - go figure!
Glimmie is offline
post #32 of 35 Old 11-23-2010, 03:20 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
The ridges inside the flex conduit reduce the contact area with the cables, making the cables easier to pull.
Some rigid conduit has ridging on the inside, for the same reason.
That another benefit of the flex, compared with the gray rigid NMT/PVC.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #33 of 35 Old 07-30-2012, 11:55 PM
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
This is a thread that just keeps on giving (look at the dates)
Anyhow, I like the idea of using orange for all the LV, but the orange is hard to find and expensive. I plan to use 3/4" for my speaker cable runs, one 3/4" conduit for 2-3 speakers back to the equipment closet. Anyhow, to get 100' orange online can be $50+ To buy the blue stuff at the local home improvement is $30-$35. So I'll stick with the blue when I can.
For my projector - 2" orange, I'll get it online. For my screen wall 1.5" orange also online. But most of my 3/4" runs will be in blue, just to save $$$
But who knows, if I find the blue cheaper, I'll do that. For me color coding would be cool and all, but money is money rolleyes.gif
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
post #34 of 35 Old 07-31-2012, 12:08 PM
GPowers's Avatar
Quoted: 43 Post(s)
Liked: 49
If you are using orange conduit it would no longer be Smurf tube. Since the orange tube is more expensive you could call it "Annoying Orange" Tube. smile.gif
GPowers is online now
post #35 of 35 Old 07-31-2012, 01:34 PM
cdika17's Avatar
Liked: 27
Unless you catch a warehouse foreclosure and get 200ft of 2" and 1" Kwikpath riser raceway for free! Orange not so annoying now.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
