Multi-level drop ceiling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-05-2001, 02:52 PM - Thread Starter
Shag's Avatar
One of the rooms in the basement I'm finishing has some duct work that runs below the joists, and would be a pain to drywall around. So, I'm considering a drop ceiling, but would like to avoid losing the 12"+ of ceiling height in the rest of the room. Basically, I'm wondering if it's possible to install a 2-level drop ceiling. Logistically, it doesn't seem like it would be all that difficult, I'm just not sure if they make anything to accomodate vertical ceiling tiles. Anyone know if I can do this?
-Shag
Shag is offline
post #2 of 5 Old 11-05-2001, 06:02 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
They don't actually make vertical ceiling tiles but boxing around something or stepping down is easy and very commen. Just build a frame out of grid parts. Use pop-rivets to hold the frame together. I have seen white pop-rivets but it's just as easy to paint raw ones with a small brush. Cut the tiles very accurately slightly oversize. This will "pinch" them place. Or if you can get to the back secure them with a few blobs of silicon caulk.
Glimmie is offline
post #3 of 5 Old 11-05-2001, 08:52 PM
Jim Mc's Avatar
I would check at a good ceiling goods supplier to see if grid work is made to facilitate the vertical panels. I know I have seen it done in commercial buildings and the pros would want a fast and easy way to do the job.
Jim Mc
"The Stargate"
http://albums.photopoint.com/j/Album...&sp=1&vt=vpall
Jim Mc is offline
post #4 of 5 Old 11-06-2001, 03:22 PM
jakermc's Avatar
I have a 2-level drop ceiling in my basement. The lower section runs from the front of the theater to about the middle of the room where a steel support beam runs parallel to the front wall. The beam is boxed in with dry wall, creating a vertical "wall" that rises and meets the begining of the higher section of ceiling tile. It looks great and actually helps create the feeling of two rooms - a theater in the front of the room and a bar in the back half.
I used Armstrong tile and grid, if thats helpful.
jakermc is offline
post #5 of 5 Old 11-06-2001, 06:59 PM
Chuchuf's Avatar
Or you could build a trey or soffit out of wood and drywall around the ducting, and then do the drop ceiling in the upper part.
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
Closed Thread Dedicated Theater Design & Construction
