DRYLOK and basement question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 09-11-2007, 12:26 AM - Thread Starter
v1rtu0s1ty's Avatar
Hi folks,
I would just like to know if it's safe to apply DRYLOK or any other product to seal walls and floors. I've seen good reviews on the product but I would like to know first if it's safe to apply it everywhere such as walls and floor and anything we think water might come in.
v1rtu0s1ty is offline
post #2 of 21 Old 09-11-2007, 06:07 AM
mbgonzomd's Avatar
It is certainly safe for concrete walls. I am not sure if it is designed for use on floors. Probably an epoxy based product is better for floors. If you are planning a subfloor (Delta Fl, Plankton, Dricore) then you do not need to paint the floor.
Gonzo
My Home Theater Odyssey
PSN: mule-tool
mbgonzomd is offline
post #3 of 21 Old 09-11-2007, 07:01 AM
Quoted: 3255 Post(s)
Liked: 2743
Drylock is safe to apply to walls. It says right on the bucket "not for floors"
Beware of which floor sealer you pick. A neighbors contractor used a solvent/spirit based sealer for their basement and they had to move to a hotel for two days until the odor went away.
It was so strong that when the contractor put some fans in the windows I could smell the solvent inside my house across the street. That is about 200 ft.
Another thing about DRYLOK and other similar products they work great in mitigating the humidity that enters a basement through the porous concrete walls . They also will stop a certain amount of leaking that a temporary excess build up of water that might occur.
But they will not solve fundamental drainage and ground water problems. Those have to be addressed first if you want a dry basement.
post #4 of 21 Old 09-11-2007, 07:18 AM
GreySkies's Avatar
Quoted: 618 Post(s)
Liked: 432
There is a Drylok that you can use on floors. I used it under my Dricore floor.
GreySkies is offline
post #5 of 21 Old 09-11-2007, 08:33 AM - Thread Starter
v1rtu0s1ty's Avatar
So far we have been very dry even during last 3 week's storm. It rained hard and continuous for 1 week. A lot of people in our area got flooding.
Thanks for the tips too.
post #6 of 21 Old 09-11-2007, 08:54 AM
dc_pilgrim's Avatar
Here is an old thread I had on this topic.
http://www.avsforum.com/avs-vb/showthread.php?t=795523
I can't remember the name of the product I wound up using. I was intruiged by the Kryton product mentioned, but couldn't source it locally and was on a timeline. With Drylock you need to consider if you have cement or masonry in your basement.
dc_pilgrim is offline
post #7 of 21 Old 09-11-2007, 09:47 AM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Drylok is a good product but I think the Ames product I used is far better. I used the block & wall it goes on real thick. Here is the link. http://www.amesresearch.com/basement...TJAodmzLk2w#bw
check out post #5 The Copper Fields Cinema
I ordered it and had it at my door in 2 days
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #8 of 21 Old 09-11-2007, 05:31 PM - Thread Starter
v1rtu0s1ty's Avatar
Thanks for sharing your experience. That helps a lot. How big did you cover? How many cans did you end up using?
post #9 of 21 Old 09-11-2007, 07:07 PM
mert70's Avatar
I used drylock for floors and it's working great. Look for the Low Odor type, it's 4 bucks more, but it is worth the money. I made the mistake of getting a gallon of the regular and had to keep all the windows in my house open for days.
mert70 is offline
post #10 of 21 Old 09-11-2007, 07:34 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
v1rtu0s1ty
I used two 5 gallon buckets on my walls I wanted it pretty heavy so that if my walls did crack again I hopefully wont spring a leak The ames folks are pretty helpful if you call them. They can tell you how much you will need
Scott
          Current Photo's
W00lly is offline
post #11 of 21 Old 09-11-2007, 08:47 PM
Remax's Avatar
I thought drylok is for cinderblock foundations only? I read it shouldnt be used on a poured foundation.
Remax is offline
post #12 of 21 Old 09-11-2007, 09:06 PM
Liked: 2743
From their product sheet:
"Latex Base DRYLOK Masonry Waterproofer is a low odor, ready-mixed masonry waterproofing paint. Specially formulated to waterproof interior, exterior, above or below grade masonry walls. Ideal for use on cinder and concrete block, poured concrete walls, stucco, brick, retaining walls, basement walls, birdbaths and fishponds."
It's been on my poured concrete walls for 12 years without a problem.
post #13 of 21 Old 01-22-2008, 08:08 PM - Thread Starter
v1rtu0s1ty's Avatar
EDIT: I'll just go with LATEX.
LATEX BASE DRYLOK® MASONRY WATERPROOFER
Latex Base DRYLOK® Masonry Waterproofer is a low odor, water clean-up formula for waterproofing all interior, exterior, above or below grade masonry walls, cinder and concrete blocks, stucco, brick, retaining walls, basements, concrete swimming pools and foundation. No pre-mixing or pre-wetting necessary.
* A masonry waterproofer paint
* Ready mixed
* Tintable
* Low Odor
* Non-flammable
* Guaranteed to stop water even under pressure
* Withstands 10 pounds of hydrostatic pressure, greater than a wall of water 22 feet high
* Clean up with soap and water
* Applies easily with brush and/or roller
* Complies with all current VOC and/or VOS
* 10-year Warranty
post #14 of 21 Old 01-22-2008, 09:26 PM
tradewinds's Avatar
Quoted: 12 Post(s)
So, a poured foundation can be coated with Drylock and then pad and carpet on top?
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #15 of 21 Old 01-22-2008, 11:31 PM - Thread Starter
v1rtu0s1ty's Avatar
I'll search other's thread. Thanks.
I'll go with latex. The smell isn't really that bad according to the description. Yes, you can apply it to poured concrete. They claim that they use it for swimming pools.
post #16 of 21 Old 01-23-2008, 06:28 AM
mbgonzomd's Avatar
Poured foundation walls, not floor.
Gonzo
PSN: mule-tool
post #17 of 21 Old 01-23-2008, 07:11 AM - Thread Starter
v1rtu0s1ty's Avatar
I'll contact DRYLOK later and ask about it. But I think it should work especially they mentioned swimming pools. They didn't mention swimming pool walls. But what about swimming pools that doesn't have any corners. Anyways, I'll keep you posted.
post #18 of 21 Old 01-23-2008, 07:20 AM
Fuzzybear50's Avatar
In my experience drylock is not for poured foundations but I guess you could put it on the walls for piece of mind, but IMO it is a waste of time.
I would concentrate more on moving water from the downspouts > away from the house.
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #19 of 21 Old 01-23-2008, 12:57 PM - Thread Starter
v1rtu0s1ty's Avatar
BADABING!!! BAMBAMBAM!!!
FYI...
Hello,
Thank you for contacting us. In regard to your question, we do not recommend using the DRYLOK Masonry Wateproofer on the floor as it is not designed to accept any kind of foot traffic or pressure and will begin to break down over time. The product that you want to use is a clear sealer called DRYLOK Concrete Protector with SaltLok. It is a penetrating sealer that will soak into the pores of the floor to stop the moisture and dampness from coming up through.
We recommend that the floor be bare, clean and dry. Apply one coat of the DRYLOK Concrete Protector to the floor, and it will seal up and solidify any powdering masonry as well as making the floor resistant to chemicals and spills, etc.
Apply one coat to the floor by brush, roller or sprayer. Allow the Protector to cure 6 hours for light foot traffic, 24 hours for normal traffic, and 48 hours
before painting over with a latex based paint or laying carpeting. Be sure the
air and surface temperatures are 50 degrees F or higher when applying. If the floor is too cold the product will not be able to cure and will not be able to form its waterproof seal.
post #20 of 21 Old 01-23-2008, 04:10 PM
mbgonzomd's Avatar
Nice work. That clears up any confusion.
Gonzo
PSN: mule-tool
post #21 of 21 Old 02-16-2008, 10:42 AM
slbhicks's Avatar
i have an home that is about 50yr old it has a celler door that leads to outside from family room down stairs. within that area there is cinder block walls which are starting to leak when it rains the cement walls are painted .my question is would drylok work for this problem and would we have to remove the paint
slbhicks is offline
