60" Plasma (~145lbs) Mounted into Brick - what type of fasteners are recommended? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-25-2007, 02:11 PM - Thread Starter
bkw
bkw's Avatar
Which fasteners are recommended for mounting something almost 150lbs into brick? Molly, Sleeve Anchors, Tapcon screws?
Mortar joints appear to be solid, and believe that the bricks are 3.5-4" deep (fireplace chimney).
Thanks!!
bkw is offline
post #2 of 5 Old 09-25-2007, 02:32 PM
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I think I would do the sleeve anchors
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #3 of 5 Old 09-25-2007, 05:20 PM
Max Lomax's Avatar
Six 3" Tapcons into the brick or the mortar will do nicely and require much smaller holes (less mess). Get the hex head type not the phillips. Will hold up a at least 500lbs.
Max Lomax is offline
post #4 of 5 Old 09-25-2007, 06:13 PM
deweylittle's Avatar
Recently went through this. Mine is a 50", just over 100#. I hung mine outside, on the backside of the fireplace, as part of an outdoor kitchen/patio upgrade. my brick is very soft and I had trouble getting the Tapcons to bite. i ended up going thru the veneer brick into the denser fire brick with 3/8*8" lag bolts. also filled the drilled holes with liquid nails before torquing the bolts in. still not satisfied, I tried to add a couple of wedge anchors, again into the fire brick, but they pulled out. finally, located some 8" strike anchors and was successful in getting them to hold. i think it's rock-solid now.
deweylittle is offline
post #5 of 5 Old 09-28-2007, 12:10 AM
jdohman's Avatar
Easy 500 pounds. I have had three guys hang off a bracket mounted like this. Not talking about skinny guys either.
jdohman is offline
