how to make speaker grills - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-04-2007, 11:37 AM - Thread Starter
mike_311's Avatar
I finished my basement and made a hollow box wall drywall finished with openings and shelves to hold my projection tv, front/center channels and subwoofer (under the tv) and also a component shelf. It turned out pretty good everything is flush with the face of the wall.
My problem is the cut out openings in the wall, I want to cover them with homemade grills, the front L/R speakers are fairly large so the openings are large and I have an opening for the subwoofer and center channel as well.
What is the best way to make grills. Initially I bought some audio grill fabric online and made wood frames but they just aren't doing it for me. It looks ok but I want a cleaner look.
The grills need to be white (frames and fabric), and the subwoofer grill circular, the others rectangular.
Any ideas?
"If the world didn't suck, we'd all fly off."
mike_311 is offline
