Insteon Lights Controlled By Harmony 880 - AVS Forum
post #1 of 20 Old 11-18-2007, 06:54 AM - Thread Starter
Digital Man's Avatar
Last year when I selected Insteon dimmers from Smarthome, I was convinced that they would have an IR to Insteon converter available real soon so I could control my lights with my Harmony 880 remote. Well they still don't have one, so unless anyone knows of definitive plans for one soon, I suppose I'll go with my backup plan. The backup plan is to use an IR to X10 converter, and run my Switchlincs in X10 mode rather than Insteon mode.
Can anyone recommend an IR to X10 converter, or a better solution to this problem?
Guy
Digital Man is offline
post #2 of 20 Old 11-18-2007, 09:48 AM
AccessHA's Avatar
Do you have a media center or PC in your theater? If so, you could use a USB-UIRT.
AccessHA is offline
post #3 of 20 Old 11-18-2007, 10:06 AM
Cathan's Avatar
I'm not at the point where I need to worry about intergrating Insteon with my remote. Assuming a native solution isn't available a year or so from now, I plan on going the PC route like AccessHA suggests. Sorry I can't be of much help on X-10 question.
Cathan is offline
post #4 of 20 Old 11-18-2007, 10:12 AM - Thread Starter
Nope, I don't have a media center pc. It's something I may add in a few years, but I would like a solution that doesn't require a pc.
I've done some more searching, and it looks like this might work:
http://www.smarthome.com/4040.html
Initially I just want something that will allow me to control my 3 lighting zones on Smartlincs individually. By that I mean if I could just dim one zone at a time that would be fine. Eventually I would like to set up lighting scenes, but that can come in the future.
Guy
post #5 of 20 Old 11-18-2007, 10:55 AM
YW84U's Avatar
Funny that this thread should come about when it did - I just ordered 3 swithclincs and a KPL for the HT last Thursday (20% off sale). I've waited for an IR/Intseon solution as well, but grew impatient - so I ordered the 4040 - IR X10 Command Console (IR543) to bridge the gap in the interim. I figured for $25 or so, it was an economical X10 way of achieving control with my 880 for the time being. I'm planning on using the KPL outside the HT to set up the various scenes for the dimmers, and control the KPL with the 880 via X10 to invoke the scenes I program manually.
I'll eventually migrate everything to to PC automation down the road. Haven't gotten a PLC or software yet - still in the research/homework stages on that part. I might opt to go Linux and use anything open-source that's available....(Bruce Winter's MisterHouse project over on Sourceforge looks interesting).
I think Bud (Chinadog), Swithey and ebr have deployed a similar setup in their builds as well. I was poking around the Harmony site last night, and can confirm that the 453 can be added as a device in your activities menu. I'll know more on Tuesday when the beloved FedEx man comes to pay me another visit
YW84U is offline
post #6 of 20 Old 11-18-2007, 11:49 AM
greg_mitch's Avatar
Guy
I've got one for use with my MX850. I have played with a little. It is called the IR543 I believe. I am still contemplating have a separate remote for just the lights (Insteon's RF remote) and another remote for all of the A/V equipment (MX850).
Yes it is this device you were referring to before.
greg_mitch is offline
post #7 of 20 Old 11-19-2007, 09:19 AM
Andy238's Avatar
Yep, the IR543 will do what you want. I had one in my last media room and I'm planning on using it again with a PCS Scenemaster controller in my new HT. I use a Pronto remote and it works nicely with X10. If you can do macros with your 880 you can do a pseudo scene thing by just sequentially sending the X10 commands.
BTW, you can get the IR543 for quite a bit less on the big auction house. Just search all catagories for "IR543".
Andy238 is offline
post #8 of 20 Old 11-19-2007, 10:49 AM
scaesare's Avatar
Ditto on the waiting for a Smarthome IR solution. It's been a year of waiting for me.
At some point I may consider the PC route, but problem is the Media Center PC in my room is typically off for most other activities, and having to fire it off just to do lighting control has some drawbacks IMO.
-Steve
scaesare is offline
post #9 of 20 Old 12-02-2007, 05:45 AM
chinadog's Avatar
Here's how I setup my X10 stuff with the 880. Hope it helps. I had a lot of questions when I was doing it, so I documented everything as best as I could.
Bud
chinadog is offline
post #10 of 20 Old 12-02-2007, 03:06 PM
ginigma's Avatar
I'm using a USB-UIRT and PowerHome for my setup, in my family room, not a true HT, but that's not important for this discussion. I've heard others had good success with the IR543, but I didn't want any X-10 signals on my powerlines.
Universal Devices is coming out with a new device which includes IR. I think it has "99" in the model name. I'll check the smarthome forum for a link.
http://www.techmall.com/topic.asp?TO...archTerms=99.9
There's nothing on the UDI web site yet, but they seem to be a good company with great support.
ginigma is offline
post #11 of 20 Old 12-03-2007, 07:21 AM
tradewinds's Avatar
Seems the SMST6 is discontinued. What replaced it? I need a on/off/dimmer switch that can be controlled via IR.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #12 of 20 Old 12-03-2007, 09:19 AM
chinadog's Avatar
You can use an Insteon controller since they speak X10. I haven't tried it personally, but should work.
Bud
chinadog is offline
post #13 of 20 Old 12-03-2007, 09:35 AM
tradewinds's Avatar
thanks....I guess my requirements are a bit more simpler...i.e. I just need a switch I can point my remote to and it will turn the light on-off and also dim. I don't really need X-10. Is there such a switch available?
post #14 of 20 Old 12-03-2007, 09:53 AM
chinadog's Avatar
chinadog is offline
post #15 of 20 Old 12-03-2007, 02:23 PM
aham23's Avatar
Originally Posted by chinadog View Post
Take a look at the Lutron Maestro.
http://www.homedepot.com/webapp/wcs/...f&ddkey=Search
Bud
this is what i was planning on doing in my HT. my thought is that i can just program my mx-900 to control the dimmer since it is IR. of course, i have been wrong before. later.
aham23 is offline
post #16 of 20 Old 12-03-2007, 04:13 PM
tradewinds's Avatar
Bud
Perfect!
post #17 of 20 Old 12-14-2007, 05:38 AM
tradewinds's Avatar
well, I got the Lutron Maestro and although it is exactly what I want, it produces a buzzing that will be a problem. Lutron sells a debuzzing thing that is $150 which is insane considering the Maestro only costs around $30.00.
What I read up it that this is known as filament buzzing. Does anyone know if there is a simpler cost effective way to reduce the buzzing.
(I'll post this in a new thread this is off topic)
post #18 of 20 Old 12-14-2007, 06:05 AM
Cathan's Avatar
Yes, exchange the bulbs for ones with a beefier filament.
Cathan is offline
post #19 of 20 Old 12-14-2007, 06:10 PM
chinadog's Avatar
Hmmm, never heard that before. Curious if Cathan's solution will work.
Bud
chinadog is offline
post #20 of 20 Old 12-14-2007, 06:56 PM
tradewinds's Avatar
beefier filaments? any ones you recommend. I thought they all look the same to me, but I have not really looked at filaments, paid more attention to wattage and lately have changed out all to CFL, had to locate the box with the incandescents.
User Tag List
