Bottom of column for sub and speakers..leave it plywood? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-21-2007, 09:34 AM - Thread Starter
rsprance's Avatar
Liked: 24
How should i place the speakers on the shelf in my columns?
Should the speaker shelf have some kind of material on it? Should the sub fire directly onto the plywood stage floor? I will be lining the inside of the columns with OC and stuffing with insulation but i wasnt sure if i should carpet / fabric the actual speaker shelves or area where the sub will fire.
rsprance is offline
