2nd row seat/riser photos please - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 84 Old 06-12-2011, 03:44 PM
premiertrussman's Avatar
Quoted: 17 Post(s)
is it sad scrolling through here that i recognize almost every single riser?
here mine for the fray
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
post #62 of 84 Old 01-30-2012, 09:00 PM
cybrsage's Avatar
Liked: 154
Here are some build pics of mine. No carpet yet, though. The two boxes on the top row and the rightmost box on the bottom row are for LED louvered lights. The other three boxes are for power. I cut holes through all the sections to prevent any of them from trapping air. The vents on the top are to allow air flow as well. I am using the riser as a broadband base trap while also ensuring it does not turn into a drum.
cybrsage is offline
post #63 of 84 Old 01-31-2012, 12:49 PM
go_habs's Avatar
Heres mine
Check out my HT Build!
http://www.avsforum.com/avs-vb/showthread.php?t=1379436
Check out my YouTube Channel (Theater tours,bluray reviews all things tech)
http://www.youtube.com/user/bigky226?feature=mhee
go_habs is offline
post #64 of 84 Old 01-31-2012, 05:24 PM
qx56's Avatar
1 foot tall
qx56 is offline
post #65 of 84 Old 02-26-2012, 02:50 PM
wvictor's Avatar
Anyone have information on building a base trap in to a riser? (pros/cons/examples) A local installer has recommended this for my room as opposed to a in-wall sub or free standing sub.
-> Invisibill's Home Theatre Project
wvictor is offline
post #66 of 84 Old 02-27-2012, 08:00 PM
cybrsage's Avatar
Liked: 154
A bass trap is to trap and remove the excessive bass build up which happens in corners. It is not a bass built into the riser.
cybrsage is offline
post #67 of 84 Old 05-19-2013, 06:16 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
What is the ideal amount of riser for the second row ? (and third? )
Mfusick is offline
post #68 of 84 Old 05-19-2013, 07:10 PM
Brad Horstkotte's Avatar
Liked: 73
Check the riser height calculator sticky at the top of this forum
Brad Horstkotte is offline
post #69 of 84 Old 05-23-2013, 08:19 PM
iamjason's Avatar
Quoted: 31 Post(s)
curious how much the risers are costing? we are building a house in a new development and they have an option for a riser - 4" tall and 6'x12' for $542 - i like the idea of having one less thing to do but i have never built out a room - my existing theater was here when we moved in. is it worth the cost to have them do it or should i do it my self -
iamjason is offline
post #70 of 84 Old 05-24-2013, 04:23 AM
Spaceman's Avatar
Quoted: 45 Post(s)
Liked: 150
That price isn't too bad, but I think you'll find that a 4" riser is too low and at 6' deep, not really deep enough for reclining theater seats. Also, it most likely will have a single layer of decking and will lack insulation. Unless you have your room layout already done and can calculate the correct riser height for the builder, I'd wait and DIY. If you plan on ripping out the builder carpet and putting in a special carpet for the theater, I'd definitely DIY the riser. If you plan on soundproofing the room, you need to wait and build the riser after your soundproofing efforts.
FYI-My riser costs are lumped in with my stage and mini riser costs, so I don't know for sure how much the riser cost by itself. I can tell you all three came to $730 before carpet, so I'm guessing I spent about $450 for a 13"x8'x12-1/2' riser, including 2 steps. It has a 2x12 perimeter with 2x8 joists, 2 layers of 3/4" osb decking and is filled with insulation.
Spaceman is offline
post #71 of 84 Old 05-30-2013, 06:25 AM
iamjason's Avatar
Quoted: 31 Post(s)
i need to find out more details about how it is built - not sure about the carpet - i may just match it with the builders - i will be building a stage as well so doing it my self may be the way to go -
iamjason is offline
post #72 of 84 Old 05-31-2013, 12:54 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
On of the things I am playing with- is do I want it all carpet or should I accent the carpet with stained and finished wood around the edges ?? More work and cost but I think it looks nicer.
For those that did- or did not- any feedback ?
Mfusick is offline
post #73 of 84 Old 05-31-2013, 07:57 PM
iamjason's Avatar
Quoted: 31 Post(s)
i think i will diy - my current one is 12"x6'x8' - the 12 in height is needed to clear my front row - and the 6 ft lets me recline with out issue -
thanks for the help!
iamjason is offline
post #74 of 84 Old 07-23-2013, 03:05 PM
linkseo's Avatar
Liked: 25
Technically not "RISERS". more like "platform" close enough:rolleyes:
I had limited ceiling height so I purchased the rialto backrow riserless theater seats which are 8 inches taller then the front. they get the job done great but i noticed my "shorter" guests look a tad uncomfortable getting off and on. some had to do a tiny hop LOL. So i built this platform which is 4 inches tall to accommodate them. Add a strip of led lights and presto! Problem solved smile.gif
linkseo is offline
post #75 of 84 Old 12-08-2013, 07:47 AM
bigbadbob's Avatar
So I am contemplating building a two-tier riser for the Man Cave. I will have a 4" and another 4" to 6" on top of that. It's in my basement and looking for suggestions on construction design. I will have one Clark Synthesis under the smaller, 4" riser and two Clark Synthesis transducers under the larger riser. I will be building it out of 2 x 4's and 2 x 8's or 2 x 10's. I was considering putting Auralex U-boats underneath. Will this help/hurt the vibrations of the transducers? Riser will be covered with pad/carpet. Smaller riser will have a couch with the second row, upper level, individual theater seats and the third row will be bar stools.
Any help, comments, suggestions, concerns appreciated.
RG
1redss likes this.
Klipsch Rocks!
bigbadbob is offline
post #76 of 84 Old 02-10-2014, 11:55 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
BIG what are the dimensions for that riser?
wraunch is offline
post #77 of 84 Old 02-22-2014, 10:17 AM
bigbadbob's Avatar
The riser is 26' wide and 20' deep.
Klipsch Rocks!
post #78 of 84 Old 10-30-2014, 07:55 PM
prophets92sho's Avatar
I lil late.
http://www.avsforum.com/photopost/sh...p?photo=336984
Sony Pearl... Optoma BX-AL133 Anamorphic LensOppo83bdpDenon 2309ci 7.2 AV receiver.Sony PS3.Center channel: Klipsch Heresy.Front L/R: Klipsch Heresy.Subwoofers: B&W AWS 650 and NHT Supersub.Rear Surround L/R: Klipsch RS3.Side Surround L/R: Klipsch KSC-C1.
prophets92sho is offline
post #79 of 84 Old 09-17-2016, 09:17 AM
mrcoop's Avatar
Quoted: 38 Post(s)
Liked: 53
reserect..Built a riser similar to audioholics suggestion. Didnt do much for bass trap but the tactile response is very impressive!
ID:	1666073   Click image for larger version
ID:	1666081   Click image for larger version
ID:	1666089   Click image for larger version
ID:	1666097   Click image for larger version
mrcoop is offline
post #80 of 84 Old 10-17-2016, 08:42 PM
MUTTS's Avatar
Quoted: 44 Post(s)
Liked: 38
Just finished and got carpeted. Basically stole everything from this thread as far as construction. Hope you like it.
MUTTS is offline
post #81 of 84 Old 10-18-2016, 05:31 AM
Spyderturbo007's Avatar
Quoted: 201 Post(s)
Liked: 80
Here is mine. We just finished it on Sunday. My knees are still sore from crawling around on the OSB all day long.
It's 10 3/4" tall and uses Big's design of a 2 x 10" perimeter and 2 x 8" stringers. It's filled with R-13 insulation and covered with 2 layers of 3/4" T&G OSB with some 30lb roofing felt sandwiched in between.
Spyderturbo007 is offline
post #82 of 84 Old 08-02-2017, 09:43 AM
Quoted: 52 Post(s)
Liked: 3
Nice details and pics. I have a dumb question: Why fill the riser with insulation? Is it for soundproofing for lower floor or a base trap?
My HT is in the basedment so there is no one below the room. Should i still fill the riser with insulation?
Harana is offline
post #83 of 84 Old 08-03-2017, 05:41 PM
schmidtwi's Avatar
Quoted: 231 Post(s)
Liked: 171
Second time I posted this tonight, but This is a good thread.
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #84 of 84 Old 08-03-2017, 07:55 PM
Quoted: 3898 Post(s)
Liked: 3333
The insulation keeps the riser from resonating and allows you to use the riser as a bass absorber.
