Wire fish: Exterior wall, between floors? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 01-04-2014, 10:17 AM
msick's Avatar
Unfortunately, I've had no luck there. I have a separate furnace/ac system for the upstairs. The equipment for the bottom 2 floors is in the basement, and the equipment for top floor is in the attic. The vents for the lower system are in the drop ceiling of the room with the equipment. AFAIK, there is nothing that runs from the basement to the top floor (HVAC-wise). Plumbing hasn't been much help yet either, but I will keep looking.
I may just pull the baseboard and carpet and run the cable a few inches out from the wall and through a hold in the floor to take advantage of what I've already cut. At least I know the drop will be in the right location.
msick is offline
post #32 of 34 Old 01-04-2014, 01:34 PM
Quoted: 3255 Post(s)
Liked: 2743
How does your basement furnace vent exhaust gas? Usually up through the roof. Maybe it is electric?
post #33 of 34 Old 01-04-2014, 03:36 PM
msick's Avatar
It actually routes through the dropped ceiling in that room and terminates outside the top of the wall below the first floor.
msick is offline
post #34 of 34 Old 01-04-2014, 05:17 PM
Liked: 2743
well how about something outside the house, you wouldn't be the first.
