Show Us your rope lighting - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 228 Old 01-23-2008, 09:28 PM - Thread Starter
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I am about to order my rope lighting for my soffet tray that I am about to build but I'm at a loss as to what color to choose. Lets see some pics of everyones rope lighting
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #2 of 228 Old 01-24-2008, 04:50 AM
dc_pilgrim's Avatar
Blue LED rope from 100bulbs.com
dc_pilgrim is offline
post #3 of 228 Old 01-24-2008, 05:05 AM
mbgonzomd's Avatar
Liked: 29
This is soffit design:
Blue Led light:
Unfinished room:
Pretty much finished room
Gonzo
My Home Theater Odyssey
PSN: mule-tool
mbgonzomd is offline
post #4 of 228 Old 01-24-2008, 06:14 AM
Guru's Avatar
Here:
Blue LED light from Ebay (no one else had 50 foot runs in 12 v for less)
Dan
Guru is offline
post #5 of 228 Old 01-24-2008, 06:30 AM
huntrm's Avatar
Blue has a good look/feel - I like it. Anyone on this thread install blue, then went to white? Not sure if I'm 100% committed to blue.
huntrm is offline
post #6 of 228 Old 01-24-2008, 06:33 AM
ChipWV's Avatar
This is the cheap incandesent rope light from Lowe's.
Hope this helps
Chip
A dumb man gets into trouble and doesn't know how to get out of it.
A smart man gets into trouble and knows how to get out of it.
A wise man never gets into trouble... Spastic Bat Theater Thread
ChipWV is offline
post #7 of 228 Old 01-24-2008, 07:16 AM
dc_pilgrim's Avatar
Gonzo went white to blue. Check his thread.
Woolly - did you PM Sleeks to add this to the sticky?
post #8 of 228 Old 01-24-2008, 07:20 AM
indianrider's Avatar
I am building my HT room currently. Do I need to run the rope lighting on a low voltage transformer?
indianrider is offline
post #9 of 228 Old 01-24-2008, 07:27 AM
sleeks's Avatar
I just saw the thread. I'll add it to the sticky. The resources in this forum never cease to amaze me.
-Brian
sleeks is offline
post #10 of 228 Old 01-24-2008, 07:34 AM
dc_pilgrim's Avatar
You can do it either way, although low voltage (12v) transformers sometimes humm. I used a grafik eye dimmer, which will dim rope light which is line voltage (120v). Be aware, that a G-E (presumably other dimmers too) need a certain minimum wattage to work, which can be an issue with LED rope of shorter distances. My run is about 35-40 feet, and about 0.8w per foot, dims fine.
Incandesant rope by its nature will use more electicity, and thus won't be an issue in shorter runs. I prefered LED to take a heat source out, plus its nifty.
EDIT - to answer questions below w/o further cluttering a picture thread:
I am not a GE expert, clearly, I didn't know the GE could do low-voltage, presumably w/a transformer. I went line voltage since I saw a discussion that it would work with the GE (maybe it was the transformer specifically).
Nifty - is in that it is cool to the touch and won't generate heat, that it should be long lived w/o bulbs going, that it is newer technology, and more efficient - but the operating costs would probably never be recovered by the upfront cost.
post #11 of 228 Old 01-26-2008, 12:56 AM
Minhas's Avatar
I have rope light in my family room, living room, and theater. All bought from Birddog.
Family room (same color in living room)
Theater:
Minhas is offline
post #12 of 228 Old 01-26-2008, 05:41 AM
aham23's Avatar
so how about a rope light 101 for dummies (me ) class?
how does one wire it up? do i need an outlet in my soffit or just tie it into a wall switch?
i would like to run some down the soffits on both sides of my room.
thanks.
aham23 is offline
post #13 of 228 Old 01-26-2008, 06:34 AM
ccapozzoli's Avatar
I did LED lighting for my steps and my stage steps. I will post pics later. However to wite them up is no big task. I got the 12V low voltage version and I wored them up to a transformer, which BTW does not have to be big becasue they LV LED's only draw .84 watts per foot. Then I wired the transfornet to a switch which will be controlled via a creston systems.
I bought my lights from noveltylights.com, but I think they are all the same. when you buy them, they add on a 2 foot wip at teh end of the rope lighting so you can wire it up.
I also know you can buy them with a plug ready to go. It just depends on how you want and control them.
ccapozzoli is offline
post #14 of 228 Old 01-26-2008, 08:24 PM - Thread Starter
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Anyone with amber rope lighting
Scott
          Current Photo's
W00lly is offline
post #15 of 228 Old 01-26-2008, 10:18 PM
videocam's Avatar
Blue from Walgreens Christmas clearance :-)
Amazing DJ likes this.
-Cam
Television Photojournalist, Video Producer, Voice Over Artist
Cam Communications Cinema Palace Construction Thread
Cam's Whole House AV and Automation Thread
LOGANED! 4-30-08
videocam is offline
post #16 of 228 Old 01-26-2008, 11:10 PM - Thread Starter
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
I just ordered clear. we will see how that looks. My HT is going to be pretty dark and even more so when I do the star ceiling with fidelio so I am hoping the clear will help with that.
Scott
          Current Photo's
W00lly is offline
post #17 of 228 Old 01-29-2008, 07:18 AM
Stylz's Avatar
I am in the design process of building my basement HT and want to use rope lighting. Since my ceilings are low, what would be the minumum gap distance I could get away with, with it still looking great. As anyone experimented with different distances from the ceiling?
Stylz is offline
post #18 of 228 Old 01-29-2008, 10:22 AM
rutlian's Avatar
I have a red rope lights in placed around my hometheater ceiling but I don't have a soffit or anything to hide it, I'd love to cover them but I am avoiding a soffit due to my ceiling height and I am thinking of crown moulding but don't know where to start. Need help for what size and is it safe to put a crown moulding close to the rope lights? the diagram below is this gonna work? the vertical line represents the wall. sorry for the drawing.
Rope light.doc 19k . file
Peter
Enjoy HD no matter what......
rutlian is offline
post #19 of 228 Old 01-29-2008, 10:48 AM - Thread Starter
W00lly's Avatar
Quoted: 51 Post(s)
Liked: 73
Rutlian
I think that would work out fine I plan to do something similar. The rope light can sit right on the wood it really does not give off much heat
Scott
          Current Photo's
W00lly is offline
post #20 of 228 Old 01-29-2008, 11:45 AM
rutlian's Avatar
Rutlian
Thank you scott, and sorry for hijacking your thread. I was gonna put up another thread for my inquiry but put it here instead, I know you wont mine.
I have another question. Do you think a wood glue will be strong enough to hold the moulding? I plan to attached the moulding to the wood about 1'' thick and 2'' deep and then glue it to the drywall I have doubts doing it that way maybe you or anyone here can suggest how to attached it the wall.
Thanks again,
Peter
rutlian is offline
post #21 of 228 Old 01-29-2008, 01:29 PM
Fuzzybear50's Avatar
I never knew there was such a big price variation between the incandesent rope light and the LED lights........they definitely want a pretty penny for longer runs.
Beer is the answer! What is the question?
Fuzzybear50 is offline
post #22 of 228 Old 01-29-2008, 01:34 PM
bass addict's Avatar
Quoted: 366 Post(s)
Liked: 442
Thanks again,
I am going the exact same route. I don't have a sofit( I currently have crown molding up) and was just going to build a combination between yours and gonzo's to hide the rope lighting.
I would definitely recommend nailing it to the wall (I'd actually use nails and glue). Just go pick up a finish nail gun and have at it.
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #23 of 228 Old 01-29-2008, 01:59 PM
dc_pilgrim's Avatar
I saw your drawing above and did something similar, albeit on a soffit, not the wall.
My crown attached to 1x1 wood, then my side soffit - all with a combination of liquid nails (glue) and brad nails. I also added a piece of molding to the bottom of my crown, essentially hiding the bottom surface of my 1x1, and making the "crown" bigger.
Here is the finished two piece crown (some of the molding needs to be glazed, which makes it easier to see the pieces)
post #24 of 228 Old 01-29-2008, 02:02 PM
Dark_Wizard's Avatar
That's why others and myself went for the cheaper Lowes lights...had to cut some costs.
Dark_Wizard is offline
post #25 of 228 Old 01-29-2008, 02:40 PM
Quoted: 366 Post(s)
Liked: 442
For my riser/stage lighting I bucked up and spent the extra money for the LED's. I just liked the extra piece of mind of the cooler bulbs. For the ceiling I am going to go with incan. as the heat shouldn't be an issue in that area, not to mention it is a lot longer run so the cost savings are significant. 1000 bulbs has incan. runs for very little money.
post #26 of 228 Old 01-29-2008, 02:42 PM
rutlian's Avatar
Dave,
Thanks for sharing that's absolutely perfect. And very nice too and the double moulding to cover the 1x1 is a great idea. Many thanks now I can start with my project.
Peter
rutlian is offline
post #27 of 228 Old 01-29-2008, 02:47 PM
Actually I did get LED's for my riser as well and from Lowes and they were very reasonable. I am using incan in the soofits as well so looks like we are both doing the same thing.
BTW, my incan lights are the blue xmas ones from Lowes....
post #28 of 228 Old 01-30-2008, 06:14 AM
Don_Kellogg's Avatar
I don't have them turned up much in this picture, probably two clicks on the Lutron 3506 dimmer. I'll try to get a better shot later today.
"Anyone who lives within their means suffers from a lack of imagination."
Don_Kellogg is offline
post #29 of 228 Old 01-30-2008, 09:51 AM
P_Og's Avatar
Are all rope lights 'dimmable'? Or should I be looking for a special kind?
"-They should project the movies on Cartman's a$$.
-Yeah, that would be like IMAX."
P_Og is offline
post #30 of 228 Old 01-30-2008, 09:54 AM
dc_pilgrim's Avatar
I know in another thread some people had issues dimming LED rope light from costco, might have been hit or miss. I haven't seen any dimming issues with incandescent.
