DIY A/V rack? - Page 9 - AVS | Home Theater Discussions And Reviews
 8Likes
post #241 of 263 Old 08-18-2014, 10:01 AM
j2048b's Avatar
Originally Posted by 1080eyes View Post
It is a wood frame. One of the ideas I'm kicking around, is a inside the frame friction fit.
Another is Velcro.
Not familiar w friction fit?
U can always use a drill bit and line it up w the covers holes, and drill the hole out then place heli coils in the holes that matxh the screw threads so u can always take the screws in and put without damaging the wood,
Or use "L" brackets from the inside and mount the covers onto the "L" brackets as well?
Velcro may work well too!?
Sent from my iPP using Tapatrash
j2048b is offline
post #242 of 263 Old 09-05-2014, 09:13 PM
Liked: 0
Originally Posted by krakhen View Post
Hey Guys!
Using some ideas from folks like PMeyer and others, as well as from commercial pull-out designs I began planning for my rack enclosure. It will be in the HT Room's back left corner and my objective is to be able to somewhat easily check cables and connections because there is no access to the back from another room.
Hey, i know its been a while, but did you end up building this setup?
Yogi_76 is offline
post #243 of 263 Old 09-05-2014, 09:29 PM
Newshoundaussie's Avatar
My homemade rack with self closing tray for laptop.
ID:	248674   Click image for larger version
ID:	248682   Click image for larger version
ID:	248690   Click image for larger version
Newshoundaussie is offline
post #244 of 263 Old 09-05-2014, 11:09 PM
j2048b's Avatar
Nice man! Great job!
j2048b is offline
post #245 of 263 Old 10-09-2014, 01:06 PM
tlb48's Avatar
who makes the av rack
tlb48 is offline
post #246 of 263 Old 10-09-2014, 05:17 PM
wkearney99's Avatar
Quoted: 136 Post(s)
Liked: 77
Didja miss the 'homemade' part?
I'm guessing they're some soft-close drawer slides?
Nice look.
wkearney99 is online now
post #247 of 263 Old 11-04-2014, 11:22 AM
lemonslush's Avatar
Quoted: 408 Post(s)
Liked: 105
What are Heli Coils?
lemonslush is offline
post #248 of 263 Old 11-04-2014, 11:25 AM
lemonslush's Avatar
Quoted: 408 Post(s)
Liked: 105
Originally Posted by design1stcode2nd View Post
I'll have to take some shots with a flash but here is the concept. I have one more shelf to add which will make it harder to see the speaker wire in the cable D-Rings on the left.
In hindsight I would have painted the "door" frame before I wrapped it.
You use any special hinges for that or something simple at HD?
post #249 of 263 Old 11-04-2014, 12:27 PM
cw5billwade's Avatar
Quoted: 259 Post(s)
Liked: 153
Originally Posted by YW84U View Post
I opted to DIY it by using double-tab adjustable shelving rails with plywood shelves painted black. Used some split loom tubing from the auto parts store to corral the cabling . Total for parts somewhere around ~$60.00
I'm almost done; working on fitting the last few panels this week.
Hope it gives you some options/ideas!
Cheers,
I stole Tom's idea but no face plates
inside media room I made sort of an L shape wall shelves along with the double-tab adjustable shelving rails these 2 shelves are permanente location the others are flexable attached with screws on the shelf suports to prevent tiping foward.
hope this helps
Bill
PS my power center on top shelf gives a nice look with room lights out
cw5billwade is online now
post #250 of 263 Old 11-05-2014, 10:53 AM
design1stcode2nd's Avatar
Quoted: 20 Post(s)
Liked: 37
Just standard dark, door hinges from HD. I did have to mount them to some 1/4 ply that I painted black to get it to line up and install easily.
lemonslush likes this.
Play like a Raven
design1stcode2nd is offline
post #251 of 263 Old 11-05-2014, 12:11 PM
lemonslush's Avatar
Quoted: 408 Post(s)
Liked: 105
sounds great. Now I just need to decide if I want to copy what you did to cover my existing rac which sits in a cubby that I made shelves in. Or wall up that cubby and do the inwall rack like many others on here have. Great ideas in this thread, its been very helpful. Thank you.
post #252 of 263 Old 11-05-2014, 01:43 PM
Potatogod93's Avatar
Quoted: 26 Post(s)
hope this helps
Bill
How much weight can those shelves seem to hold?
Potatogod93 is offline
post #253 of 263 Old 11-05-2014, 04:24 PM
Quoted: 259 Post(s)
Liked: 153
The L shaped shelves I put nailers on the wall and the left and right side. I can sit on them if I want. The other shelves about 30 lbs give or take probably more
post #254 of 263 Old 11-06-2014, 03:08 PM
Liked: 0
I have a CNC plasma table that I use for various projects. Do you think there would be much of a market for custom front plates?
RadarVector is offline
post #255 of 263 Old 11-23-2014, 10:40 AM
lemonslush's Avatar
Quoted: 408 Post(s)
Liked: 105
I finished my rack. I built a wall, put a hole in another wall (after finishing the room). I need to make the trim plates, kinda getting hung up here.
What type meterial did you guys use? I got some MDF chalk board but I have to cut it with my skill saw and the lines are not coming out so perfect. I was thinking try to use something thinner that would cut with a razor knife maybe?
post #256 of 263 Old 12-20-2014, 01:40 PM
Liked: 0
Thanks for all the great inspirations. Time to get started on mine
Adflash is offline
post #257 of 263 Old 02-10-2015, 12:05 PM
Searl6542's Avatar
Sound escape
For those who used the adjustable shelving (which I'm leaning towards doing!) how do you prevent or reduce sound from leaking out from where you cut the hole in the wall? Is the sound escaping minimal so it's no big deal or you don't really worry about it?
Searl6542 is offline
post #258 of 263 Old 02-10-2015, 05:21 PM
Quoted: 14 Post(s)
Liked: 1
My simple DIY
IamCornholio is offline
post #259 of 263 Old 02-10-2015, 05:50 PM
Quoted: 259 Post(s)
Liked: 153
Mine is not in my theater room just outside in billiard room
post #260 of 263 Old 02-14-2015, 10:32 AM
Searl6542's Avatar
Thanks for the feedback! I'm guessing most must do that type of setup with the open back in separate rooms.
post #261 of 263 Old 02-15-2015, 06:56 AM
Quoted: 259 Post(s)
Liked: 153
some put the open rack in their media closet but have the equipment in room. If you do that then you need to sound proof the media room as well. other wise you may as well not bother with soundproofing the theater since you just put a huge hole in it.
post #262 of 263 Old 02-15-2015, 03:33 PM
Searl6542's Avatar
Right! I was thinking if I went with the open back I would either build a closet behind that wall with the system enclosed or create a door from the theater side in front of the equipment. The door would be as thick/dense as the DD with weather stripping around it so when it's closed it would be pretty airtight.
post #263 of 263 Old Today, 06:15 AM
Quoted: 259 Post(s)
Liked: 153
either method would work
