My New Theater - Version 2.0! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 1361 Old 06-09-2008, 08:00 AM - Thread Starter
mn_hokie's Avatar
Jason, 3 cups of coffee and 45 minutes later and I've read from beginning to end this morning. Great job! Thanks for posting record of all your work. I noticed on several occassions you felt like you were talking to yourself. I feel that way too. I'm sure you weren't though.
I love the color scheme!
tony
Tony,
Thanks for the comments. I was actually enjoying your thread last night. Glad to see you back at it From the number of views, it looks like a lot of these threads get viewers, but most don't post to them. Thanks again for doing so.
mn_hokie is offline
post #152 of 1361 Old 06-09-2008, 09:37 AM - Thread Starter
mn_hokie's Avatar
As promised, here are pictures of the completed riser. The cover on the step is just temporary, as I'm planning on using an actual stair tread.
mn_hokie is offline
post #153 of 1361 Old 06-09-2008, 12:12 PM
scottyb's Avatar
Quoted: 29 Post(s)
Ooooo, Ahhhhhhh.
scottyb is online now
post #154 of 1361 Old 06-09-2008, 12:16 PM - Thread Starter
mn_hokie's Avatar
mn_hokie is offline
post #155 of 1361 Old 06-17-2008, 01:19 PM - Thread Starter
mn_hokie's Avatar
For those showing the love - more pics to come this week!! (I promise).
I just got off of the phone with the carpet company. We have an install date set for July 7th, which gives me a few weeks to finish the paint, trim, and doors. We figured we needed a deadline to bump ourselves into high gear
mn_hokie is offline
post #156 of 1361 Old 06-19-2008, 08:16 AM - Thread Starter
mn_hokie's Avatar
Got the first coat of brown suede paint on the bottom of the walls last night. You roll on the first coat with a foam roller, which pulls the paint up off the wall to give it texture. The second coat is done with a 3" brush, basically painting a hatch pattern to create the suede effect.
The colors are actually darker than they appear in the pictures. Red always seems to throw off the processing on the photos for some reason.
mn_hokie is offline
post #157 of 1361 Old 06-19-2008, 08:34 AM
kezug's Avatar
I like the color scheme...looking good.
kezug is offline
post #158 of 1361 Old 06-19-2008, 08:52 AM
mplant1's Avatar
nice
mplant1 is offline
post #159 of 1361 Old 06-19-2008, 09:03 AM
scottyb's Avatar
Quoted: 29 Post(s)
Jason,
I like it except your divider line is kinda crooked. I think it would look better if it was straight.
post #160 of 1361 Old 06-19-2008, 09:23 AM - Thread Starter
mn_hokie's Avatar
Scotty,
It's the camera. The ends tend to tilt in when at the wide angle setting. we'll be placing chair rail as a divider though.
mn_hokie is offline
post #161 of 1361 Old 06-19-2008, 09:43 AM - Thread Starter
mn_hokie's Avatar
Thanks for the replies guys. It's good to get the comments (keeps me motivated).
I need some opinions on an issue that will be hitting me very quickly. Please see the below image:
This is a mock up in MSPaint of the wall with the cabinets and equipment rack. The cabinets are recessed into the wall, and I will be installing a Mid-Atlantic rack next to the door. I color coded all of the trimwork to help explain the issue:
Baseboard = Dark Blue
Chair Rail = Red
Casing = Yellow
Here's my issue. The gap between the bottom of the rack and the top of the cabinets isn't that big, so one piece of trim will span the distance. I was initially thinking of running my chair rail from the stage to the EQ rack, as shown in the picture. I could then run vertical casing on both sides of the cabinet to butt up to the chair rail. The right side opening for the cabinets isn't entirely in line with the EQ rack opening. There's maybe an inch or less between the two. If I'm lucky, I can do one piece of casing (as shown) to cover the entire vertical and bring everything back in line.
My biggest concern is how the EQ rack trim will meet the chair rail. If I use standar casing, won't it be thicker than the top reveal of the chair rail? Has anyone run into this yet?
mn_hokie is offline
post #162 of 1361 Old 06-19-2008, 09:45 AM
mplant1's Avatar
dude-
Did you design backgrounds for NES games back in the day??? I KNOW I have seen this before...
mplant1 is offline
post #163 of 1361 Old 06-19-2008, 09:58 AM
SatelliteGuy's Avatar
Your theater is looking great!
Rinker Family Cinema Construction Thread:
http://www.avsforum.com/avs-vb/showt...ghlight=Rinker
SatelliteGuy is offline
post #164 of 1361 Old 06-19-2008, 10:34 AM - Thread Starter
mn_hokie's Avatar
Thanks. I just checked out your thread. I like the hidden comm room idea.
mn_hokie is offline
post #165 of 1361 Old 06-19-2008, 10:59 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Looking good Jason,
As far as the rack, maybe case the bottom as well. You can stop the chair rail before the rack. To make it look more symetrical you can also cut the casing on the right side to make it the same as the left. Then add a small piece of chair rail between the racks casing and the doors casing. Good luck.
oman321 is offline
post #166 of 1361 Old 06-19-2008, 11:00 AM - Thread Starter
mn_hokie's Avatar
Looking good Jason,
The only down side to that is that I'd have a mix of casing and chair rail across the top of the cabinets. Not sure how that would look. It may end up being the lesser of two evils.
mn_hokie is offline
post #167 of 1361 Old 06-20-2008, 11:30 AM
Elite Pro-FHD1's Avatar
Great work, nice theatre.
Lakers
Dodgers
Broncos (I know)
XboxLive Gamertag: SUPREME22
Elite Pro-FHD1 is offline
post #168 of 1361 Old 06-20-2008, 11:38 AM - Thread Starter
mn_hokie's Avatar
mn_hokie is offline
post #169 of 1361 Old 06-20-2008, 11:59 AM
scottyb's Avatar
Quoted: 29 Post(s)
Originally Posted by mn_hokie View Post
Scotty,
Jas,
You should know me by now. It was a joke.
post #170 of 1361 Old 06-27-2008, 07:50 AM - Thread Starter
mn_hokie's Avatar
Originally Posted by scottyb View Post
Jas,
I know. Just messin with ya
mn_hokie is offline
post #171 of 1361 Old 06-28-2008, 08:13 AM
shaneotool's Avatar
Looking great so far
Nice colors and design - looking forward to seeing the finished product
I like to watch video and listen to audio.
shaneotool is offline
post #172 of 1361 Old 06-29-2008, 08:34 PM - Thread Starter
mn_hokie's Avatar
Thanks again for the comments guys. After a week long vacation with the family in the black hills, it was back to work on the theater. With carpet going in on the 7th, I still needed to:
- finish painting
- install cabinets
- install doors
- install trim
Here are a few shots of this weekend's progress.
First, a shot from the top of the stairs:
A shot from the hall. Theater entrance is on the left:
Back wall of the theater with 2nd coat of suede paint complete. I also painted the frame of my rear speakers black to blend better:
First coat of black paint in the equipment room. I'll be installing a mid atlantic rack in the opening:
mn_hokie is offline
post #173 of 1361 Old 06-29-2008, 09:31 PM
broconne's Avatar
I like the color choices - Needs a bit more burnt orange in the room however
A/B Pre-Build Thread
broconne is offline
post #174 of 1361 Old 06-29-2008, 09:38 PM - Thread Starter
mn_hokie's Avatar
HA! Thanks.
mn_hokie is offline
post #175 of 1361 Old 07-01-2008, 09:15 AM - Thread Starter
mn_hokie's Avatar
Major Bonehead Move!!!
My doors came in, and I realized I made a severe error when ordering. I could have sworn that my 3 hall doors were framed for a 36" door, and the equipment closet was framed out for a 24" door. For whatever reason, I woke up this morning thinking the equipment room door was wrong. I went down and measured and was fuming when I discovered it was only 20" wide. I called Menards to see what I could do about exchanging the door for an 18" one and paying a restocking fee, but they don't offer any type of return on a special order, so I'm stuck with it.
Just to be sure, I remeasured the 3 hall doors. I couldn't believe it when the mechanical room rough-in was only 34 3/4" inches. The framer did his job right; I just should have remeasured instead of doing the "I'm pretty sure about this" when ordering the doors. Lesson learned there.
If anyone in the Minneapolis area needs some new doors, please let me know
mn_hokie is offline
post #176 of 1361 Old 07-01-2008, 09:34 AM
In2Photos's Avatar
Ouch! That sucks!
Mike
In2Photos is offline
post #177 of 1361 Old 07-01-2008, 09:50 AM - Thread Starter
mn_hokie's Avatar
mn_hokie is offline
post #178 of 1361 Old 07-01-2008, 11:09 AM
tomdahlberg's Avatar
http://minneapolis.craigslist.org
Keep up the good work man, looking forward to the carpet install
tomdahlberg is offline
post #179 of 1361 Old 07-01-2008, 11:44 AM - Thread Starter
mn_hokie's Avatar
Thanks Tom. I actually have an ad up on CL already no hits as of yet.
mn_hokie is offline
post #180 of 1361 Old 07-06-2008, 06:52 AM - Thread Starter
mn_hokie's Avatar
After ordering 2 more doors, it was time to install the two that fit. I'm satisfied with the result, but considering the amount of time I spent on the doors, I'm thinking of leaving this task to the pros the next time around.
I also decided to change the design a little while painting. Initially, I was going to go with an oak chair rail along the wall. The plan in the hallway/lobby area was to simply have the red and brown meet to form a straight line. I ultimately decided to have a 3" black band seperating the colors, which I feel really ties the columns together along the side wall.
Here's another shot of the back wall. The black rail really pulls in the color of the in-walls as well.
Cabinets are now installed in the recessed area along the right wall.
And finally, a shot of the flooring that is going in the laundry area across the hall from the theater:
With carpet coming tomorrow, today is all about getting the trim installed. We spent the early part of the weekend staining skirt boards, door and cabinet casing, and baseboard, so all that's left today is to cut and hang it. I'll also need to get the door frames stained after adding some oak to the inside of the theater framem to increase the depth of the jamb for the double drywall.
More pics to come......
mn_hokie is offline
