Small Theater Build Threads - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #91 of 332 Old 10-01-2008, 07:25 PM
HT_SoulMan's Avatar
I've subscribed to quite a few threads posted by participants of this one. Now if I can find a good small theater seating thread...
HT_SoulMan is offline
post #92 of 332 Old 10-02-2008, 06:41 AM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
SoulMan,
You can start one - I'm sure there are others that have the same concerns.
Ray
Ray
"Listen with an open heart and mind."
cavchameleon is offline
post #93 of 332 Old 10-02-2008, 06:16 PM
quicksilver02's Avatar
Here's my living room theater. It's 12.5' x 18'. Just finished getting it carpeted yesterday.
quicksilver02 is offline
post #94 of 332 Old 10-02-2008, 06:45 PM
scottyb's Avatar
Quoted: 18 Post(s)
Nice what size screen are you using and who makes it?
scottyb is offline
post #95 of 332 Old 10-02-2008, 08:26 PM
It's a 115" wide 2.35:1 screen. I use a Panamorph UH380 to stretch the image to fit. I bought SmX material and built the screen myself. I don't use the "acoustically transparent" feature of the screen in my setup, but I'm very happy with it.
post #96 of 332 Old 10-02-2008, 08:59 PM
hokie93's Avatar
Lookin' good. What brand are those chairs?
hokie93 is offline
post #97 of 332 Old 10-02-2008, 10:30 PM
They are Berkline 090's. I'd like to have a matching second row, but I already had the couch which has the benefit of seating 3.
I got them through Roman at Ultimate Home Entertainment, who I'd highly recommend dealing with.
post #98 of 332 Old 10-03-2008, 09:31 AM
HT_SoulMan's Avatar
Nice.. Even the fireplace looks like it hasn't been used.
post #99 of 332 Old 10-03-2008, 12:50 PM
HT_SoulMan's Avatar
Originally Posted by cavchameleon View Post
SoulMan,
Ray
started one.. http://www.avsforum.com/avs-vb/showthread.php?t=1072359
post #100 of 332 Old 10-03-2008, 12:54 PM
That's because it hasn't! The entire room was gutted and redone.
post #101 of 332 Old 10-05-2008, 01:33 AM
Quoted: 194 Post(s)
Liked: 219
Great! I'll check it out, I'm also interested!
Ray
Ray
post #102 of 332 Old 10-05-2008, 08:33 PM
huntrm's Avatar
Here's mine, 12x15 with double doors in the back. Tight space, likely putting in one row of seats or a large L-shaped sofa for family of 5. Materials used:
- two layers of 1/2in drywall with greenglue
- 1 in linacoustic on back wall, and along the sides slightly above sitting ear level
- polybatting above up to the soffits
- two sets of corner bass traps on back wall
- wrapped in storebought, local fabric (black and brown) - using 1in furring strips to hang
- installed Grafik Eye 3104 with fourzones (two sets of can lights, one rope light, and side sconces)
- Will eventually put in projector with 92-100in screen
Build thread can be found here:
http://www.avsforum.com/avs-vb/showthread.php?t=990548
huntrm is offline
post #103 of 332 Old 10-11-2008, 04:51 AM
Tedd's Avatar
Quoted: 926 Post(s)
Liked: 339
One of Theo's designs:
http://www.soundandvisionmag.com/ins...-theaters.html
(the second theater in the article...)
Tedd is offline
post #104 of 332 Old 10-11-2008, 12:25 PM
Bujee1's Avatar
Wow!
We have a celebrity in our midst.
Post more pictures please. The one shot doesn't do it justice!
120" Electric Motorized Remote Projection Screen Movie Projector Black Matt 16:9, Elite Screens R115WH1-WIDE ezFrame Fixed Projection Screen (115" 2.35:1 AR)(CineWhite), Onkyo TX-NR616 7.2-Channel THX Select2 Plus Certified Network A/V Receiver(Black), Klipsch Reference Series R-1650-C In-Wall/In...
Bujee1 is offline
post #105 of 332 Old 10-11-2008, 01:40 PM
jamis's Avatar
Nice carpet.
jamis is offline
post #106 of 332 Old 10-15-2008, 08:57 PM
tenebros's Avatar
tenebros is offline
post #107 of 332 Old 10-17-2008, 06:55 AM
htnutz's Avatar
My small theater is still under construction, as can plainly see.
Room size: 15’ x 12’ 9” with 8 foot ceilings.
The screen is 110". Painted wall, Behr Silver Screen.
Looking at buying 5 Berkline 88 seats; two rows of seats. 2 seats in the front row and 3 seats on the riser.
He’s a link to my thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1075974
My 3 Plus years build.....
The Scrapwood Theater
htnutz is offline
post #108 of 332 Old 12-12-2008, 08:31 PM
Chuck1906's Avatar
My room is 15 x 17. Screen is 106". Seats 5 comfortably plus 2 more at the dinette table. Did all the work myself except carpeting for the stage and riser and electrical.
Chuck1906 is offline
post #109 of 332 Old 12-13-2008, 04:41 PM
MountainAsh's Avatar
I love the idea of a thread dedicated to "small" rooms... we just need to define small.
I use to think my theater was on the large side at 14'2" x 22' x 8'2" but compared to so many theaters on this forum, mine is on the small side. Especially when you factor in my height limitation; 5' of left side is only 7'2" due to HVAC chase. Also, since I wanted all or most of my seats to meet THX specs., I have limited seating to 6.
I think any criteria should include a minimum of HxWxL. If one of those dimensions is lacking, you have to work around things. We could possible include seating capacity as well.
Dave
MountainAsh is offline
post #110 of 332 Old 12-13-2008, 08:47 PM
victor-eyd's Avatar
I'd say any width or length dimension which is 14' or less would define small. I would not include height as most pjs out there can accomodate for a low ceiling configuration
Viuctor
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #111 of 332 Old 12-13-2008, 09:10 PM
mjg100's Avatar
Mine is a room right off of our master bedroom. It used to be an exercise room. The room is 11'-5" wide by 13'-4" deep. I am really liking the image and sound in this small room. I am using a Planar PD7130 and a 106" fixed frame screen. Seating is just for two or three. For sound I am using a Denon 3300 as a pre/pro and a six channel Kenwood amp for the power. The speakers are RBH WM-30's and a NHT sub. I placed the equipment in the a mechanical room and controlling it remotely. I did not do a build thread. I just took a few pictures afterwards.
www.avsforum.com/avs-vb/showthread.php?t=1092659
mjg100 is offline
post #112 of 332 Old 12-14-2008, 07:00 AM
koach's Avatar
koach is offline
post #113 of 332 Old 12-28-2008, 09:28 PM
FHT123's Avatar
Bump...mine is going to be 12 x 14....i need more ideas, keep posting guys!
FHT123 is offline
post #114 of 332 Old 01-07-2009, 05:18 PM
rutlian's Avatar
Mine is 13'x20'x7.5' like others I was inspired by a lot of HT owners here, Our hometheater is not as luxurious like others but I am very happy with it, just recently added acoustic panels and very happy with the results, again before building the acoustic panels I did a tremendous research on this forum before finally doing it.
this Forum ROCKS. Next project will be replacing the carpet.
Peter
Enjoy HD no matter what......
rutlian is offline
post #115 of 332 Old 01-07-2009, 09:51 PM
mn_hokie's Avatar
Liked: 27
Love the panels. Can you tell a huge difference now that they're in?
mn_hokie is offline
post #116 of 332 Old 01-07-2009, 10:18 PM
griffin_hr's Avatar
Mine definitely qualifies for the "small" theater, it's 10.5' x 18'. I am in the process of building it now. I keep thinking I am getting close, but then I start to think about it and there is SOO much left to do before I can truly say it's finished...(not sure that will ever be the case though.)
Here is a link:
http://www.avsforum.com/avs-vb/showthread.php?t=1100666
Thanks for looking.
griffin_hr is offline
post #117 of 332 Old 01-08-2009, 02:02 PM
rutlian's Avatar
Thank you. Yes big difference, I should have done long time ago. I plan to put more in the back maybe cover the whole door with panel and maybe upper corners.
Love your HT, it is one the nicest. I Love your posters. and the sconces they are really cool.
Peter
rutlian is offline
post #118 of 332 Old 01-27-2009, 09:00 AM
Bujee1's Avatar
Hey guys,
I'm building an ultra small theater (10x11ft, it's a bedroom) and I want to put my components in the closet. Can I just push my open rack into the closet or should I think about something enclosed? I'm going to take the doors off and cover the opening with curtains. Will that be enough ventilation?
Any of you done this before?
Bujee1 is offline
post #119 of 332 Old 01-27-2009, 09:10 AM
mn_hokie's Avatar
Liked: 27
Thanks for the kind words. I'm actually going to be putting up a couple of Chameleon frames over the next few weeks (one on the side wall and one on the back wall) so I'll have to let you know what my ears think
mn_hokie is offline
post #120 of 332 Old 01-27-2009, 09:12 AM
mn_hokie's Avatar
Liked: 27
Originally Posted by Bujee1 View Post
Hey guys,
You should have no problem with an open rack. It's really just cosmetic at that point. As far as ventilation, you'd probably want a more sheer curtain to allow the heat to pass through. The downside to this of course is that you'll be heating your theater via the rack so it could get a little toasty in there with everything running. Do you have the ability to vent the closet from the rear?
mn_hokie is offline
