Small Theater Build Threads - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #181 of 332 Old 07-04-2009, 06:55 PM
victor-eyd's Avatar
That theater is awesome!
I really really need to clean up my ht!
Victor
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #182 of 332 Old 07-06-2009, 09:17 AM
budk's Avatar
Add my little theater to the list.
It's only 10 x 21 x 8 but it has all the goodies.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #183 of 332 Old 07-16-2009, 02:16 PM
Big Ave's Avatar
Here's my first theater, 14'X16.5' on 100" BOC...
Big Ave is offline
post #184 of 332 Old 07-20-2009, 02:35 AM
mjfoster77's Avatar
Well I'm still in the planning stages of building a dedicated theater in my unfinished basement. The dimensions are 13 ft x 19 ft. the ceiling is 9 ft. but there is duct work.
Here is a shot looking into what will be the theater:
basement long view
I was wondering, and I hope this is the right place to ask, would it be beter to enclose the duct work, or lower the ceiling to 8 ft. I ask this because I want to do sofits with rope lighting in the room. Will it look weird if I keep the ceiling at 9ft and build around the duct work and still have sofits around the room with lighting. I haven't really noticed any theaters that had this dilema. Any advise is greatly appreciated. I'll look for some better pics of the duct work.
xbox live:sixsec assassin
mjfoster77 is offline
post #185 of 332 Old 07-20-2009, 03:12 AM
Sherardp's Avatar
I never started a dedicated HT thread here, room is 14x22x8.5. More pics in my sig line.
Click the link to see pics of my home theater
http://s450.photobucket.com/albums/q...oom/?start=all
Sherardp is offline
post #186 of 332 Old 09-02-2009, 07:30 PM
victor-eyd's Avatar
post #187 of 332 Old 09-03-2009, 03:56 PM
yamahaSHO's Avatar
My build is currently going on.... 11.5' x 24'
The "Z" Family Theater
-Jason
The "Z" Family Theater - Almost "complete".
-Not your average sub build
-Klipsch Sonosub Build
SONY quality and customer service FTMFL
yamahaSHO is offline
post #188 of 332 Old 09-09-2009, 06:30 PM
mjg100's Avatar
Not a very good pictures, but I will post any way. Click on link labeled "Upstairs dedicated room" at the bottom of this post. Room is 11'-5 1/2" wide x 13'-5 1/2" deep with 8' ceiling. I have 12 sound panels and four bass traps in the room. The screen is 106" fixed frame. My equipment is remote mounted, so I only have speakers and projector in the room. Sound is very good in this room and since the speakers are all crossed at 100Hz, I have good headroom and dynamics. I did all of this on a tight budget and am using the following equipment:
Planar PD7130 DLP projector
HK 254 AVR
Kenwood 6 channel amp (125 wpc)
PHD 205 ATSC, NTSC & QAM tuner
Nady XA1100 (1,100 watt pro amp)
Behringer CX2310 crossover
Toshiba HD DVD player
Five RBH WM30 speakers (have 2 more if I decide to go 7.2)
6.3CF ported Shiva-X subwoofer (uses one channel of Nady XA1100)
2.0 CF sealed sub using two 10" NHT drivers (uses one channel of Nady XA1100)
Three 1.0 CF sealed subs using 10" NHT 116 drivers and 115 watt plate amps. (I cross my mains to these subs using the CX2310 covering 30Hz to 150Hz overlapped mains. Mains are crossed at 100Hz to free them up so that they have increased head room.)
Seating is an old leather love seat.
Up coming room changes:
1. Grills (on order) for small subs at front of the room.
2. Build and install AT screen (sample on order) and place center channel behind
screen.
3. Change theater seating to 4 rocker theater seats or 3 leather theater chairs.
Probably wait until Christmas for this.
Updated:
I know have my AT screen in place and grills on my front subwoofers. Here is the build thread for screen conversion: http://www.avsforum.com/avs-vb/showthread.php?t=1180610
Other than chairs I think I am done for awhile.
I guess you are never done. I added top and bottom horizontal masking to my screen using cable and pulleys so that the masks move together. Here is a picture with masking set to 2.40.
[IMG][/IMG]
Here is the same picture over exposed so that you can see the masking. You can see the sound panels behind the screen.
[IMG][/IMG]
Close up picture of the masking. Picture over exposed to show masking.
[IMG][/IMG]
mjg100 is offline
post #189 of 332 Old 09-23-2009, 07:52 AM
maxposure's Avatar
Here is a link to my small theater build.
Converted an old dining room. Size is 10x15
http://www.avsforum.com/avs-vb/showthread.php?t=1181959
maxposure is offline
post #190 of 332 Old 09-23-2009, 08:33 AM
cpotteke22's Avatar
Here's mine, approx. 10x16'. Eventually I'll be re-doing the drop ceiling, and installing new carpeting.
cpotteke22 is offline
post #191 of 332 Old 10-13-2009, 08:08 PM
Bujee1's Avatar
Finally finished my "man cave".
By bujee1, shot with DSC-H1 at 2009-10-07
It's a small room (10x11) with two drop down screens (1.78:1 and 2.35:1) and a 52" flat screen. the ps3, A2 HDDVD, XBOX 360 and my computer can be viewed on either screen and the TV.
120" Electric Motorized Remote Projection Screen Movie Projector Black Matt 16:9, Elite Screens R115WH1-WIDE ezFrame Fixed Projection Screen (115" 2.35:1 AR)(CineWhite), Onkyo TX-NR616 7.2-Channel THX Select2 Plus Certified Network A/V Receiver(Black), Klipsch Reference Series R-1650-C In-Wall/In...
Bujee1 is offline
post #192 of 332 Old 10-13-2009, 08:53 PM
inphoenix's Avatar
Originally Posted by ashcurrie View Post
Room Dimensions: 11ft x 15ft
Projector: Panasonic PT-AE3000E
Fronts: B&W 685's
Centre: B&W HTM62
Backs: B&W 686's
Cable: QED Silver Anniversary XT
Sub: REL T3
AV Reciever: Denon AVR-1909
BLu-Ray: Denon DVD-1800BD
Games Consoles: PS3 60GB, XBOX Premium 60GB
Media Reciever: Macbook Pro running Plex.
Cheers, Adam.
Great job! I am kinda in same situation as you. I have a 11x18 room that I am planning to convert into HT. I have couple of questions for you. When you open the door, does it not hit the speakers? I will be in same situation and I am thinking of moving the door by few feet or mirror the seating. Ideally I would like my screen by the entry door.
Also, how many inches is your screen from floor?
If anyone else wants to help out a noob here is my thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1187062
inphoenix is offline
post #193 of 332 Old 10-18-2009, 04:16 PM
vigga's Avatar
Here is mine:
Room is 12x12 with a JVC-RS25 projector.
For full details see my theater page:
http://www.avsforum.com/avs-vb/showt...ighlight=vigga
vigga is offline
post #194 of 332 Old 10-20-2009, 06:51 PM
Bujee1's Avatar
Originally Posted by vigga View Post
Here is mine:
Nice room!
Everything you need. Nothing you don't. How do you manage the light from the window?
Bujee1 is offline
post #195 of 332 Old 10-23-2009, 07:01 AM
vigga's Avatar
Originally Posted by Bujee1 View Post
Nice room!
This picture was obviously taken during the day - as you can see there is a little bit of light coming in through the window. The blind are heavy wood, and the drapes are thick so when both are closed the room is pretty dark - sports and such are no problem. For the most part this is a "night time" theater.
vigga is offline
post #196 of 332 Old 10-23-2009, 07:13 AM
Nightbreed's Avatar
My room is well and truley on the way. it's 11.5' x 18.5'
Aussie Art Deco Cinema
Nightbreed is offline
post #197 of 332 Old 12-22-2009, 01:14 AM
victor-eyd's Avatar
David Susilo's "Akung Theater" 10x16
http://www.avsforum.com/avs-vb/showthread.php?t=1207804
John H's 13x21 "Theater for one"
http://www.avsforum.com/avs-vb/showthread.php?t=1187347
Qluber's 12x13 theater/man cave
http://www.avsforum.com/avs-vb/showthread.php?t=1205963
Victor
post #198 of 332 Old 12-23-2009, 04:30 PM
robber616's Avatar
My bedroom 12x13
126 "16:9 bw carada screen
epson 8500 ub
robber616 is offline
post #199 of 332 Old 01-19-2010, 10:12 AM
mjg100's Avatar
[quote=mjg100;17150394]Not a very good pictures, but I will post any way. Click on link labeled "Upstairs dedicated room" at the bottom of this post. Room is 11'-5 1/2" wide x 13'-5 1/2" deep with 8' ceiling. I have 12 sound panels and four bass traps in the room. The screen is 106" fixed frame. My equipment is remote mounted, so I only have speakers and projector in the room. Sound is very good in this room and since the speakers are all crossed at 100Hz, I have good headroom and dynamics. I did all of this on a tight budget and am using the following equipment:
HK 254 AVR
Behringer CX2310 crossover (currently not being used.)
Three Klipsch RB-35's across the front and two RBH WM-30's for surround (5.1).
Three 1.0 CF sealed subs using 10" NHT 116 drivers and 115 watt plate amps. All speakers crossed to mains at 100Hz.
I changed the front wall. I am now running three Klipsch RB-35's across the front. I built a couple stands to raise them up so that they match the center channel speaker. Center speaker height was determined by the masking panel in upper position (viewing wide screen movies). Here are pics of the new mains.
Left Main
[IMG][/IMG]
Right Main
[IMG][/IMG]
When the new Pro-10's come out I plan on switching the front three to those. I want to see what the 10" pro drivers in the Pro-10's can do for HT.
mjg100 is offline
post #200 of 332 Old 01-19-2010, 06:19 PM
BFI6603's Avatar
Thought I'd post my small Home theater build.
BFI6603 is offline
post #201 of 332 Old 01-19-2010, 06:58 PM
plasmawatcher25's Avatar
Here's mine. We moved and I had to set up the theater as soon as possible. The theater in my old house was only 9 X 11. This is a little bigger at about 14 X 15 but I think that still qualifies as a small Home theater.
I plan on replacing the painted screen and replace the sheet I have hanging that covers the opening in my wall with something nicer. Not that fancy but we love it.
plasmawatcher25 is offline
post #202 of 332 Old 01-19-2010, 07:13 PM
Dex41's Avatar
Dex41 is offline
post #203 of 332 Old 01-28-2010, 08:31 PM
Originally Posted by Dex41 View Post
Here is mine....
http://www.avsforum.com/avs-vb/showthread.php?t=1218436
Very nice!
post #204 of 332 Old 01-28-2010, 09:01 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Vigga, what brand/colour is that green paint? looks great.
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #205 of 332 Old 04-04-2010, 08:28 AM
Nethervue's Avatar
Redid a bedroom into a small media room. HD70, 92" matte white screen, PS3, Expressvu HD, and HTIB which sounds quite good (in DTS) in a small room like this. Here are some pics, sorry for the subpar quality!! Since the pictures, I have added wall mounts for the back speakers so the can be angled downwards a bit. Cheers!
Nethervue is offline
post #206 of 332 Old 04-04-2010, 03:23 PM
luelf21's Avatar
Heres mine. Room is 13'(w) x 15'(d) x 8'(h)
luelf21 is offline
post #207 of 332 Old 04-09-2010, 03:36 PM
TRXHooL's Avatar
Hello
This time the current images of my little home cinema. The room is 16sqm big / small!
Facilities:
Projector: Sanyo Z5 black
Screen: Celeton Cinetec WS-S 1.2
AVR: Denon AVR 2808
BD: Denon DVD 2500 BT
SAT: Arion AF-4000 HDCI
LS Front: 2x 950 Canton Karat
LS-Center: 1x Canton Karat CM 51
LS-Rear: 4x Canton Karat R 4 dipole
Sub: 2x Nemesis BR2 - BMS 12S330 DIY Subwoofer
Subamp: Behringer CX 2310 + APart Champ one!
Cable: LS-> Summer Meridian 240, High Line, HDMI-> Gold Cable High Line, current-> Exclusive HD 1.5
Absorber: 7cm Basotect
in planning:
VPR A behind-the-subwoofer, the ceiling absorbers on the frame and suspended from the ceiling. In addition, behind the rack are two Helmholtz resonators planned. The side walls are to get even absorber.
Greetings TRXHooL
TRXHooL is offline
post #208 of 332 Old 04-09-2010, 06:28 PM
spyder696969's Avatar
Liked: 123
(Lots of pics)
Post = 1.5 images per sqm! LOL.
spyder696969 is offline
post #209 of 332 Old 04-10-2010, 06:28 AM
TRXHooL's Avatar
Well, yes! One should recognize, too little!
Greeting TRXHooL from Germany
TRXHooL is offline
post #210 of 332 Old 05-16-2010, 07:46 PM
Remington5183's Avatar
Hi guys!
Here is my partially complete theater:
http://www.avsforum.com/avs-vb/showthread.php?t=1249907
Please take a look and let me know what you think.
Remington5183 is offline
