Lighting Plan for Home to optimizing 3DTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-26-2010, 09:25 AM - Thread Starter
fkiller's Avatar
Hi, it's my first thread ever!
I'd like to talk about environment where 3DTV will be placed.
A main idea came from 3D TV experience in Sony Style, Philadelphia. I and my wife wore 3D glasses and got experienced that whole room was totally BLINKING. I turned around and finally found the source of blinking, which was fluorescent lamp on the top of Blu-ray shelf.
Then, I've just realized that to convert my AV life into 3D is not only to purchase 3D TV, but also to consider that my living room equips suitable lightings.
I think that regular light bulb also can't be a perfect choice, because of a nature of AC(alternating current).
Anyone has an idea for this? Does any light company announce such product?
fkiller is offline
post #2 of 9 Old 03-26-2010, 04:32 PM
peter0328's Avatar
Quoted: 48 Post(s)
Standard light bulbs are what you should use. Fluorescents or CFLs are the worst. I recommend GE Reveal brand lol.
Of course you should also have the lights OFF when you are viewing anything on your HDTV....
peter0328 is offline
post #3 of 9 Old 03-29-2010, 10:31 AM - Thread Starter
fkiller's Avatar
Thanks for replying peter0328.
I'm thinking that lighting system with DC(Direct Current) converter would be the best choice for 3DTV Environment. Most standard bulb can work with DC, and it will have theoretically no blinking at all.
Also, I'd expect that Europe should have even more problem with this, because their electricity is 50hz, which is not match with 120hz/240hz display rate.
fkiller is offline
post #4 of 9 Old 03-29-2010, 10:35 AM
Lee Stewart's Avatar
Liked: 51
Europe uses 100Hz and 200Hz, compared to our 120/240Hz. They even use 400Hz versus our 480Hz.
Their frame rate is based on 25 versus our 24. Power is 220V versus 120V for the USA
Lee Stewart is offline
post #5 of 9 Old 03-29-2010, 12:14 PM - Thread Starter
fkiller's Avatar
Thanks, Lee. It's something that I didn't know.
However, I'm still not sure that same multiples could eliminate every uncomfortable especially from light source. Is there any study or research for this? I really wonder how much portion of uncomfortably is coming from light.
I went to SonyStyle in King of Prussia, last Sunday, tried 3DTV, and still got dizziness when I watched for 30 mins.
fkiller is offline
post #6 of 9 Old 03-29-2010, 12:22 PM
Liked: 51
Remember - the wiring in your home is shielded. The main culprits for affecting 3D performance will be Flouresent lights and Incandescent bulbs on a dimmer which supposedly can interfere with IR signals.
IMO, one cause of ghosting - as it relates to power - could be a ground loop issue because they do affect the image in 2D, so it will be worse in 3D
post #7 of 9 Old 03-29-2010, 02:25 PM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
My lighting plan is to turn off all the lights and close the blinds (lol).
jbug is offline
post #8 of 9 Old 03-29-2010, 02:48 PM
Steve P.'s Avatar
That's the best plan, and is what those of us who have had field sequential 3-D setups have done for years. I usually even wait for dark!
Steve P. is offline
post #9 of 9 Old 03-29-2010, 06:01 PM
peter0328's Avatar
Quoted: 48 Post(s)
This is also my plan for movie and tv viewing. For gaming (Project Natal) I'll probably need the lights on so I'm not falling onto things lol
Reply 3D Displays
