3D on Samsung 1080p DLP with Mitsubishi 3DA-1 and no Gefen - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1111 of 1136 Old 06-16-2012, 06:42 PM
makav911's Avatar
I flashed my edid sometime ago, just recently when I switch to the 3d channels with DirecTV the screens looks distorted (same picture split in half, from left to right), I reset it by turning off the 3da1 and then the the screen goes to normal again, my 3da-1 was built in 2010, anyone have any ideas? ill try connecting the adapter directly to the tv as its currently connected thru a switch...never had issues before until recently, I'm hoping it may be the adapter that's bad or the DirecTV receiver
makav911 is offline
post #1112 of 1136 Old 06-16-2012, 07:10 PM
larrylwill's Avatar
Quoted: 29 Post(s)
I have the 3DA1 Oct 2010 never flashed anything but I had the exact same problem last week. but got first just snow, then fooling around I got a split screen left/right with another block across the bottom. I reset the 3Sa1 a couple times and finally reset the Direct TV then turned off the Tv and it finally straightened out. I have no idea what cause or fixed it. So you are not alone.
larrylwill is offline
post #1113 of 1136 Old 06-17-2012, 09:35 AM
makav911's Avatar
thanks for the quick reply, well that makes me feel more at ease, cause its not my adapter nor the receiver, I think it was due to the update DirecTV did a few months back....I get the same issues u described with the square box on the bottom and split screen, I reseted my receiver, left the adapter off all night n it seems its working ok for now....also what settings are u currently using such as picture options size widetv or widepc in 3D? and color gamut I use sRGB....
my other settings are dynamic, contrast 100: brightness 41: cool1....
makav911 is offline
post #1114 of 1136 Old 06-17-2012, 10:07 AM
larrylwill's Avatar
Quoted: 29 Post(s)
Well I turned on a 3D station on the direct tv to get you the answers and it was split screen with the bottom bar section again. So I reset the TV, still the same. Tuned off the DTV and when it came back on it was ok. So it looks like we have to reset the Direct TV every time now..
Anyway These are my settings for 3D only: :
Mode Dynamic
contrast 100
Brightness 55
sharpness 75 greyed out
color 55 greyed out
tint G50/R50 greyed out
detailed settings greyed out.
Picture options - Color Gamut Wide
3D effect Mode 1
everything greyed out.
Source HDMI3 / PC
post #1115 of 1136 Old 06-17-2012, 10:53 AM
makav911's Avatar
heads up, I called directv, they told me to go to settings on my receiver under display , video, and turn off native to "off" as it tends to distort the 3d pic according to them, so they told me to try for 24 hours and if that doesn't work they'll replaced the receiver, just Wld need to pay for s/h $19.99,, haha I'm def gng to speak to the mngr, cause I sldnt have to pay for a defective unit....ill keep u posted....
update: forgot to mention, no issues yet....
makav911 is offline
post #1116 of 1136 Old 06-17-2012, 11:07 AM
larrylwill's Avatar
Quoted: 29 Post(s)
I set mine also, Ill let you know.
post #1117 of 1136 Old 06-17-2012, 11:25 AM
makav911's Avatar
additional update, I'm having no issues when I flip to 3d channels however if u try to schedule and record a 3d program at least for me it records it all distorted....so it might be the reciever that need replacement...who knows..
if u can, try recording somethin currently showing in 3d while ur watching the standard channels and then go to ur list and see how it recorded
makav911 is offline
post #1118 of 1136 Old 06-17-2012, 11:35 AM
larrylwill's Avatar
Quoted: 29 Post(s)
I set it to record a 3D show then went back to a standard show to watch then went and looked at the 3D recording and I got the same as before. I don't think its the recording I think its the same problem. Resetting the DTV off/on straightens it out.
post #1119 of 1136 Old 06-18-2012, 07:01 AM
makav911's Avatar
yep you're right, reset fixes the problem so ill try to get a replacement from DirecTV, will post on status when I receive it..
makav911 is offline
post #1120 of 1136 Old 06-18-2012, 09:20 AM
larrylwill's Avatar
Quoted: 29 Post(s)
If yours is bad then mine is also bad, doubtful especially since both of ours started at the same time. I believe its software updates. Besides its no big deal to turn the power off then back on with the remote. and most likely when newer software comes down it may get fixed or get worse. What Model do you have? I have a HR22. Although if you can get a HR24 as a replacement then you are way ahead. My biggest complaint is how slow the HR22 is and the biggest complaint is only 50 season pass spots, tivo is unlimited.
post #1121 of 1136 Old 06-22-2012, 04:03 PM
makav911's Avatar
I believe they fixed the issue with a recent update, check under menu, settings and software sld read 0x5d2, came out Jun 20th, seems folks were getting 1080i drop out issues, check it out and let me know, I haven't had issues since
makav911 is offline
post #1122 of 1136 Old 06-22-2012, 07:20 PM
larrylwill's Avatar
Quoted: 29 Post(s)
Yes I got it, and yes it appears to be fixed.
makav911 likes this.
post #1123 of 1136 Old 07-19-2012, 06:15 AM
Butmuncher's Avatar
Hi,
I'm in need of a 1080p mitsibishi dlp's edid that supports checkerboard, i'd be very greatfull if somebody could make me a edid overide, i'd make it myself but i can't find a edid and for some reason with my 670's monifo crashes to red screen.
Need one preferably from a 3dvision certified dlp with checkerboard
Thanks if you can and no worries if you can't
Edit
Issue now sorted
Bugged Interleaved/checkerboard lg forum thread, please add your names.http://www.avforums.com/forums/lg-fo...-lg-3dtvs.html
Butmuncher is offline
post #1124 of 1136 Old 10-19-2012, 10:16 AM
jayoldschool's Avatar
Quoted: 13 Post(s)
I was an early adopter of the Mitsubishi adapter for my Samsung DLP. The early method where I flashed the EDID of the TV. It used to work perfectly. Still works with my satellite box, actually. However, I haven't used it with my PS3 for awhile, and can't get it to work with my 320GB PS3 (and it worked fine with my old 60GB fat going through a Pioneer VSX 918). The new PS3 goes through a 3D ready Pioneer VSX 521. No matter what I do, when I run the display options setup on the PS3, it won't recognize that I am connected to a 3D display. I have the tv on the correct HDMI 3 input, and the tv allows me to select 3D mode. The Mits adapter powers on automatically with signal. I have tried running HDMI from the PS3 through the AVR to the Mits to the TV, and directly from the PS3 to the Mits to the TV.
I'm really stumped here. It used to work perfectly on the old PS3. I only used it for games, but it worked fine through the old non-3D Pio 918. Today I wanted to watch Prometheus, and it should work fine through the Pio 521.
I'm open to ideas!
jayoldschool is offline
post #1125 of 1136 Old 10-30-2012, 06:43 AM
Quoted: 13 Post(s)
Bump for our DLP 3D friends...
post #1126 of 1136 Old 11-02-2012, 07:34 AM
knobby's Avatar
does anyone know how to change color and other settings in 3d mode on hlt56 model.they are blacked out .thanks
knobby is offline
post #1127 of 1136 Old 01-26-2016, 09:21 AM
ctreesh's Avatar
Is there any youtube video showing the full procedure to flash the edid on a Samsung TV set to make it work with the Mits 3d adapter?
Or better yet, is anyone willing to sell me a pre-programed gefen that I could just drop in and make this work?
I already have a working mits adapter, but not the samsung model.
I likely dont have the correct video card, or the software, or access to a real mits edid, or the odd vga to hdmi programming cable....it all seems very difficult, and Id rather pay someone to flash it for me, or just build the geffin box to make my tv work in 3d.
Any takers?
ctreesh is offline
post #1128 of 1136 Old 01-26-2016, 09:37 AM
ctreesh's Avatar
Any takers?
Reguarding the ps3...try this...
hook the ps3 directly to your 3d input of your adapter, skip the avr. see if it recognized 3d and set up the screen size. Play something in 3d. (netflix has some 3d flix on it, or some game).
Then unhook and try again. Once the ps3 sees a workign 3d setup, it will remember it until you do a video setup auto detect again.
ctreesh is offline
post #1129 of 1136 Old 01-26-2016, 07:26 PM
Augerhandle's Avatar
Quoted: 763 Post(s)
Liked: 660
Any takers?
Via a simple reset, the EDID restrictions are removed from the 3DA-1 adapter, allowing it to work with Samsung DLP 3DTVs.
1. Power off the adapter (leave everything plugged in and connected)
2. Press and hold the 3D Mode button then press and hold the Power button
3. Observe the 3D status light until it blinks. You want it to blink once, if it blinks twice (5 seconds apart) then restart at step 1.
4. After you get the unit to blink once, release the Power button then release the 3D Mode button.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #1130 of 1136 Old 01-27-2016, 05:28 AM
ctreesh's Avatar
W H A T ?
Really?
ctreesh is offline
post #1131 of 1136 Old 01-27-2016, 06:45 AM
ctreesh's Avatar
W H A T ?
Really?
Wow, this totally worked! Thank you so much!
3da1's can be had for under $200 on ebay easy. The 3dc-100s units are way over $400 if you can even find one. Turns out they are the same box in every way with this trick.
ctreesh is offline
post #1132 of 1136 Old 01-27-2016, 09:55 AM
Quoted: 763 Post(s)
Liked: 660
wow, this totally worked! Thank you so much!
yw
ctreesh likes this.
post #1133 of 1136 Old 12-22-2016, 08:46 PM
3D_Shinobi's Avatar
I need help flashing my edid on my samsung cannot register powerstrip anymore
3D_Shinobi is offline
post #1134 of 1136 Old Today, 08:11 AM
jlseagull's Avatar
Unhappy
Can anyone here help me with this issue as well? After taking note of this thread for years and years, I finally got a good deal on a 3DA-1 starter kit, and when I went to EnTech to purchase a Powerstrip registration and request the EDID module, and it is now no longer available to purchase a license from them.
I emailed them about wanting to purchase a registered version and they said it was not for sale, and that they would not sell the full version, with or without the EDID pin access.
Is there another program out there available to reprogram a Samsung HL67A750A1FXZA to work with the Mitsubishi 3DA-1 adapter?
Very sad about this.
jlseagull is offline
post #1135 of 1136 Old Today, 10:48 AM
Quoted: 763 Post(s)
Liked: 660
post #1136 of 1136 Old Today, 10:56 AM
jlseagull's Avatar
Unfortunately, I already tried that. My 3DA-1 was manufactured in June 2011, which is apparently after they "fixed" that trick. http://forums.highdefdigest.com/3d-g...-dlp-sets.html
Reply 3D Displays
