3D on Samsung 1080p DLP with Mitsubishi 3DA-1 and no Gefen - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 10-08-2010, 09:59 AM
BigSteve82's Avatar
Quoted: 76 Post(s)
Well, it's been 4hrs and still no reply email with a PIN
I really wish they had a customer support number other than 440-394-5648 because nobody ever answers on that one. Does anyone know their normal hours of operation? Or, perhaps another program that will write/flash EDIDs?
4K/HDR Display: Vizio M70-D3 | Receiver: Yamaha Aventage RX-A3000
Speakers: Definitive Tech BP8B (Front) / CLR2002 (Center) / ProMonitor1000 (Rear+Height) / HSU VTF-2 MK4 (Sub)
Media Players: Xbox One S / PlayStation 4 / Chromecast / Amazon Fire TV Stick (Kodi)
Remotes: Vizio Tablet / Harmony One+ | HDMI Cables: Monoprice "Certified Premium" 18Gbs
BigSteve82 is offline
Old 10-08-2010, 11:03 AM
tommyla's Avatar
I got my new PIN for my Laptop this morning and I tried to do a quick test with my VGA out to the VGA port on the Sammy and PS was able to find the EEPROM on port #3 and offered me to update the EDID but of course I didn't want to flash the EDID on that connection!
I had to run to work but I will try to flash the HDMI port tonight, the problem is that I only have VGA out on the laptop so I will have to make PlumB's cable, urg! I really wanted to not have to solder anything!
PlumB, do you think that a VGA->HDMI or VGA->DVI->HDMI adapter would work or you really have to create that Frankenstein cable of yours?
tommyla is offline
Old 10-08-2010, 12:29 PM - Thread Starter
PlumB's Avatar
That might work, I don't know. You can't get HDMI to display VGA video, but all you need is the SDA and SCL wires to flash the EDID. You'll have to check the pinouts I posted with the directions for the cable.
PlumB is offline
Old 10-08-2010, 01:34 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
I have FINALLY gotten my new PIN for the laptop and it WORKS!!! Well, it's at least letting me click on "Update EDID" now and going through the steps...still have a problem, though.
I saved the following from the first page into a text file just as it is and named it "EDID Update":
Code:
00FFFFFFFFFFFF0034ACC831000000003111010380A05A780AAEA1A6544C992614505421080081800101010101010101010101010101023A801871382D40582C450040846300001E662150B051001B304070360040846300001E000000FD00173D1A4417000A202020202020000000FC0053414D53554E470A2020202020010C
It recognizes/finds the Samsung's EEPROM but whenever I get to the point of choosing a .txt file and choose the one I created with only and exactly the code posted above, I get a message that says "This file does not appear to contain a valid EDID. Please check it in an EDID editor."
I feel that I'm ALMOST there but keep getting knocked back the closer I get with something new. Any suggestions on THIS problem?
Old 10-08-2010, 01:58 PM
tommyla's Avatar
Re-read line62's post, you need to open the files up in Mon Info and it will fix it for you, then you can save the new file and use it in PS.
http://www.avsforum.com/avs-vb/showt...2#post19301172
Code:
Whenever I get to the point of choosing a .txt file and choose the one I created with only and exactly the code posted above, I get a message that says "This file does not appear to contain a valid EDID. Please check it in an EDID editor."
tommyla is offline
Old 10-08-2010, 02:06 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
He speaks of two files in that post...what is the other file that I need besides the one copy/pasted from the "Updated EDID" code on the first page of this thread?? I am SO lost right now!
1) Basically I copy and paste the following "Updated EDID" for the HL61A750 from the first page and paste it into a .txt file:
Code:
2) I open up MonInfo and File>Open the text doc I just saved.
3) While that text file is selected in the upper left window, I File>Save As to somewhere on the desktop as .bin
4) Run PS as usual and choose this newly created .bin file that MonInfo created to my desktop?
I'm just wanting to verify the exact instructions (if someone can post step-by-step for me it would be great) since there are contradictions between the first page and other users.
Old 10-08-2010, 02:24 PM
tommyla's Avatar
I'm gonna play that fun game when I get back home tonight. Hopefully you would have figured it out by then and save me some time!
Code:
tommyla is offline
Old 10-08-2010, 02:56 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
Looks like you can enjoy your evening....I was bested by commas! I thought you simply copied/pasted the code into a text file. Didn't realize I had to put commas after every section. I did this, saved again, and it showed...wait for it...
SUCCESSFULLY UPDATED!!
Now onto the next steps...hooking up the PS3.
1) Plug the PS3 into the 3DA-1 adapter
2) Plug the adapter into HDMI3
3) Power on everything
4) Run a display check in the PS3's menu??
Is it really THAT simple to do? OR is there something else that needs to be done for it to be recognized as 3D display? I really don't want to do these steps wrong and have to go through ALL this all over again.
Thanks everyone for being patient with my impatient self and helping me through this. Let's just hope that I did it right up to the connections (which is what I'm wanting to clarify before attempting).
Old 10-08-2010, 03:24 PM
jford951's Avatar
Well my nvidia 7300 didn't allow me do update either same bus error
jford951 is offline
line62's Avatar
Alright!! Big Steve
Cool do you have the adapter and glasses?
line62 is offline
Old 10-08-2010, 03:34 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
Originally Posted by line62 View Post
Alright!! Big Steve
Yup! I have it all hooked up following the directions on the adapter and my PS3 automatically recognized it as being a 3D set!!
Watching the demo DVD now and I must say...IT'S AWESOME and was DEFINITELY worth all this trouble!! LOL
Only thing is, and I'm sure others have noticed it, anything black on the screen appears reddish in color. There really aren't the deep blacks DLP is great for visible right now while watching in 3D. Taking the glasses off, and looking at the screen with the naked eye, it's almost all red. Is this just something that has to be dealt with while it's in 3D mode or is there a fix for it?
Old 10-08-2010, 03:37 PM
tommyla's Avatar
Life is ironic sometimes isn't it? I just spent $1K building a brand new desktop and I had to get my 5 year old laptop out for this! :P
Oh BTW, we should start a list of incompatible graphics cards. PlumB, can you add this list to your OP?
I'll start the list:
Nvidia GTX 460
Nvidia 7300
tommyla is offline
Old 10-08-2010, 03:39 PM
line62's Avatar
Big Steve name the hdmi 3 input pc and it will fix that
line62 is offline
Old 10-08-2010, 03:43 PM
line62's Avatar
I think you might have to build the "cable"....
line62 is offline
Old 10-08-2010, 03:53 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
I've renamed it to "PC" and it made it a lot crisper (had some ghosting when set to "BluRay")...still has the red though and a lot of the menu/picture options are greyed out.
Old 10-08-2010, 03:54 PM
tommyla's Avatar
line62, did you have to build the cable? I'm gonna try the VGA->DVI->HDMI first and then if that doesn't work, I'm gonna bite the bullet and build the damn cable! :P
Buying two extra cables, a continuity tester, and a soldering iron is not gonna be cheap either!
tommyla is offline
Old 10-08-2010, 03:55 PM
tommyla's Avatar
When in 3D mode, the image tint is gonna shift, it's just how it is.
tommyla is offline
Old 10-08-2010, 04:02 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
Actually, going back and comparing the two, "PC" actually made it quite a bit blurrier. The ghosting was due to the wrong 3D mode being selected.
Old 10-08-2010, 04:04 PM
line62's Avatar
No I was able to view what I was doing on the laptop and used my hdmi on the laptop out to program. See my screen shots?
line62 is offline
Old 10-08-2010, 04:12 PM
tommyla's Avatar
I only have VGA out on the laptop, it's a pretty old one, urg!
tommyla is offline
Old 10-08-2010, 04:20 PM
jford951's Avatar
It is looking that way
jford951 is offline
Old 10-08-2010, 04:35 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
Nvidia GTX 460
Nvidia 7300
Add the ATI 5XXX Series to that list, as well. Mine was the 5850. Over on their site, the entire 5XXX series is listed as incompatible.
Old 10-08-2010, 04:45 PM
makav911's Avatar
PlumB anyone,
I will post the info from mono info for the HL61A750 here in sec...maybe then you can let me know if I need to change/update the extension block on my TV with what you already have.....
thanks!
Here it is:
Monitor #1 [Real-time 0x0100]
Model name............... SAMSUNG
Manufacturer............. Samsung
Plug and Play ID......... SAM03C7
Serial number............ n/a
Manufacture date......... 2007, ISO week 49
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1600 x 900 mm (72.3 in)
Power management......... Not supported
Extension blocs.......... 1 (Reserved - 0x00)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.650 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.080
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 26-68kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 230MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1360x768p at 60Hz (16:9)
Modeline............... "1360x768" 85.500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
Report information
Date generated........... 10/8/2010
Software revision........ 2.52.0.857
Data source.............. Real-time 0x0100
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,C7,03,00,00,00,00,31,11,01,03, 80,A0,5A,78,0A,AE,A1,A6,54,4C,99,26,
14,50,54,21,08,00,81,80,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,40,84,63,00,00,1E,66,21,50,B0,51,00,1B,30,40,70,36,00, 40,84,63,00,00,1E,00,00,00,FD,00,17,
3D,1A,44,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D, 53,55,4E,47,0A,20,20,20,20,20,01,A2
makav911 is offline
Old 10-08-2010, 05:04 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
Here's a helpful tip that I noticed on my set hooked up to a PS3 (it may NOT be the same for all).
When running the PS3's display detection on "Automatic", it will put in a screen size automatically. For mine, it showed 72" automatically. Being that I have a 61", I obviously changed it. It definitely looked good but I noticed quite a bit of ghosting.
I went back and redid the PS3's display detection and left it on it's automatic 72" setting...images are WAAAY better now with absolutely NO ghosting whatsoever! I thought it looked good when I had it on 61", but leaving it at it's default findings looks completely different in a GOOD way!
Again, this may not be the same for everyone, but I would try the setting that's automatically chosen AND the actual size of your TV (and anything in between) to see what looks best for YOU! Hopefully, if this does work for you and you put the actual size of your TV in as most any normal person would do, you'll be as excited as I am at the even more improved picture quality!
Old 10-08-2010, 05:07 PM
NetCoder's Avatar
Congrats! What did you finally change to get it to detect your tv?
NetCoder is offline
Old 10-08-2010, 05:09 PM
NetCoder's Avatar
I think the TV size changes the "exaggeration" of the depth of field.. I think it will largely depend on your tv room configuration.. (ie. distance from your sitting position to your tv)
Are you further or closer, than the recommended 10 ft for these tvs?
NetCoder is offline
Old 10-08-2010, 05:57 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
I was able to get it working via the laptop hooked up since the ATI HD5850 in my desktop wasn't compatible. Simply had to wait for another PIN for the laptop config (which took near 8hrs to actually get) and then add commas into the Updated EDID file for it to read. After that, it was smooth sailing
My primary sitting position is right at about 11ft away. Is there any specific forumla / guidelines as to what would be the best setting?
Old 10-08-2010, 06:02 PM
line62's Avatar
Big Steve set color to normal and wide tv see what ya think? I am partially color blind lol. If you type your set # in search on here guys there is a ton of calibration info and more than you could ever want to know about your TV sets...
line62 is offline
Old 10-08-2010, 06:25 PM
tommyla's Avatar
Going home to try it out, will swing by Fry's to get an adapter, wish me luck!
tommyla is offline
Old 10-08-2010, 06:37 PM
BigSteve82's Avatar
Quoted: 76 Post(s)
When in PC mode, those were the default settings. PC mode, no matter what is plugged into it, looks far less crisp for some reason and causes the image to become blurry. I really only notice the red tint if looking at the set without glasses...having restored my previous UM settings, it seemed to have helped it and it's black where it's supposed to be black. I'm guessing the red is just some sort of filter used in the DLP-3D. I know the Mitsu's are green in black spots.
I've calibrated mine through the service menu about a year ago and it greatly improved the picture quality. Most of the settings were actually found in these forums.
