3D clips and trailers for 3d tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-16-2010, 04:41 AM - Thread Starter
3dtvworld's Avatar
Hey guys I have just added some more clips to my 3D Download page on my site. The clips and trailers are mostly in side by side format and should playback on 3D TV's so those of you starved for 3D content should find some temporary happiness Head to my site and I will try and post some more this weekend.
Laters!
3dtvworld is offline
post #2 of 26 Old 11-19-2010, 04:00 AM - Thread Starter
3dtvworld's Avatar
Hey guys I have added some more clips and trailers with some more to come this weekend. Please check the downloads section of 3DTVWorld.com.au for regular updates!!
post #3 of 26 Old 12-16-2010, 03:51 AM - Thread Starter
3dtvworld's Avatar
Hey 3D lovers!!! I just added some new 3d content to http://www.3dtvworld.com.au/3d-downloads/
Legend of the Guardians 3D sample and Loony Tunes 3D clip as well!
Good times!! Thanks to everyone visiting and supporting the site!
post #4 of 26 Old 12-20-2010, 04:47 AM - Thread Starter
3dtvworld's Avatar
Just added Pirates of the Caribbean 4 3D trailer to the downloads page!!!
Will post some more stuff over the Christmas break as well
post #5 of 26 Old 12-20-2010, 05:30 AM
SpenceJT's Avatar
Quoted: 25 Post(s)
Liked: 27
does anyone know if the file formats can be copied to a DVD or USB thumb-drive, and played back by way of a Panasonic BDT350?
SpenceJT
"Someone ever tries to kill you, you try to kill 'em right back!"
- Malcolm Reynolds, Capt. "Serenity" -
SpenceJT is offline
post #6 of 26 Old 12-20-2010, 06:15 AM
RetroGamer360's Avatar
Quoted: 14 Post(s)
I was going to ask the same thing. I downloaded 21 video files and was only able to see 6 files and play 2 of them on my Panasonic 3D Blu-Ray player via USB thumb drive. Do. I have to convert the files to another format?
RetroGamer360 is online now
post #7 of 26 Old 12-22-2010, 03:50 PM
Luc48's Avatar
If it's MKV then you can't play with most Panasonic TV's/Blu-ray player (Samsung does appear to have MKV 3D support).
If you have an XBOX you can convert either to WMV (for example Encode360 or tmpgenc xpress, or other...).
Another option is to split the MKV steam using MKVExtract and then remux with MP4 (but downside is max 4GB and only AAC stereo support).
Luc48 is offline
post #8 of 26 Old 12-25-2010, 08:07 PM
Mr Ian B's Avatar
Quoted: 53 Post(s)
Liked: 46
So what is the format we need to play via burned DVD to panny players and how to do it with Mac computer?
Ian B
Mr Ian B is offline
post #9 of 26 Old 01-04-2011, 04:36 AM - Thread Starter
3dtvworld's Avatar
Guys I have added some fresh clips for your 3D TV pleasure!!! I have included a couple samples from Piranha 3D as well as a night time fireworks clip all in side by side 3D MKV formats that should playback on most 3D TV's.
You can download the clips at http://www.3dtvworld.com.au/3d-downloads
post #10 of 26 Old 01-04-2011, 11:05 PM
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
Why do these need to be in MKV? Samsung's won't play them. Why not AVI or mpg4? Are these new MKVs going to play?
Bill is offline
post #11 of 26 Old 01-04-2011, 11:14 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Wow! How do I play back? On USB ? On bluray player or direct to 3d tv
zoro is offline
post #12 of 26 Old 01-05-2011, 04:57 AM - Thread Starter
3dtvworld's Avatar
They should playback on a samsung 3D TV. I have no issues playing 3d mkv files back on my samsung 58" 3D Plasma via USB. What model 3DTV are you guys using?
post #13 of 26 Old 01-05-2011, 06:29 AM
mr_jbloggs's Avatar
Thanks for compiling the 3D clips/trailers/demos. Once I download, is there a way to join all the clips together into one file for continuous play?
mr_jbloggs is online now
post #14 of 26 Old 01-05-2011, 10:40 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Mine is Sony Xbr 909?
zoro is offline
post #15 of 26 Old 01-09-2011, 03:31 AM - Thread Starter
3dtvworld's Avatar
A couple more 3D clips have been added to the downloads section this weekend as well as some new coverage from this years CES 2011 showcasing some new 3D TV tech!
You can see all the news and download all the 3D files for your 3DTV's here http://www.3dtvworld.com.au
post #16 of 26 Old 01-09-2011, 03:33 AM - Thread Starter
3dtvworld's Avatar
If you playback the files via USB most should play back on most 3D TV's.
The panasonic viera 3D plasma's do not support some file formats and those of you with a sony should contact the manufacturer to confirm which formats can be played back via USB. You may need a firmware update if the files do not playback successfully.
post #17 of 26 Old 01-09-2011, 03:56 PM
8:13's Avatar
3D TV's usually only accept Megui's profile called "Max Compatibility" on simple profile you find in it's advanced configuration tab.
Then the audio during mux is Standard.
And these tv's only accept side by side Squished or half horizontal.
I suppose top bottom half vertical may work too but I never tried.
Your main thing though is the profile you use during encoding, it isn't MeGui's Max Compatibility profile.
To use Megui you need to dl and install avisynth, then dl megui.
Update megui when you open megui and install all the profiles it ask you about after it installs the updates.
avisynth
megui
Other files you need:
Haali media splitter
graphedit
mkvmerge
ffdshow
Then you use this avs file:
Code:
loadplugin("C:\\Program Files (x86)\\AviSynth 2.5\\plugins\\DirectShowSource.dll")
left=directshowsource("C:\\Users\\Jeremy\\Desktop\\left.mp4", audio=false, 23.976).spline64resize(960, 1080)
right=directshowsource("C:\\Users\\Jeremy\\Desktop\
ight.mp4", audio=false, 23.976).spline64resize(960,1080)
return stackhorizontal(left, right).converttoyv12()
To make a avs file you need to have notepad, copy and paste this into notepad, and change the notepad extension to ".avs" and erase the ".txt" extension.
In ffdshow vfw configuration, decoder tab, set "mp4" to "wmv9", and set "raw video" to "all supported".
Steps:
Assuming your source is ready. then you just input the left and right side into the avs file to point to where it is on your computer.
Open megui and set it to max compatibility.
Open the avs file.
Click enqueue, go to the queue tab and click start.
Wait then mux the audio using the tools, muxer tab, then mp4 and the audio source.
If your source isn't ready the video needs to be put into mkv using mkvmerge and then you add the mp4 and framerate in mkvmerge, save the file.
Drag and drop the file into graphedit, delete the decode at the end of the chain and save file as grf.
Add grf files to your avs file and use in megui.
Watch tutorial.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #18 of 26 Old 01-15-2011, 05:26 AM - Thread Starter
3dtvworld's Avatar
Hey guys!
Added more downloads to Http://www.3dtvworld.com.au/3d-downloads
have a great weekend and thanks to the continued support!
post #19 of 26 Old 01-15-2011, 08:37 AM
Samfield's Avatar
Hey guys!
Thanks, really enjoy these 3D clips and trailers for demo sessions.
Samfield is offline
post #20 of 26 Old 01-17-2011, 02:49 PM
jtmcalpin's Avatar
Hey guys!
Sweet! I am at work now but cant wait to get home and try some of these clips. Thanks!
jtmcalpin is offline
post #21 of 26 Old 01-20-2011, 06:58 AM
tangcoma's Avatar
Quoted: 33 Post(s)
Liked: 25
can i play it in ps3?
tangcoma is offline
post #22 of 26 Old 01-22-2011, 04:55 AM - Thread Starter
3dtvworld's Avatar
Guys some more clips just added including the Green Hornet trailer in 3D! http://www.3dtvworld.com.au/3d-downloads
Thanks and have a great weekend!!
post #23 of 26 Old 01-23-2011, 05:48 PM
threed123's Avatar
Liked: 39
3dtvworld: When download a trailer, I get a weird windows jump window that opens and then referring site for the download. After the download, the little jump window will not disappear unless a do an end program through the task manager. Are others having this problem?
threed123 is offline
post #24 of 26 Old 01-24-2011, 06:21 PM
icester's Avatar
Just go directly to :
http://www.biohemmet.se/
And download what you like.
Mathew Orman
icester is offline
post #25 of 26 Old 01-25-2011, 10:52 PM - Thread Starter
3dtvworld's Avatar
Added another clip guys and have added a forum as well for 3D related discussions too! Thanks for the support!
post #26 of 26 Old 01-15-2013, 03:07 PM
nickels55's Avatar
Liked: 36
All of the links on your site are now broken.
nickels55 is offline
Reply 3D Displays
