Discussion - Screens for 3D Projection - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #331 of 332 Old 07-27-2016, 02:28 PM
alpin3r's Avatar
Quoted: 21 Post(s)
Originally Posted by wnielsenbb View Post
Actually the JVC's use active 3D. The downside is the horizontal polarization conflicts with current 3D active glasses. You want a screen that retains NO polarization. If it retains polarization the image will be dimmer, due to how the glasses work. Any decent white screen should work fine.
Warren.
That is not the case.. with JVC glasses and JVC projector at least.
JVC's glasses are horizontally polarized, so in order to get the brightest 3D image from the new JVC projectors, one needs a screen that DOES RETAIN polarization and use JVC glasses.
If you are using cheaper 3rd party glasses, which nearly all are vertically polarized, then yes.. you would need a screen that DOES NOT retain polarization.
alpin3r is online now
post #332 of 332 Old 07-27-2016, 03:52 PM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
I should have imagined that was true. I was thinking he thought it was a passive 3D system.
Found a good chart for Da-Lite screens.
http://www.projectorreviews.com/home...ection-part-2/
http://www.bhphotovideo.com/bnh/cont...C&A=details&Q=
1222 is a bit out of the price hoped for, but a good screen is worth it. It will outlive many projectors.
Warren.
wnielsenbb is offline
Reply 3D Displays
