The "Official" Optoma 3DXL Owner's thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 1731 Old 01-25-2011, 07:31 AM - Thread Starter
rdjam's Avatar
Originally Posted by Wilson-Flyer View Post
So let me get this straight. I can take this new Polarizing thinga-ma-giggie and the new Optoma thingie and hook it to my 1080UB LCD (non 3D) projector and be in business with passive 3D. NAW! Can't be that simple. I notice the rotator says it works with LCD but the Optoma says DLP only?
I'm confused.
"Naw" is correct. That polarizer grate is designed for DLP-Link projectors I think.
rdjam is offline
post #92 of 1731 Old 01-25-2011, 09:33 AM
GunPower's Avatar
Originally Posted by walford View Post
These units have two separate HDMI inputs since they asume that you could have one input from a unit that plays 3D blu-ray disks and another input from a cable or satellite STB receving HDMI 1.4a 3D video content.
That still sounds like a HDMI switch to me. They always taught me not to reinvent the wheel in my engineering classes...
Maybe it has something to do with the multi-box approach though. Is there any info on how the cabling is run to support dual projector passive? With only one output per box, it sounds like it would requre a 3rd piece of equipment to actually split the L/R signals, which I suppose a PC could easily manage... But a 3D-BR player would not... Does that mean it won't support dual projector passive on 3D-BR players?
GunPower is offline
post #93 of 1731 Old 01-25-2011, 09:42 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
rdjam already stated his player has dual outputs. I asked the same question earlier in the thread.
wnielsenbb is offline
post #94 of 1731 Old 01-25-2011, 10:55 AM - Thread Starter
rdjam's Avatar
Yes, the 3DXL has two inputs, so you could make the case, certainly, that it has an HDMI switcher built in for the sources - to allow for instance, a Bluray player and Cable Box to be connected at the same time.
However, there is only one output - so for two projectors, one needs two 3DXL units. Each 3DXL unit must be fed with the 3D bluray HDMI stream. In my case, I am using my Denon 4311 to supply both 3DXL boxes, since the 4311 has two HDMI outputs that can send the same signal.
Each 3DXL then "demultiplexes" the right or left signal from the 3D Bluray stream, depending on the position of the selctor switch on the back of the 3DXL.
I should probabably put some graphics in the opening posts to help illustrate how this works in relation to the projection system being built in the "Ultimate 3D projection" thread.
rdjam is offline
post #95 of 1731 Old 01-25-2011, 01:11 PM
Wilson-Flyer's Avatar
I'd like to see that, rdjam.
I'd also like to see a diagram of on the cheap and what's needed to make this all work at a bare minimum.
I'm torn and my delima is thus...
I have a 55 Sammy in my living room that I love. It replaced a 62 Mits that I loved too but it was only 720p and it blew up (infamous Mits cap problems). I was pissed off at Mits at the time so I bought the Sammy, 2 months before they released the 3D stuff. Story of my life.
Anyway, I want 3D but I don't want it as my main source. I want Bluray (PS3) and DTV sometimes and my preference is on the big screen. You see, I have an Epson 1080UB in the same room with a pull-down DaLite Hi-Power 106" screen for watching occasional games (sports) and Blurays. I'd love to drop it down to occasionally and watch 3D. Passive would be my preference but active would work if it worked reliably. I have a HT PC too with TMT5 but that wouldn't be my first choice of sources. I play with the HTPC but my family WATCHES the other sources. You know what I mean.
I almost pulled the trigger on the 73838 Mits last week. Then I saw the 63" Sammy 8000 bundle on sale at BB this weekend. Now I find myself in a holding pattern once again going, "Who am I fooling here. What I really want is BIG 3D. I'll be settling with anything else." So far, I'm glad I haven't pulled the trigger on either one but I only have a few more days on the Sammy deal at BB.
What to do. What to do...
Then, I run across this section (can't believe I haven't been here) and more importantly, this THREAD.
I source all my material to both the TV and the projector via a DVDO Duo so getting HDMI sources to both is no problem. I do have the challenge that a DLP projector will be a challenge in my environment because I have to mount it off-center so horizonal and vertical shift are almost mandatory, hence the reason I've stayed with LCD and the Epson to this point. The 1080UB Pro is a great projector and it's 3 years old now. I don't mind having two projectors and buying a 720p just for 3D if that's what it takes. I don't particularly want to have 3 over my head on the couch though. LOL Looks like you have to have two to do passive if I'm reading correctly?
Again, I'm looking a "part-time" projector solution for 3D only. I think you will agree that my 1080p normal viewing problems are under control but it sure would be nice to watch an occasional 3D production from the comfort of my couch.
How can I do this and what is the cheapest way out for me? This Optoma device has thrown a whole 'nother kink in all this for me. Looks like we can do this a lot cheaper now than I ever even dreamed. I'm way past the 720p v. 1080p thing when it comes to 3D. Again, this will be a part-time experience for me and I owned a 720p projector before the Epson. I know what to expect and I can live with it.
Still in a holding pattern. There's something important enough going on here to wait and see how it all unfolds before I do anything, it appears to me.
It's been my experience here at AVS that there's an incredible amount of tech going here all the time but what we are exceedingly bad about is stating in the end that you need "This, this, this and that to make this all work." That's what I'm trying to figure out in this thread and I suppose that it is still a work in progress in reality.
-bob
HDTV in my home since 1999.
Wilson-Flyer is offline
post #96 of 1731 Old 01-25-2011, 01:38 PM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
This box with an Acer H5360 projector is a really cheap solution. 720P makes no difference for 3D movies. I sit 7' from my 120" screen and it doesn't bother me at all. In 2D that changes and I notice the screen door effect, but for 3D it is amazing.
post #97 of 1731 Old 01-25-2011, 01:43 PM
Passive? Active? Where does the emitter go or is it DLP enabled? Still confused. For a thousand bucks, I'm all over this. I was about to spend 2-3 times that for something smaller that I really didn't want to begin with.
post #98 of 1731 Old 01-25-2011, 01:50 PM
TrickMcKaha's Avatar
Wilson-Flyer,
You are about perfect for getting a 720p DLP Link projector except that part about needing to mount it off center. If only you can find a way to mount it exactly where it wants to be, you could be in the wide screen 3D business on the cheap - under $1300 - much less if you already have a suitable HTPC. But if you really must have lens shift, you would almost certainly be better off rigging up a passive glasses 2 projector setup like rdjam or Blackshark.
If you might want to go that route, first thing is to check rdjam's list of projectors that have all three colors oriented together, polarization-wise. If your current projector is on that list, it could serve as one of the two you would need. If it is not, maybe that projector hasn't been tested yet, and you might want to follow the instructions to test it - its not very hard.
I advocate for big screen projection 3D whenever possible. Smaller screens are noticeably... smaller - especially in 3D.
TrickMcKaha is offline
post #99 of 1731 Old 01-25-2011, 02:00 PM
I just thought of something. Optoma has a dLP Link projector pretty much made for moving to various places, setting it up, and gaming in 3D. It costs under $700 and you might just set it on an end table when you want to watch 3D. That way, mounting over your head would not be necessary. For occasional use, that might be fine. It is the 700 series.
Together with the 3DXL box or a suitable HTPC, great 3D would be thrown onto the big screen.
post #100 of 1731 Old 01-25-2011, 03:07 PM
I can live with that. Even though I have the HTPC, my goal here is to keep it out of the equation. I don't want to have to deal with it. It's my toy but the family needs something simple. I just want to get my sources that already do 3D out in 3D if that makes sense.
I don't mind putting another one above my head over the couch. It's hard to describe but the 1080UB is on a small shelf between two windows. It would be easy enough to simply pull a shelf all the way across the windows and then with a little vertical offset, I would be fine. I don't mind doing that. I guess what I was trying to convey is that as much as I'd like to have passive, which it sounds like I'd have to have two for, I'm not willing to have a pile up there so it starts looking junky. This is my living room, after all. LOL
I'm going to check and see if my 1080UB Pro is on the list. If it is, getting another and slightly lessor 1080 might be an option but I probably can't even find another 1080UB now and I suspect they work better if they are a matched set. That would be a double value because when watching non-3D stuff, I could essentially double my light output for daytime viewing.
Hmmm... Lots to consider. I'm just glad to find this thread. I think I'm finally headed in the right direction thanks to it and probably better for less than I had first thought. I ride the projector and display forums and have for years but they are amazingly quiet when it comes to 3D. It's a wonder I even found this part of the board, but I'm certainly glad I did.
post #101 of 1731 Old 01-25-2011, 03:14 PM
I don't see a 700 series on Optoma's page. Maybe it's last year's model? If so, it would be even cheaper, probably. Maybe I'm just missing it in the HT section. Got a model number?
Do you have a link to rdjam's list of LCD projectors he's tested?
PS--> I didn't mean to "take over the thread" but I think most would agree that this is an important part of the discussion of this device too. If not, I'd be happy to start another thread.
post #102 of 1731 Old 01-25-2011, 03:43 PM
rastie's Avatar
WF- I believe he was talking about the gametime short throw projectors from optoma so I believe there is the gt700 and another with slightly higher c/r.
rastie is offline
post #103 of 1731 Old 01-25-2011, 03:45 PM
I found them under the game projectors. I also found a 720 refurb on fleabay for $600. Uh-oh! Trouble's a brewin'! LOL
post #104 of 1731 Old 01-25-2011, 04:15 PM
This device's propaganda keeps referring to 720p projectors on the cheap.
I gotta ask the obvious question. Why wouldn't it be even better on a 120 1080 DLP? Surely they exist (I've aleays been an LCD projector guy but my bet would be that most 1080p DLPs are 120 by now anyway without doing any research.) and probably not that much more money.
What gives? Is this thing limited to 1080p in and 720p out and even if that's true, wouldn't a 1080p DLP projector upscale the projector's input to 1080p and make it even better?
What am I missing?
post #105 of 1731 Old 01-25-2011, 04:58 PM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
hdmi can't do 120Hz 1080p, hence no 120Hz input 1080 projectors at all. It would need a DVI or Displayport adapter. Any 1080p 3D projectors out, or on the horizon are hdmi 1.4 and don't need any funky adapter. They are a lot more money is all.
post #106 of 1731 Old 01-25-2011, 05:07 PM
Duh! That makes sense. Thanks!
post #107 of 1731 Old 01-25-2011, 05:11 PM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
The funky thing is so far the only way to game at 1080p in 3D at more than 24fps is passive projection with DDD or iZ3D drivers and both projectors plugged directly into the htpc. nVidia won't support dual projectors for no reason but greed.
post #108 of 1731 Old 01-25-2011, 05:33 PM
Yea. I've been reading about that, though I'm just not as into gaming as I use to be. I don't get it. Sometimes it seems like nVidia and ATI can't get out of their own way.
post #109 of 1731 Old 01-25-2011, 07:00 PM - Thread Starter
rdjam's Avatar
I've only tested a couple of JVC pjs so far, but I've put easy instructions up in one of the opening posts.
I'm definitely encouraging everyone to test their pjs and post the results and photos here.
I'll then add the results to the list on the first page.
rdjam is offline
post #110 of 1731 Old 01-25-2011, 07:01 PM - Thread Starter
rdjam's Avatar
Tell me more about Iz3D! Will it let me use dual NVidia cards to feed a projector from each card in 3D mode?
rdjam is offline
post #111 of 1731 Old 01-25-2011, 07:09 PM
Where's all this? I can't find it.
post #112 of 1731 Old 01-25-2011, 07:38 PM
defiancecp's Avatar
Yes, or even from a single card with dual outputs. I used it that way for a while with a 9800gt. Yes, I go through a lot of video cards :P My first 3d setup was that 9800gt, iz3d driver, and a pair of ew1610 projectors through a set of cheap berezin plastic polarizer filters. I've switched things around about a gazillion times since then, but that setup stayed around for several months with much success.
In fact, dual outputs is one of the best modes I've personally experienced with iz3d.
defiancecp is offline
post #113 of 1731 Old 01-26-2011, 04:04 AM
hashitoxicosis's Avatar
@Wilson-Flyer
I just set up a temporary 3D solution. I bought an Optoma tw610st pj, it is short throw, means it puts out a 100" image at 3-4 feet. It is driven by a Radeon hd6950 card( any 5xxx ir 6xxx will do, but 6xxx are hdmi 1.4 ready for the future) I am using dlplink glasses. TMT5 is used to play the 3d SBS movies downloaded from the internet( and you get them all!). You could substitute GT720 pj if you want it even cheaper for a little less lumens ( 3100 vs 2500 lumens). TMT5 can also play 3d BDs directly.
hashitoxicosis is offline
post #114 of 1731 Old 01-26-2011, 04:45 AM
Originally Posted by ha****oxicosis View Post
@Wilson-Flyer
I really need the lumens in my room but I was hoping for a cheaper solution. This is quickly turning into a $2k project and that's fine but it just requires some additional planning. I'm seriously considering going Real3D with the emmitter so that's going to add to the cost too.
Oh well... I guess I don't have to make any decisions until the 3DXL actually ships in the states. I may go ahead and get the projector, though. Has anybody heard a firm ship date yet? I know it's been asked before but not really responded to so I guess not.
That's pretty much best bang for the buck if I draw a $1k line in the sand for the projector? Everybody pretty much agree on that? I need lumens and and as much mounting flexability as I can get for my $. LOL
post #115 of 1731 Old 01-26-2011, 07:52 AM
tw610t is 968 shipped . A 55xx card is about 150 ( assuming you already have the htpc setup) DLP link glasses are about 90 a pop
dual 1080p (needs lens shift for accurate alignment) two 3d-xl s polarizer and screen will be over 4000 ( i was thinking that route earlier)
post #116 of 1731 Old 01-26-2011, 09:33 AM
You guys keep talking about HTPCs and cards and the like. I already have one well within specs but I must be missing something here. I thought the whole purpose of this black box that is the origin of this thread, was to get my sources to the projector in 3D format without having to deal with a PC. Am I missing something here I need to know?
post #117 of 1731 Old 01-26-2011, 09:43 AM - Thread Starter
rdjam's Avatar
Heh! Sorry, yes we strayed off topic a bit there!
No, the discussion wandered over how to get full 1080p60 to each projector, which is not currently supported by any of the devices out there - prolly should have had this over in the U3D thread
The 3DXL will do pretty much all official formats and send then to the single projector DLP-Link, or dual-projector custom setups we have been discussing.
Sorry for going OT there!
rdjam is offline
post #118 of 1731 Old 01-26-2011, 10:04 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
There is no current 3D ready projector that has any placement flexibility. You can check the projection calculators on Projectorcentral. My Acer 5360 had to be 14 feet back from the screen and mounted upsidedown 8" above the screen.
post #119 of 1731 Old 01-26-2011, 10:17 AM
Remit's Avatar
How big is your screen? 14' back it must be huge!
Remit is offline
post #120 of 1731 Old 01-26-2011, 10:27 AM
wnielsenbb's Avatar
Quoted: 16 Post(s)
Liked: 27
120" screen. I happened to have a shelf on the rear wall that worked perfectly for it.
The optoma gt720 would need to be only 6'7", which would put it right over my head.
The optoma HD 66 is similar to my acer, but more offset. From projectorcentral: "you can fill a 120" screen with a 16:9 image from 13' 6" to 14' 10", depending on the position of the zoom lens. The fixed throw angle means that the bottom edge of this same image will appear almost 11" above the lens' centerline"
That would probably be better for ceiling mounting for most people.
Reply 3D Displays
Optoma , Optoma 3d Xl Converter Box For 3d Video And Gaming , Epson Powerlite Home Cinema 8350
