Which secondary 3d TV is best for me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-26-2011, 11:55 AM - Thread Starter
GunPower's Avatar
I need to figure out which secondary 3d TV will complement my Acer H5360 *dlp* setup.
The background: The "family" Xmas present this year was the Acer H5360 (and one "testing" pair of viewsonic *dlp link* glasses) which was opened with much excitement by the family, amidst promises of 3d console gaming and 3d Blu-ray movies in the theater room... Well, that's not as easy as I had first thought since sans 3D-XL it is usable only by PC. Last night as I was working on hooking up the PC (which is my all important gaming PC that nobody else is allowed to touch ... lol) I received looks of disapproval from my wife and children. They want their 3d.
So, I need a secondary display solution for the living room. This display *needs* to support 3d console game support out of the box - primarily CoD:Black Ops on the 360 (favorite game for the kids) - but also PS3 games. It would also be super great if it supported 3d Blu-ray out of the box - although I do have a BR drive coming for the PC/Acer in the theater room so I suppose it's not a deal breaker if it doesn't.
My first guess is that the Mitsubishi DLP lineup is what I should be looking at. But, there have been a lot of Samsung plasma combo deals that are very attractive. 720P is fine (family can't tell the difference but I can). I just really don't want to double-dip for the glasses.
Are the Samsung plasmas in any way compatible with dlp-link glasses?
I have pretty much ruled out nVidia 3d-Vision because of the secondary display need, but maybe they would work with a mitsubishi or samsung?
Looking for suggestions on the perfect complement...
GunPower is offline
post #2 of 3 Old 01-26-2011, 11:59 AM
poofyhairguy's Avatar
Doesn't work with DLP glasses, but is plug and play with 3D game consoles, 3D Blu Ray players, and 3D cable boxes:
http://www.amazon.com/Samsung-PN50C4.../dp/B003XDU6EQ
poofyhairguy is offline
post #3 of 3 Old 01-26-2011, 12:02 PM - Thread Starter
GunPower's Avatar
That is the exact Samsung TV that I was considering. Any chance that it is compatible with nVidia glasses? If it was, I could return my one set of dlp glasses and go nVidia glasses so as not to double dip.
Otherwise, I'm leaning towards a Mitsubishi dlp.
Thanks for the direct link.
Edit: Or possibly the Samsung glasses are compatible with the Acer H5360 in nVidia mode? But that would still need some kind of emitter...
GunPower is offline
Reply 3D Displays
