DIY DOLBY 1080p 3D, Color correction not really needed... - AVS Forum | Home Theater Discussions And Reviews
Old 03-13-2011, 10:23 PM - Thread Starter
Plewacka's Avatar
I have just recently tried out the Dolby method of Dual Projection Passive 3D, and the results are as good as, if not slightly better than the Acer 3D projector,
The only problems with this method for me was that the Dolby glasses need color correction when viewing, or the results would not be watchable, and there not being a blu ray software player on a HTPC that I could find,
UNTIL NOW...
The color correction needed for the Dolby 3D Glasses I thought would be the deal breaker for me, but I found out that with a little ATI Catalyst Control Center Tweaking, and having the Dolby Glasses as flat as possible, and parallel to the front face of the projector, removed most of the color shift I saw, there is still some left, but it seems to balance out very well when watching 3D... Man am I happy with this setup, because for the most part I spent about $200 to get this working, and I can use a normal screen!!!
I will post a guide soon that will include where to get the filters, glasses, software, and how to set everything up, please PM me for more details.
The Dolby Method I have concluded for myself only, is superior to any other method out there, with the exception of course of maybe the Acer 3D, and JVC projector paired with active glasses...
Now I was lucky enough to happen to have 2 projectors lying around, and they're not even the super digital $20,000+ high end's, more like two cheaper 1080p's. I would love to see how much a color corrected, 2 high end projectors, and even a higher gain screen would make a difference.
Ok, enough talk, now onto the writing the guide.
Oh, and the Blu Ray player software, you still have to rip the movie but do not have to re-encode it anymore with Stereoscopic Player 1.6.9...
Thanks for all the work and research being done with 3D in this community.
Plewacka is offline
Old 03-14-2011, 06:10 AM
defiancecp's Avatar
I've tried using catalyst control center color corrections, but the results were far from what I would consider acceptable. There is variation from projector to projector because of the light mixture produced by the bulbs, but even others that had success using directshow filters had to use more complicated corrections than what is in catalyst controls.
I agree with you that this method is generally superior otherwise, though.
defiancecp is offline
Old 03-14-2011, 06:57 AM
shajan's Avatar
subscribed.
Shajan
shajan is offline
Old 03-14-2011, 09:59 AM - Thread Starter
Plewacka's Avatar
Defiancecp, I wonder why I am getting the results as good as they are, maybe it's the lamps, or the fact that I am using 2 different projectors which I probably failed to mention, (it's what I have on me at the moment).
Defiancecp, Which glasses did you try, the Dolby Glass lens type, or the curved plastic lens type, maybe this made a difference.
I'm just trying to pinpoint where the difference is because this is a 3D method that I really see a future for in home theater if done properly.
If you could post some pictures of what your color difference is like then maybe we can compare.
Thanks to AVS Forum members all around...
Plewacka is offline
Old 03-14-2011, 11:47 AM
defiancecp's Avatar
Unfortunately it's long since (nearly a year now) dismantled. I plan on trying again using the CMS in the 3d-theater once that gets released though. So I can't really get any pictures...
I was using flat-lensed infitec filters and glasses. I've heard that dolby and infitec, in spite of dolby being a licensed infitec implementation, use slightly different frequencies - if so that might impact the color balance.
My projectors that I with were Optoma EW1610's, which (if I remember correctly) use UHP lamps.
There's a thread somewhere - can't find it now - but somewhere on here where a couple guys were using infitec or dolby and had directshow filters handling the color correction (which of course limits the application a little bit since those can't be applied to DirectX or non-HTPC sources.
Personally, even if catalyst corrections would work, I still wouldn't be ready to switch back - I don't really plan to do that until non-HTPC sources can be properly corrected. Which is why I hold high hopes for the 3d-theater box, since it can demultiplex 3d signals and handle color management.
Old 03-17-2011, 07:54 AM
TimShadler's Avatar
I can't wait to hear more!
TimShadler is offline
Old 03-25-2011, 01:04 PM
jack-bauer's Avatar
Please find my Infitec/dolby color calibration kit version2:
http://jptheking.free.fr/3d/Dolby_ca...ion_kit-v2.zip
This of course is only for playing 3D movies. No gaming.
Jack
EDIT: Documentation can be found here: http://jptheking.free.fr/3d/Dolby_calibration_kit.doc
jack-bauer is offline
Old 04-07-2011, 06:25 AM
jack-bauer's Avatar
Dolby3D vs polar wars: A new hope...
So far, like defiancecp, I had never been able to do color correction with the graphic card driver and/or the projectors settings. But thanks to Plewacka, I spent a few hours again on the subject. He being able to do fairly acceptable correction made me wonder.
Let me summarize the issues:
Drivers/Projectors use a 2D CMS (saturation+Hue) which is known not to be able to correct the colors efficiently. I happend to find out that gain (brightness) is the most important parameter, which is missing in 2D CMS. Hopefully, with 3D CMS the task would be easier.
Note: Projectors using Xenon lamps would be easier to correct. Unfortunately, I am on the dark side as I use standard UHP lamps, which is worst case as far as wavelenght filtering is concerned.
Plus, the ranges available for all parameters are much too narrow to take care of the huge color shifts needed for Dolby3D or Infitec correction. This if you use the regular menus.
Still, on my projectors, and probably on most, gain can be set for each primary when using the service menu (look in the color temperature section). This for each of four available user profiles. Range appears to be wide enough for the correction. If you can set the gains to 50% or less, there is hope.
I make two kinds of experiments:
1. Only adjust the gains for the 3 primaries
2. Add more tweaking with the 2D-CMS
On my projectors, gains range from 0.45 to 1.5 in the service menu (0.8 to 1.2 in the regular menu).
The values I have been using:
Code:
                L eye   R eye
RED             1.1     0.45
GREEN           0.65    1.0
BLUE            0.9     0.75
I am getting a perfect match for greens. Reds are noticeably different but as long as the brightness look about the same, it is not a problem in 3D viewing. Even if you close one eye then the other, you hardly see any difference. Blues and Magentas are more critical and experimentation must be done with different video clips to get the correct parameters. Using the 2D-CMS helped reduce some colors mismatches, specifically because it can play on secondaries as well as primaries.
This gives a rough 40% light transmission through the filters, more or less what you get with polars.
My conclusion:
Code:
No correction   Unwatchable. Severe eye rivalry on primaries and secondaries.
Gain correction Fair
Gain and CMS    Fair to good
AVS script      Excellent
As I want to switch easily from 2D to 3D, color correction must set on/off at the touch of a single key. I can do that if I take only the gains into account. If I want to include CMS, it is a little bit more complicated. So, because I am a lazy guy, I tried to watch an entire movie, only using the gain parameters.
We watched Avatar again yesterday night with only the gain settings from the service menu. I was very pleased with the result. Nobody in my audience made any comment about color mismatch (I didn't warn them about the new settings). Although the correction is not perfect, it is way *much* better than with the polars and the terrible silver screen. With my now trained eyes, I could see some differences now and then while watching the movie, but absolutely none to make me reject this very simple kind of correction. There is maybe a slight drop of brightness (*) compared to the AVS script. Nothing dramatic though.
I must add: No headache at the end of the movie
I am seriously thinking about getting rid of the AVS script. Because my CPU is busy in correcting colors, I could not use it to make frame doubling, as I do with 2D. I can do that now and it makes me extremely happy (we watched Avatar with frame doubling). Too bad I spent an enourmous amount of time to do color correction through AVIsynth scripting...
So it seems color correction can be done on the projector side. I wouldn't see any reason not to play games with this settings. Also, a setup with an HDMI splitter and two 3D-XL boxes would hopefully allow any kind of HDMI 1.4 sources to be used.
My classification:
Code:
                        Sequential      Polarized       Dolby3D
                        projectors      setups          setups
Vivid colors            good            fair            good
Calibrated colors       good            fair            fair (gains) to good(avs)
Ghosting                medium          poor-medium     excellent
Fast motion             frame lag!      in sync         in sync
Brightness              fair            good            good
Other negs              Active glasses  Hot spot+Grain  Dual setup (need splitters)
EDIT: (*) Drop in brightness is explained by the fact that, instead of matrixing the colors, we only set the gain parameter.
For example, red for left eye should be added some green. That means not only changing the color but also its brightness (green goes through the left filter with almost no attenuation). Using CMS helps to recover some light as Hue parameter can be used to drift color.
Jack
Old 04-08-2011, 12:09 PM
TimShadler's Avatar
What kind of projectors are you using jack-bauer?
Old 04-09-2011, 02:15 AM
jack-bauer's Avatar
I am using two vpl-hw15 from Sony.
http://www.mtbs3d.com/phpbb/viewtopi...aef9&start=104
Jack
Old 04-13-2011, 06:40 AM
jack-bauer's Avatar
More on color correction using projector's settings. Can be used for games.
A magic trick: Use color space
Dolby filters are asymetrical. Left colors are oversaturated while right colors are undersaturated.
Most projectors, if not all, offer two colors spaces to choose from: normal and wide.
Her comes the trick: Apply normal to oversaturated colors and wide to undersaturated colors.
What you have left is decreasing gains to match the other filter's color.
My settings:
Code:
Left filter:    normal color space
Right filter:   wide color space
Right RED gain:         -50%
Right BLUE gain:        -10%
Left GREEN gain:        -40%
You can then use CMS (hue) to tweak the left over color mismatches, if any.
(I am using Left RED hue+10% and Left CYAN hue-5%. That gives very slightly better matches)
My results are so good that I am not able to tell color differences any more when watching a movie
EDIT: I spoke too fast... After watching a few movies, there are some slight differences, but absolutely no eye rivalry any more if you set colors the same brightness. Definitely zero eye strain.
Jack
Old 05-11-2011, 02:10 PM
xhonzi's Avatar
Quoted: 21 Post(s)
Subscribed.
xhonzi is offline
Old 05-31-2011, 04:28 PM
xhonzi's Avatar
Quoted: 21 Post(s)
Jack,
When you watch 2D, do you remove the dolby filters? If not, are you not worried about the light loss?
xhonzi is offline
Old 06-05-2011, 04:00 AM
jack-bauer's Avatar
Originally Posted by xhonzi View Post
Jack,
Yes I remove the filter (I am using only one projector for 2D).
This could have been an issue for me as I had the idea to integrate the filters right inside the projectors, somewhere between the lamp and the panels. This would have needed some kind of glide mecanism... I have not given up with the idea, but this seems quite difficult with my projectors.
http://www.mtbs3d.com/phpbb/viewtopi...1320&start=104
Jack
Old 06-06-2011, 10:40 AM
xhonzi's Avatar
Quoted: 21 Post(s)
So, to switch between 2D and 3D, you:
1. Turn on 2nd PJ
2. Place Dolby Filter in front of 1st PJ (I think I've seen your mounts, they have a little hinge. How hard is it to get the filter in just the right spot?)
3. Use remote to change "colour space" from 2D settings to 3D settings for 1st PJ.
xhonzi is offline
Old 06-07-2011, 03:50 AM
jack-bauer's Avatar
1. Turn on 2nd PJ
2D=>3D:
1. Plug proj#2 to the mains and turn it on
2. Lower filter in front of proj#1 until the frame touches the lens mounting. At once on the right spot.
3. Press "standard" on the remote (may trigger both PJs. Don't care)
3D=>2D:
1. Turn proj#2 off (and unplug when fans stop).
2. Lift filter on proj#1
3. Press "cinema" on the remote.
(Cinema: Lamp in eco mode, color correction OFF).
(Standard: Lamp at full power, correction ON).
Note: Every 200 Hrs I swap projectors to balance lamp usage (2D is 90% of the time).
That's all . Jack
Old 06-07-2011, 12:16 PM
xhonzi's Avatar
Quoted: 21 Post(s)
Awesome, thanks.
xhonzi is offline
Old 12-18-2012, 02:34 AM
Phantom Pepper's Avatar
Holy cow am I glad I found this. I am a projectionist who has figured out how to make DCPs that will work in 2d and 3d color spaces... but the 3d is just 2d 48fps with left and right sources the exact same, so its not really 3d. I want to fix that ! Using your techniques, how would I go about creating it in the actual footage being shot, not adjusting the projector? what are the color differences left and right? (For I know that this multiplexing effect is the differencel in Dolby 3d)
Phantom Pepper is offline
Old 10-20-2015, 03:59 AM
laplasz's Avatar
Glad that found this thread - respect your efforts making 3D at home experience better.
I hoped that there is a better solution then silver screen and active glasses..
So can you please provide links for dolby filters? I tried to google it, but no useful result.
laplasz is offline
Old 11-28-2015, 05:12 AM
Ag4t's Avatar
Quoted: 13 Post(s)
Liked: 3
If I understand correct it's called Cat. No. 835z, also question to Jack, when you use projectors correction there is no need for script right? Thanks
Ag4t is offline
Optoma Ew1610 Wxga 2700 Ansi Lumens Projector
