LG PASSIVE LW6500 dedicated thread... - Page 83 - AVS Forum | Home Theater Discussions And Reviews
post #2461 of 2488 Old 04-02-2013, 05:57 AM
ashope's Avatar
Quoted: 24 Post(s)
Thanks,... my true motion was set to high (7) ... so I've set it to off,... and we'll see how that looks.
Much appreciated!
Take Care
Allen
Vizio M70C3, XBMC (Win8) running off a QNAP Synology.
ashope is offline
post #2462 of 2488 Old 05-16-2013, 05:57 AM
SteveCaron's Avatar
A new update was there this morning. Not sure what it fixed but went smooth and panel functions as before.
SteveCaron is offline
post #2463 of 2488 Old 05-16-2013, 07:30 PM
fred96ws6's Avatar
I noticed it this morning also. Did the update and didn't notice anything different. Still no Flash Player update so I consider it a worthless update!mad.gif
fred96ws6 is offline
post #2464 of 2488 Old 05-20-2013, 11:15 AM
batista11b5's Avatar
I just got the update 05.00.12 for my 55LW6500 , but not sure what it is
batista11b5 is offline
post #2465 of 2488 Old 05-20-2013, 02:23 PM
DigitalKnight's Avatar
Just had the panel replaced in my 55LW6500 as it had a few dead/stuck pixels in the center and a strange dark shadow line near the center. Perfect now. Even the light bleed on the corners is much better. TV still impresses me every time I use it.
DigitalKnight is offline
post #2466 of 2488 Old 05-24-2013, 09:18 AM
fritzi93's Avatar
Liked: 39
I should update you all about the intermittent thin red vertical line on my 65LW6500. It would appear some variable time after the TV warmed up. If you recall, I was able to make it stop by putting slight pressure on the rear of the set at the bottom of the line (the set was wall-mounted and tilted down). The line was a couple inches from the right side, facing the set.
I did some research and it seemed likely that it was TAB bond failure. It's a solder-less connection between a data cable and the panel. I even saw a few videos illustrating the problem on YouTube.
First of all, I'm sorry I don't have any pictures, but my wife had the camera that day.
Anyway, I took the TV down and laid it flat on the carpet. Removed the back, then attached the stand and stood it up. Then removed the bezel. Under the bezel are four metal angle bars, one each for top, bottom, sides. I removed the top and right side one before realizing that if I removed any more, the panel would fall out.
So I screwed the top one back on, since the data cables were not at top or right side.. The side angles wrap around top and bottom, overlapping the horizontal members. Anyway, removing just the right side angle reveals the rightmost data cable at the bottom. Very thin and gold colored. At this time I took off the bottom, just to see the other cables. There are 12 of them, each evidently passing data for 165 vertical lines of pixels. It looked to me that the rightmost cable was slightly longer than the others, and had a little crease in it, probably from the bezel pressing on the over-long cable.
I put the bottom angle back on for safety's sake, and turned on the TV. Then hooked up and turned on an external drive with MKVs, and played one.
Here's the thing: Just like in one of the YouTube vids I saw, putting a little pressure on the suspect cable (with the non-conductive handle end of a screwdriver) caused the vertical red line to appear. So, again as in the video, I made a little pad out of electrical tape and placed it behind the cable, just below where it connects to the panel and directly behind the crease in the cable. There's a narrow space there. Now, pressing against the cable did *not* make the line appear. Fingers crossed, I re-assembled the TV. I ran it constantly all weekend and it was fine.
The TV has been running with no problems whatsoever for a few weeks now. It is now in the living room (not wall-mounted). I confess the mirror-like screen finally annoyed me enough to put a 70" matte-screen Sharp in my HT. (My wife is much less annoyed by the mirror screen, and the lighting there is less conducive to reflections).
Anyway, there you are. I'd call this a band-aid rather than a repair, although from what I've been able to gather, in many cases it seems to be a permanent fix. Actual TAB bond repairs are so expensive it makes more sense to just replace the panel.
fritzi93 is offline
post #2467 of 2488 Old 05-26-2013, 04:31 PM
utkinpol's Avatar
Hi,
I am struggling with my TV lately. I have configured it with static IP for 5g network, and streaming from tplink router I got last 'hansel and gretel' 3d movie - so, in all action scenes 3d payback 'freezes', like it pauses with audio suppressed, then continues. it is definitely not network, also newer LM6200 TV shows same movie flawlessly with no hiccups. what could be a culprit? too high FPS in the movie itself? or audio? is there anything that can be adjusted in menu settings? I tried to play with all I know but to no difference.
utkinpol is offline
post #2468 of 2488 Old 07-06-2013, 09:27 AM
avguru1's Avatar
Hello all:
I'm wondering if anyone has discovered what the data rate threshold is on the set?
I seeing that at around 10 Mbps, the set starts to stutter on playback. Anyone else seen this?
~Michael
avguru1 is offline
post #2469 of 2488 Old 07-08-2013, 06:36 PM
SteelDog's Avatar
Is this the largest passive 3D set available right now besides the Vizio? I think they have one of the same size. Just curious. I am thinking of getting one of these because I want passive and need to replace my old Mits.
Wash:"This landing is gonna get pretty interesting."
Mal:"Define "interesting."
Wash:"Oh God, oh God, we're all going to die?!"
Kaylee:"Goin' on a year now I ain't had nothin' twixt my nethers weren't run on batteries!
Mal:"Oh, God! I can't *know* that!"
Jayne:"I could stand to hear a little more."
SteelDog is offline
post #2470 of 2488 Old 07-09-2013, 08:55 AM
NSX1992's Avatar
Quoted: 25 Post(s)
No, LG and Sony make 84" 4K passive 3D sets and they are expensive but great.
NSX1992 is offline
post #2471 of 2488 Old 07-10-2013, 02:59 PM
SteelDog's Avatar
I should have clarified. I meant besides those ultra expensive 4Ks. Sorry.
SteelDog is offline
post #2472 of 2488 Old 08-05-2013, 07:35 AM
alvinhaur84's Avatar
I am not sure anyone here has the same problem as myself.
Previously my LG 47LW6500 is working fine.
But today I just unable to turn it on. When I try turning it on, the power indicator on the bottom right of the TV is power on (I think with the clicking sound as well). I can even press the touch screen (also located at the bottom right of the TV), but just nothing happen to the TV itself.
What should I do?
alvinhaur84 is offline
post #2473 of 2488 Old 08-18-2013, 06:12 PM
toshcalc's Avatar
Quick question - had my 55LW6500 for two years now and it's still having a very minor issue that is an annoyance when it happens. On some blu-rays during a dark scene, the screen often jumps to a brighter picture, dims again, and can jump back and forth. Seems to happen when there is a change in the amount of light on-screen. Bit of extra light on-screen, and the entire screen seems to brighten up (even areas of a scene that should not be "brightened"). I hope this explains the issue enough. Minor annoyance, but would love a solution if this is a fix-able issue. Thanks!
toshcalc is offline
post #2474 of 2488 Old 08-19-2013, 09:32 AM
fritzi93's Avatar
Liked: 39
That sounds like it might be the Energy Saving setting, which is on by default. Make sure it's turned off in Picture Settings.
From the manual: "When you first set up your TV, it ships in the Intelligent Sensor mode. You may notice a fluctuation in the screen brightness as room light conditions change."
Now that I think about it, I recall turning it off the first day I had mine, since brightness would fluctuate even when room lighting did *not* change.
fritzi93 is offline
post #2475 of 2488 Old 08-20-2013, 12:47 PM
toshcalc's Avatar
Thanks - I'll give that a try and see what happens.
Another quick one - no doubt already covered elsewhere so my apologies. When my 55LW6500 screen is completely black, there is some white "leakage" for lack of a better term around the edges of the screen. Is this a known issue, and is there a fix? Thanks again!
toshcalc is offline
post #2476 of 2488 Old 08-20-2013, 03:44 PM
fritzi93's Avatar
Liked: 39
Yeah, many (most?) edge-lit LED/LCDs exhibit that sort of clouding/flashlighting, to a greater or lesser degree. You shouldn't notice during normal viewing. (I can, just barely, if viewing very dark content. Like, say, the last chapter of Zero Dark Thirty, and I'm looking hard for it. My wife can't see it.) If you can readily see it in normal viewing, that would be unacceptable, IMO.
fritzi93 is offline
post #2477 of 2488 Old 09-12-2013, 03:57 PM
jimmy101's Avatar
My 55lw6500 won't see all my movies on my go flex home(nas), but my lg bd690 does.
I have tried resetting the dlna database in the go flex home. also my other devices see all movies
just fine. I have no idea what caused the tv to stop seeing all my movies, because it use to.
I'm also on the latest firmware for the tv 05.00.12
Any ideas?
jimmy101 is offline
post #2478 of 2488 Old 09-12-2013, 04:29 PM
Mine had that really bad... especially in the 4 corners. I tried everything to fix it that was mentioned on this forum... I ended up needing the panel replaced and the new panel has much better uniformity.
post #2479 of 2488 Old 09-14-2013, 01:56 AM
zeyden's Avatar
Hi everyone.
I'm very upset by the EZ Settings now... I just managed to reset my White Balance values in there - which of course didn't match the original value.
I didn't write down the values before playing with this, and now I'm getting a feeling that I've broken things really bad :-(
Would anyone please write up the original White Balance settings (Cool, Medium, Warm) for this TV? My model is 47LW650W (European Version) - but I'm sure it's the same panel as the LW6500.
These are the values I need:
R-Gain
G-Gain
B-Gain
R-Cut
G-Cut
B-Cut
THANKS IN ADVANCE. I'll be delightful if anyone can help me with this - will save my TV.
zeyden is offline
post #2480 of 2488 Old 01-08-2014, 05:44 AM
Bobcrane's Avatar
Netflix has been flaky since the 5.1x round of firmwares.
Is anyone else continuing to have a problem with Netflix? It's been so long since I tried that I forget the error code. It's a common LG code and basically says the selected title can't be played.
Then I have to deactivate the account. Do the 'Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up" etc on the remote to clear out Netflix. Then reactivate.
Then I'm good for a couple of weeks.
Anyone else have consistent problems or have found a more permanent solution?
Bob
Bobcrane is offline
post #2481 of 2488 Old 08-24-2014, 05:46 PM
jimmy101's Avatar
Exclamation
I just turn my tv off and on, that works for a while.
Never again will I buy another LG tv. Its been years and the firmware is still full of bugs!
jimmy101 is offline
post #2482 of 2488 Old 09-06-2014, 02:54 AM
Liked: 0
I have now searched this whole thread and found some nice settings for my TV aswell as changed the input of HDMI1 to PC, or Gaming Console to lower the input lag, and also changed the picture setting to "Game Mode" for my Xbox One, but I got another question, now that I am in Gaming Mode the picture is really dark and also lacks some color, I tried to change some of the settings (Most of them are greyed out anyways, the only thing you can basically change are the standard settings but nothing inside the expert menu or color calibration), but no big success till now. Can anyone tell me what settings you use to play either Xbox One or 360 or any other console in gaming mode?
Edit: My TV is a 47LB650v, the european model of the lw6500
Chambalaya is offline
post #2483 of 2488 Old 09-11-2014, 03:41 PM
tomtastic's Avatar
Quoted: 281 Post(s)
Liked: 95
I absolutely could not use this display for Call of Duty, the lag was so bad. I have the 65". It's a nice display, but I remember trying to use it for online multiplayer was impossible. At least where timing is crucial like in FPS games. I had to use my older LCD. It was like the joystick was lagging behind the screen. Nothing would fix it.
Sorry if that doesn't answer your question. The other think about this display is the glossy screen. I can't imagine why they would manufacture a glossy screen instead of matte. Makes no since to me. Then the other thing I noticed that really bugs me is that they used a single neck post for table top mount instead of dual mounts. This is so that it can swivel, but really this is very dangerous. It mounts in the back via 5 screws and there is a lot of side to side play in the stand. I'll probably be making a new stand with the wall mounting kit I have, but I just can't believe LG would let this fly. Every time my kids step in front of it I get very nervous. I have a couple of boards at each bottom corner to keep it from moving until I get something made.
This line intentionally left blank.
tomtastic is online now
post #2484 of 2488 Old 10-06-2014, 02:20 PM
My 55lw6500 gives me the boot up LG splash screen but then the display goes black? I get sound from the internal speakers so I know the TV is on and that the internal tuner is working for HD channels but not picture? Any ideas?
post #2485 of 2488 Old 10-06-2014, 04:17 PM
Fixed it. Took back off TV and tighter the connectors back on and now it works fine.
post #2486 of 2488 Old 08-17-2015, 08:17 PM
jimmy101's Avatar
Thumbs down
We are going to lose our amazon video app!!!
Hello,
We're writing to let you know that the Amazon Video app will no longer be available on your 2011 LG TV after September 14, 2015.
This means you won't be able to stream movies and TV shows directly from the Amazon Video app on your 2011 LG TV. As we continually seek to improve our service, this occasionally means we can no longer support certain devices or features.
To continue to access Amazon Video on your TV after this date, you can connect a compatible streaming device (e.g. Roku, Amazon Fire TV, and Fire TV Stick) or game console (e.g. PlayStation and Xbox).
Amazon Video is also available on hundreds of other devices, including newer Smart TV and Blu-ray models, Android and iOS phones and tablets, and your computer's web browser.
You can learn more about compatible devices and register a new device at:
https://www.amazon.com/instantvideo/devices
Sincerely,
Customer Service
Amazon.com
jimmy101 is offline
post #2487 of 2488 Old Yesterday, 06:46 AM
zingerhill's Avatar
When I got the message about Amazon all I could think was "that's why smart TVs are a bad idea!" It doesn't impact me any more since Tivo now supports Amazon Instant. However, I used to rely on the app. Really annoying.
Hello,
Sincerely,
Customer Service
Amazon.com
zingerhill is offline
post #2488 of 2488 Old Yesterday, 06:50 PM
steveting99's Avatar
Quoted: 1030 Post(s)
Liked: 324
This is a good lesson not to purchase a TV based on smart features being touted by the manufacturer. The developers of these smart features do have some control on the apps and one way for them to force a change (i.e. get one to buy another TV/device) is to disable these smart features that one is dependent on.
A buyer is better off on purchasing a TV based on it's picture quality that the TV manufacturer is unable (or at least unwilling their peril) to disable.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, WDTV Live, Harmony 650 remote, KEF E301+T101, MiniDSP(2x4) & 10x10HD, Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is online now
Reply 3D Displays
Lg Infinia 47lw6500 , Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv
