Samsung PN51D6500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 81 Old 03-16-2011, 06:10 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
Picked up this set today and after about 8 hours of use and 3D, i must say that its one of the best 3D sets i've ever seen, even over the 7000 series. Also to get to service menu just turn off tv then press mute, 182 then power and boom your in the service menu.
Kpkimmel is offline
post #2 of 81 Old 03-17-2011, 07:38 AM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
That is very good news indeed. Do you find the 3D picture brighter than the 2010 models?
jbug is offline
post #3 of 81 Old 03-17-2011, 11:21 AM
neutron77's Avatar
Any comments on the LCD remote control or the built-in WiFi?
I have one of these currently on order.
How much did you pay?
neutron77 is offline
post #4 of 81 Old 03-18-2011, 12:28 AM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
Yes the 3d is brighter, and i have two presets for regular and 3d, on 3d i put the cell brightness all the way up with 70 on the reg brightness and looks bright, crisp and clean, build in wifi is ok, not a big fan i use ethernet whenever possible, uh the remote is a reg remote not lcd.
Kpkimmel is offline
post #5 of 81 Old 03-18-2011, 07:19 AM
neutron77's Avatar
hmm, I thought I read this "The PND6500 series also has a LCD Touch Control TV " here:
http://web500.us/samsung-pn51d6500-5...a-tv-and-wifi/
I guess that didn't make into the release version.
post #6 of 81 Old 03-18-2011, 10:25 AM
tazz3's Avatar
Quoted: 26 Post(s)
sounds good where did you find this model??
tazz3 is offline
post #7 of 81 Old 03-18-2011, 06:17 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
abc warehouse, but yeah i wish i had the touch remote
Kpkimmel is offline
post #8 of 81 Old 03-19-2011, 11:07 AM
neutron77's Avatar
Actually, the page above that talks about the touch remote doesn't specifically mention the 51" model; so it is probably only included in the larger D6500 models.
post #9 of 81 Old 03-19-2011, 01:48 PM
rivered's Avatar
Do you notice a buzzing sound when the sound is off like with the C7000s?
And what are the differences between the D6500s and D7000s?
rivered is offline
post #10 of 81 Old 03-20-2011, 01:05 AM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
No, no buzzing, and i dont' think touch remotes made it to any of the tvs
Kpkimmel is offline
post #11 of 81 Old 03-20-2011, 04:29 PM
JMurph72's Avatar
Do you have your 6500 mounted? I am using the stand it came with and it has a slight lean back that I can't seem ti get fixed. I'm wondering if it is just the weight of the TV. Also, the link that was listed also said that the 6500 has a built in Web Browser. I hope you didn't get your hopes up for that because that only comes in the 8000 series
JMurph72 is offline
post #12 of 81 Old 03-20-2011, 06:10 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
no, mine doesn't tilt, might want to contact samsung or check your install, the stand was kinda tricky to get just right.
Kpkimmel is offline
post #13 of 81 Old 03-20-2011, 07:57 PM
JMurph72's Avatar
Anyway you can post a picture of a profile view of your set? I have taken the stand off and re-pieced it together multiple times now. The lean back isn't enough to notice when you are looking at it straight on, but it definitely tilts back a couple of degrees when you are looking at it's profile. I dont know if it is something to be concerned about being that is probably at an 85 degree angle, but if yours is a perfect 90, I want to make sure I am not harming the set
JMurph72 is offline
post #14 of 81 Old 03-21-2011, 12:12 AM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
yes i will tomorrow and i'll try to post it, not sure how or i can email it to you
Kpkimmel is offline
post #15 of 81 Old 03-21-2011, 10:03 AM
JMurph72's Avatar
you can add attachments in the reply button
JMurph72 is offline
post #16 of 81 Old 03-21-2011, 01:41 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
its tilts back very slightly, no noticable, i think samsung did this on purpose for weight and picture..
Kpkimmel is offline
post #17 of 81 Old 03-21-2011, 01:48 PM
Frank's Avatar
I was interested in buying one if these until I called Samsung and was informed that they no longer support checkerboard mode on their new plasmas.
Most people don't know or care but for those who do, I thought I'd mention it.
Did IQ's suddenly drop sharply while I was away?
I enjoy 3D in spite of HDMI 1.4!
Full screen only 3D doesn't cut it!
Frank is offline
post #18 of 81 Old 03-21-2011, 02:09 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
my tv checkerboards just fine, full resolution and sound native, so i'm not sure what samsung told you, my panasonic 3d bluray player with checkerboard 3d works perfectly on my tv
Kpkimmel is offline
post #19 of 81 Old 03-21-2011, 02:19 PM
Frank's Avatar
That's very interesting.
I was told that all the yet to be officially released new plasma TVs did not support checkerboard mode.
I asked it it was official and I was informed that is in fact official.
I will now call them back and inform them that your set does support it and ask for an explanation.
Frank is offline
post #20 of 81 Old 03-21-2011, 02:52 PM
Frank's Avatar
Two phone calls to Samsung support resulted in two entirely different answers.
Nothing official but it seems all the new Samsung Plasmas do still support all the additional 3D modes that the other companies do not support.
Frank is offline
post #21 of 81 Old 03-21-2011, 10:17 PM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
now there is nothing holding you back
Kpkimmel is offline
post #22 of 81 Old 03-22-2011, 07:11 AM
Frank's Avatar
You're right.
I'm getting the PN64D8000.
Frank is offline
post #23 of 81 Old 03-22-2011, 10:41 PM
JMurph72's Avatar
Question to all those who have brought home a 6500 set. I was using the 3D on my 51D6500, with content coming from Time Warner On Demand. To configure the 3D, the directions tell you to use the Over/Under 3D processing to convert the video to 3D. When I ran the 3D, the very top bar of the TV was showing video that should have been located on the bottom of the screen. I am wondering if anyone else has experienced this problem, and if this a video processing issue of the Time Warner set top, or is this a video processing issue from the 6500? If it is the TV I will exchange it before my return policy is up.
(I dont know why the picture is uploading rotating, but the line that runs down the left side of the screen, is really the top of the TV)
JMurph72 is offline
post #24 of 81 Old 03-23-2011, 06:39 AM - Thread Starter
Kpkimmel's Avatar
Quoted: 90 Post(s)
Liked: 31
no problem here, when you hit the 3d button on your remote, try all the 3d settings until it looks right.
Kpkimmel is offline
post #25 of 81 Old 03-23-2011, 09:29 AM
JMurph72's Avatar
The 3D still looks correct and you still get 98% of the 3D experience, there is just a bar hovering on the top of the screen that is in 2D and should be at the bottom of the screen instead of the top
JMurph72 is offline
post #26 of 81 Old 03-24-2011, 12:31 PM
jfich's Avatar
Hi,
What's the model of glasses you're using for that TV?
jfich is offline
post #27 of 81 Old 03-24-2011, 01:18 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
3D is brighter on mine for sure.
Mine buzzes. PN59D6500.
TheBrandon is offline
post #28 of 81 Old 03-28-2011, 01:46 PM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
Other then the buzzing how do you like the 59? I saw it on sale with a starter pack and was thinking about buying it.
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #29 of 81 Old 03-28-2011, 09:39 PM
TheBrandon's Avatar
Quoted: 36 Post(s)
It's pretty good. Buzz isn't a huge impact but mine is going back for another one this weekend. I had a string of stuck pixels show up. They disappeared but one, dead in the center.
post #30 of 81 Old 03-29-2011, 11:31 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
I'm thinking about pulling the trigger on the 59. Just a little hesitant cuz I do t know if I want to go active 3d or go a passive route.
lpnaz480 is offline
Reply 3D Displays
