Sony KDL-40NX711 questions... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-02-2011, 01:11 AM - Thread Starter
le14's Avatar
I was able to pick up this TV with the 3d Transmitter and a pair of 3D glasses for a price that I could not pass up. I searched the forums and online for reviews but could not find anything besides the specs for the LED. I was wondering if anyone knew anything about this LED or that if it was rebranded with a different product number, what would be the original product number from Sony so that I could research the LED some more for optimal viewing. Here are the specs and some pics:
What It Is And Why You Need It:
Full HD 1080p with 3D1
Dynamic Edge LED Backlighting with local dimming
Motionflow PRO 120Hz Technology for Smooth Motion
BRAVIA® Internet Video & Widgets2
BRAVIA Engine 3 fully digital video processor
Built-in Wi-Fi® for network connectivity5
OptiContrast Panel reduces ambient light
LightSensor adjusts backlight with room light
Energy Saving Switch eliminates standby power
Instantly convert 2D personal content into 3D w/ one button
Note: This model comes with 2 Adult glasses and transmitter in box.
Specifications
Sony 40" 3D LED LCD TV
Display Area: 40"
Display Type: LCD
Aspect Ratio: 16:9
Resolution: 1920 x 1080
Screen Refresh Rate: 120Hz
Signal Compatibility: 1080p
Input Video Signal: ATSC
QAM
NTSC
Condition: New
Features: USB
PC Input
Speakers: 2
Inputs: USB
PC
Composite
Component Video
HDMI
RF Input
Outputs: Digital Audio Out
HDMI Ports: 4
Power Consumption: 137W
Height (inches): 23
Height with Stand (inches): 24
Width (inches): 37.3
Depth (inches): 1.3
Depth with Stand (inches): 9.8
Unit Weight: 43.7 lbs.
If anyone has any suggestions or can point me in the right directions, please lmk.
le14 is offline
post #2 of 3 Old 05-02-2011, 05:05 AM
tory40's Avatar
I recently bought one of these for use as a multimedia PC monitor. Im not sure if your using it for that, but i'll put everything i know down anyway.
In no particular order:
1. I've read that the NX711 is an NX710 with a 3D kit (glasses, emitter) which means you should be able to consult NX710 reviews as well to get calibrated settings, but i haven't looked myself.
2. Sharpening kills text
3. The "picture" setting greatly helps bring back some of the lost brightness in 3D mode, but increases crosstalk.
4. Putting the "color" setting around 85 returns some of the lost colors in 3D mode.
5. IMO every single pre-set setting is horrible, but i prefer vibrant colors and bright lights.
6. Be sure to lock any guns you might own or other weaponry away before attempting to figure out what the Cinemotion and Motionflow settings do and how they might interact with each other.
7. Your limited to 720p @120hz for gaming because of the HDMI connection.
tory40 is offline
post #3 of 3 Old 06-13-2012, 01:51 PM
where did you get the bundle that included the tv and transmitter w/glasses? how much was it?
Tony Byland is offline
Reply 3D Displays
