LG D2342P 23" Passive 3D LED LCD Monitor - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 260 Old 05-27-2012, 05:59 PM
chang69's Avatar
Originally Posted by Jedi2016 View Post
Does the ghosting problem from the glasses also affect the clip-on lenses? Richard gave his clip-ons away, but did anyone else keep theirs, especially those that are having the ghosting issue?
I wear prescription glasses, and the clip-ons will definitely be the way to go for me. Regardless of how well they claim to fit, I can't stand wearing two pairs of glasses at the same time.
Yes applies to the clipons as well.
chang69 is offline
post #242 of 260 Old 05-27-2012, 06:09 PM
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Well, hopefully they have it sorted out by the time their IPS monitors come out. Not looking all that hopeful, though.. I watched a YT video from CES, and they had the guy wearing the glasses upside down because of the mixed-up polarization.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
post #243 of 260 Old 05-31-2012, 03:43 AM
chang69's Avatar
Well I am also caught between the LG don't about the problem support desk. So I bought two Zahlman glasses which work perfectly!
chang69 is offline
post #244 of 260 Old 06-27-2012, 09:24 AM
flashmaster's Avatar
hi
i am new to the 3D tv world and i have the lg dm2350D and it is working fine, i have an external harddrive with some downloaded 3d movies and they work fine 2 days ago just tried my first blu ray 3D dvd and this is fine..but with my pc which i am using a hdml is not good...when i click the 3D button i get like 2 screens over lapping..so i use the tridef 3d and all i get is what i think is very interlaced on the test screen and no matter what i do i does not change if i tilt the tv or move my head...when i play a film i still get the double vision and interlace and i can't think of any way of sorting this out
flashmaster is offline
post #245 of 260 Old 06-27-2012, 11:43 AM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
did you manually change the monitor to output side by side? Its under the 3-d option on the menu for the monitor.
RonAlam is offline
post #246 of 260 Old 06-27-2012, 10:19 PM
yes there is no other option i can see, if i can give you an idea what it looks like when playing a film, i have horzontal lines as soon as i but my glasses on and its worse the more i move my head...also there is bad double visiony (like 2 screens over lapping)
post #247 of 260 Old 06-28-2012, 10:16 AM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
and youre using the passive glasses correct?
RonAlam is offline
post #248 of 260 Old 06-29-2012, 10:12 PM
as far as i know i am i have 3 different types..the ones that came with the tv, ones from a shop and 1 from the cinema. i have seen films in 3D with no problem direct from the tv but if played on pc this is the problem.
post #249 of 260 Old 07-02-2012, 09:34 AM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
did you install the tridef software?
RonAlam is offline
post #250 of 260 Old 07-08-2012, 09:32 PM
Don28's Avatar
Originally Posted by flashmaster View Post
hi
I Just bought the D2342P-PN yesterday and found the problem like what he has mention above when HDMI cable is plugin (pc to monitor.)
1) it does not cover the full screen (shorter on the horizontal screen)
2) When playing movie on side by side format it show the problem as above mention.I have turn on the 3D option and select side by side and try all option in the 3d option all couldn`t work.
Also try the software tridef also could n`t work. try the L R or RL option also cannot work.
On DVI
using the tridef on dvi connection it work fine on 3D n 2D. I would say not bad at all.
Could anyone advice me on the problem above with HDMI cable. Thanks you.
Don28 is offline
post #251 of 260 Old 07-13-2012, 03:05 PM
Runxax's Avatar
Hello all,
I have LG D2542P that are very similar with D2342P.
And probably some of you can explain this situation....lets see:
-I have 4 3D Modes on screen options:
1- INTERLACED
2- SBS
3- T & B
4- 3D OFF
Even if I set 3D OFF, my screen still working like INTERLACED MODE, and I think that, its supose to working like any 2D monitor, dont????
Follow this test:
.using your own your Desktop
.Set on screen options 3D OFF
.Put your 3D glasses
- It will be very hard to read the smalest words!!!! DONT?
Now,
.Put glasses out, and you will read all whithout problems
Then,
.Set 3D MODE INTERLACED on your screen options
You will continue reading all very clear (nothing seems to change)
.Put glasses again
.and (same as 3D OFF) very hard to read.....
This is whats appens with me....and your expiriences?
Can I concluse that my monitor is allways INTERLACED ON? Even if I set 3D OFF?
Another test is by YOUTUBE,
Select one video and set on youtube to interlaced, the try to see whith your glasses in 3D OFF and INTERLACED MODE, I cant see any difference between them!!
Thank you a lot.
Runxax is offline
post #252 of 260 Old 08-09-2012, 09:06 AM
3D Bruce's Avatar
Hello Everybody
I am planning to purchase LG D2342P 3d monitor mainly for watching 3d BlueRay movies.
Now, what's bothering me is that I have heard that passive monitor offers great depth but lacks theater like pop-out effects and also passive is inferior to active displays in terms of pop-out effects. Actually I prefer pop-out effects over depth. So, it would be a great help to me if anyone can confirm this..
With Regards
Bruce
3D Bruce is offline
post #253 of 260 Old 08-13-2012, 01:34 PM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
RonAlam is offline
post #254 of 260 Old 08-23-2012, 09:46 AM
mayorice's Avatar
Hi, is there a minimum distance in order to view the 3D? because the distance between me and my monitor is 70cm and i can't move it further.
Also, do you think i play play game in 3d with a HD 6570 2gb graphics card?
mayorice is offline
post #255 of 260 Old 08-23-2012, 10:39 AM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
3ft to 4ft from screen should be fine, and use the supplied TriDef software.
RonAlam is offline
post #256 of 260 Old 08-25-2012, 04:32 PM
dvdmike007's Avatar
Liked: 50
Hi guys,
I just went out to buy this and came home with the 2012 model, the d2343.
Anyone know of any appreciable differences?
It's not even on the lg website!
dvdmike007 is offline
post #257 of 260 Old 08-26-2012, 12:28 PM
MultiD's Avatar
MultiD is offline
post #258 of 260 Old 08-26-2012, 12:58 PM
dvdmike007's Avatar
Liked: 50
Ah was not on the UK site
post #259 of 260 Old 08-30-2012, 03:39 AM
jonboyuk's Avatar
Hey guys!
I would like to ask a quick question about this monitor. I bought it recently and I too have found that there appears to be a ghosting in 3D mode (though HDMI/DVI), so I'm assuming there's something wrong with the glasses?
They do say 3D LED Monitor on the side of the arm, but could they still be wrong?
I phoned LG and they said "You can't use a 2.0m HDMI cable, it needs to be 1.5m for it to work best". I know that's BS, but I don't have a 1.5m cable to test. That said, it still does it with the provided DVI cable, so I'm pretty sure it's not the monitor.
I would get some Zalman glasses, do I need the SM-SG100G's? However I want LG to issue me some more (purely out of principle).
Any thoughts?
jonboyuk is offline
post #260 of 260 Old 09-09-2012, 01:30 AM
bl4ckstarr's Avatar
I just had a replacement received which is the same model but now label on the side of the glasses shows as 3D Monitor. It did solved the ghosting problem.
bl4ckstarr is offline
Reply 3D Displays
3d Hdtv , Led Hdtv , Lcd Hdtv , Displays , 23 Lg Widescreen Fullhd 1920x1080 Hdmi Vga Dvi 3d Led Lcd Black Monitor D2342p Pn , Sony , Lg D2342p Pn 23 Inch Widescreen Passive 3d Led Lcd Monitor
