ideal height for mounting 3d tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-12-2011, 06:12 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
my new plasma will be getting mounted tomorrow and im just curious how high do you recommend the tv to be?
i'm thinking where my vision is about half way from top to bottom.
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #2 of 14 Old 06-13-2011, 09:07 AM
walford's Avatar
You are correct all TVs should be mounted so that the height of your eyes when seated is in the middle of the verticle viewing area. This is especially important for 3D TVs.
walford is offline
post #3 of 14 Old 06-15-2011, 12:47 PM
hardrock_121's Avatar
thats basically dead center of the tv when u are seated?? in that case none of the wall mounted tvs will be accurately mounted.
hardrock_121 is offline
post #4 of 14 Old 06-16-2011, 06:56 AM
walford's Avatar
True unless you mount them lower on the wall which many unknowing users do not do and their Picture Quality suffers as a result.
Instead I always reccomend using stands which also provide a location for Set Top Boxes storage of DVDs etc.
walford is offline
post #5 of 14 Old 06-16-2011, 07:05 AM
andyw715's Avatar
Similar to how you would hang a painting or photo. Average eye level with respect to viewing position.
Nothing worse than going to someones house and having to look up all night at a display hung above a fireplace.
andyw715 is offline
post #6 of 14 Old 06-16-2011, 08:56 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
I went with a low table from ikea abs then mounted the tv above that. In all it is probably the same height if it were on the stand on the ikea table. The height is perfect. When I see my reflection on the screen I'm exactly in the middle
lpnaz480 is offline
post #7 of 14 Old 06-16-2011, 12:00 PM
TheGoatLantern's Avatar
You should go back to Ikea and get the led strands for ambiance
TheGoatLantern is offline
post #8 of 14 Old 06-16-2011, 01:42 PM
unfortunately thats how my tv is mounted right now.. right above the fireplace about 3-4 feet hangs the base of the tv so the center of the tv is about 5 ft but once u are sitting in the couch you drop down to about 3-4 ft but about 8 feet away....this is making me seriously reconsider my 3dtv purchase now... having second thoughts about gettinga 3d projector instead...
post #9 of 14 Old 06-16-2011, 03:06 PM
danielsdevelop's Avatar
I think if you get a tilting mount, you should still be able to mount the 3D TV higher, but still have the 3D effects working properly...
danielsdevelop is offline
post #10 of 14 Old 06-16-2011, 03:21 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
My LCD was high like 4-5 feet up but we used a tilt mount to angle it down. It worked out but with the 3d and moving the credenza that made us put the LCD high in the first place, I realized how much nicer it is being lower.
lpnaz480 is offline
post #11 of 14 Old 06-17-2011, 07:07 AM
mrjktcvs's Avatar
It all depends on what you are sitting in. I use a recliner, so I want mine a little higher on the wall and tilted down.
mrjktcvs is offline
post #12 of 14 Old 12-15-2012, 08:42 AM
Srinivasan's Avatar
Boss My Sony 3d HX850 46" Will be delivered in a day I wanted to install that in a table I really wanted to know what is an ideal height of the table which the tv has to be kept my sitting point will be about 9ft in sofa height of the sofa will be 1.5ft and I am a bit height person my height is 6.1 and may I know what height the table has to be bcoz I have to purchase it
Srinivasan is offline
post #13 of 14 Old 10-27-2013, 05:47 PM
aragno's Avatar
I would like to revive this thread instead of creating a new one.
There seems to be no clear answer here on 3D mounting height. I understand there is some personal preference at play, but the 3D effect must be engineered at a particular viewing angle (both horizontal and vertical). Can anyone factually comment on this?
I have a new tv being delivered tomorrow. I will use my existing mount and only mount again when I get some clarity on the proper height relative to my eye height.
Thanks for any information so I can get the most out of my new 3D tv (upgrading from an 8 year old 720p, pioneer plasma monitor).
-Trey
aragno is offline
post #14 of 14 Old 10-27-2013, 11:57 PM
Colm's Avatar
Liked: 94
Height is simple. Sit as you normally would when viewing and look straight ahead toward the wall where the TV will be mounted. Mount the screen as close to where you eyes are looking as possible. Angle is just as simple. Adjust the screen so that it is as close to perpendicular to your line of sight as possible.
Colm is offline
Reply 3D Displays
Sony Bravia 46 Inch Led Tv 3d Support Hx850 Kdl 46hx850
