Sony HMZ-T1 HMD Owner's dedicated thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3331 of 3395 Old 06-26-2013, 08:55 AM
Jonathan Hersey's Avatar
Why they wouldn't design this thing better is beyond me.
Jonathan Hersey is offline
post #3332 of 3395 Old 07-01-2013, 12:59 AM
connector's Avatar
Yes, Sony have to increase the comfort. is the only outstanding issue.
@Europe, you can contact me in www.diariosdelanube.com
connector is offline
post #3333 of 3395 Old 07-08-2013, 04:04 PM
Magicantian's Avatar
Magicantian is offline
post #3334 of 3395 Old 07-13-2013, 03:24 PM
andymckay's Avatar
did anyone manage to mod the t1 to remove the headphones and put a 3.5mm socket in its place to allow the choice of usinga chat headset or just earphones
andymckay is offline
post #3335 of 3395 Old 07-15-2013, 09:34 AM
m. zillch's Avatar
Quoted: 1838 Post(s)
Liked: 1175
There was discussion of doing that but I don't recall if it was ever done. Most Sony earphones often use litz wire which is difficult to solder, so if done the point to tap the signal should be a solder point on the board, instead of the wire itself.
Chatting via a microphone could not be accomplished because the HDMI protocol used by the Sony doesn't allow for audio communication from the headset back to the source device. Some HDMI devices do allow for this, so future incarnations could theoretically employ this, however.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #3336 of 3395 Old 07-17-2013, 08:04 AM
andymckay's Avatar
Got mine this morning (£300) off ebay and wow.
Only had 10 mins to play with it but had a flick through Avengers 3d and 2d Dark Knight which were fantastic.
Tried gran turismo 6 demo and found myself leaning whilst going round corners (the wife will find this hilarious)
Just need to do a quick mod to sort out the balance off my nose and will be well chuffed
post #3337 of 3395 Old 07-18-2013, 02:21 PM
post #3338 of 3395 Old 07-20-2013, 02:22 PM
ra111's Avatar
well, I've connected an iPad, iPhone and Raspberry Pi and laptop as well as a Bloggie 3D and Ps3 / X360. I do have a UG802 Android 4.1.1 which i can test though. Frankly I'd expect your phone to work as it has HDMI out and cannot see why it wouldnt...
ra111 is offline
post #3339 of 3395 Old 07-25-2013, 05:09 PM
post #3340 of 3395 Old 07-25-2013, 07:12 PM
m. zillch's Avatar
Liked: 1175
The Sony is basically a TV set with an HDMI input.  You can pretty safely assume any modern HDMI video source, be it a cable box, disc player, telephone, or media server, will work.
connector likes this.
post #3341 of 3395 Old 07-26-2013, 10:33 AM
connector's Avatar
Yes Ayn HDMI device could be reproduced bu Mhz-t1 or t2. And if tve source (pc, console, home Cinema, smart phone, Raspberri...) supports HDMI 1.4 tren will do 3D!
post #3342 of 3395 Old 07-30-2013, 05:49 AM
BienTobias's Avatar
Finally have my 1st Mods of Sony Hmz T1
Using Kids "BEN 10" helmet made of High Density Stryropor
Just thanks all guys who pioneer in Mods and guided Me to finally
arrive in these Design....
No more Red spot in my Forehead
Used 2 Lead Sink pods mounted at backside of the helmet (not shown pic) used in Fishing Rods accesories
to balance the front end Weight of the Unit
encounter some few design Flaw ...hahaha like the green lock in front which I use a LAME handle plastic of disposable shaver
LAME black TAPEss
and still looking for internal Lining of the helmet...for comfort fit..(???? seriously thinking of using the Girls Feminine Napkin???? for Lining of the Helmets?????) Lols
Its my 1st Mods and will further improve it ...
With these Mods..I used my Sony HMZ T1 for hours without any discomfort..LOLzzz
3D Movies and PC Games to the Max...Hahahahaha
See evolution of my Mods...
BienTobias is offline
post #3343 of 3395 Old 07-31-2013, 08:26 AM
donfazhan's Avatar
good things. Looking forward to seeing the photos and your initial impressions.thanks 10.gif
donfazhan is offline
post #3344 of 3395 Old 08-01-2013, 01:48 PM
BienTobias's Avatar
See additional Photo of my Ben10 Kids Helmet Mod
see details how 2 Lead Balls are place at the back end for balance ( weight must be almost same weight of the front end 420gms)
Used a Big paper clip and bend it 45 degree like a small hook and place inside front bottom-side panel where pads are supposed to placed
U shape hooks and anchor by plastic tie-rasp(used 2 pcs)
Ben10 Kids helmet are very cheap and made of HD styropor which very easy to cut and shape.
They very Light and strong....ideal for Sony HMZ T1
Will be using 3M double Tape to secure the Plastic cover of the Helmet design
Still looking for Helmet Lining.. The original lining used in the helmet are small and not of good quality.
As per Any Sony HMZ T1 owner...very happy of its 3D and 2D picture quality...
using a Toshiba Satellite L755-16K Intel Core i5 with GT 525 2G Graphic cards with Bluray Optical Drive
Window 7 Home Premium 64bit 8G RAM
Core 2 Desktop with MSI GT 630 as a 2nd Unit connected to 42 inc Plasma Panasonic TV
Power DVD 12 and VLC player software
Looking forwards See Pictures of all Guys Who will MODS...Any advice what Helmet linings to be Used???
post #3345 of 3395 Old 08-04-2013, 04:40 AM
ivandragos's Avatar
I got a used HMZ-T1 but when i press the power button on the HMD it produces a squeaky noise. Is that normal?
ivandragos is offline
post #3346 of 3395 Old 08-05-2013, 01:00 AM
connector's Avatar
i think it's normal.
post #3347 of 3395 Old 08-05-2013, 01:02 AM
connector's Avatar
Amazing job, sony engineers must take note.
post #3348 of 3395 Old 08-05-2013, 02:15 AM
kilobulb's Avatar
Yup it really is.
BienTobias - one question, The helmet being a kids one, is it not on the small side? Or are they likely to fit most adults as well?
kilobulb is offline
post #3349 of 3395 Old 08-05-2013, 02:31 AM
kilobulb's Avatar
Originally Posted by kilobulb View Post
Yup it really is.
Acorrding to Tesco it's 52-57cm so should fit most I guess.
kilobulb is offline
post #3350 of 3395 Old 08-05-2013, 05:19 AM
BienTobias's Avatar
Yes it will fill to average adult size.....it's placing padding or helmet linings are the fun part....
I guess any helmet will do that fit owns head size will do the Job.....
post #3351 of 3395 Old 09-27-2013, 06:14 AM
nyc3dwd60738's Avatar
Im selling my barely used like new hmz-t1.if intrested pm me
nyc3dwd60738 is offline
post #3352 of 3395 Old 11-17-2013, 09:52 AM
stratogustav's Avatar
So I have a Vaio CW with Windows 7, HDMI output and a Nvidia card. However the control panel for the Nvidia does says sterescopic anywher, I already looked through all the 3D settings. The CW comes with a blu-ray player and BD/DVD burner as well. It plays SBS 3D DVDs and Blu-Rays just fine.
However I have a lot of 2D material that I want to be able to see in 3D. The nw PowerDVD 13 has a feature that automatically turns 2D to 3D. I want to use my HMZ-T1 to see this content, but for some reaon I can't make the PowerDVD 13 make the 2D videos to SBS videos, it just makes them red and blue,
Does anyone know if it is possible to make PowerDVD 13 turn 2D videos into SBS 3D videos so I can see them in my HMZ-T1?
stratogustav is offline
post #3353 of 3395 Old 11-18-2013, 11:12 AM
borland's Avatar
Quoted: 20 Post(s)
Liked: 50
disable second monitor, make HMZ primary, launch Power DVD, enable 3D if it's no enabled - enjoy. I have zero problems with my Toshiba ultrabook Z830 and Toshiba Tablet WT with Win 8.1
borland is offline
post #3354 of 3395 Old 11-19-2013, 12:41 PM
Apocy's Avatar
Hi guys,
Great thread and really interesting mods on the Sony.
I've had mine for a year now and I've been browsing and looking for any mods that will make this peace of torture more comfortable. I've tried headstrap mod but it wasn't that good. Helmet mods need a lot of work and in the end you can't really lay down and relax with half of helmet on.
Finally I was able to finish my idea I had for a while and I've finally done it ! I cost me about 15 Euro and was not that difficult to make. Also it is completely removable.
The idea was to make the Sony be as a snowboard mask with foam and also make it so, that it is pitch black once you put it on, no light coming from anywhere. The picture shows the the final "beta" and now I have the "mask" with which I can cut new forms of foam and make it look better once it is applied.
Apocy is offline
post #3355 of 3395 Old 11-19-2013, 01:28 PM
Yeah, I was able to make my HMZ-T1 the primary display and remove completely the laptop monitor as a display, however PowerDVD 13 still does not convert videos to side by side. The only conversions I get are:
1. Anaglyph Red/Cyan Mode
2. 3D-Ready HDTV (Checkboard)
3. Micro-polarizer LCD 3D (Row-Interleaved)
None of those 3Ds are side by side or top to bottom, so my HMZ-T1 cannot process them, I was hoping that with the later 2 the HMZ-T1 would at least automatically detect them, but it doesn't. I don't know how to solve this. My guess is that because the Nvidia control panel does not offer stereoscopic settings, the PowerDVD 13 does not gives me the option of side by side in the conversion.
However is odd, because the computer does read blu-ray 3D side by side videos just fine.
I really wanted to buy the PowerDVD 13 for the "LIVE" 2D to 3D conversion. All other programs I know offer 3D conversion but only by making a separate processed video, therefore wasting a lot of time and space in my laptop.
Does anyone knows if this has a fix or if there are any other good programs out there that offer 2D to 3D side by side live conversion?
post #3356 of 3395 Old 11-20-2013, 05:55 PM
Or maybe the HDMI outlet isn't 1.4 and that's why PowerDVD doen't give me the side by side option. Had anybody been able to get side by side with it?
post #3357 of 3395 Old 11-27-2013, 08:02 AM
jjhedden's Avatar
I have a new in box T1 up for sale right now, pm me if you are interested.
jjhedden is offline
post #3358 of 3395 Old 12-11-2013, 07:18 PM
Afrikan's Avatar
hey everyone.
Can I ask what has been the most common issue with this device which required some to send it back to Sony for an exchange? My warranty (2 year replacement) is about to be up and I haven't used this device much, and I want to double check areas that might become issues after my warranty is over.
Afrikan is offline
post #3359 of 3395 Old 12-12-2013, 03:41 PM
Originally Posted by Afrikan View Post
hey everyone.
No issues whatsoever with mine, is Sony after all, pretty durable as well, the only issue I guess is the comfort issue, it can really make not want to use it as much as you would like to.
post #3360 of 3395 Old 12-24-2013, 03:49 AM
nabilghali's Avatar
I just received hmz-t1 3days ago
Connected it to my msi gs 70 laptop
It worked fine with movies and games in 2D mode
But when I try it with 3d vision games as batman origins or latest tomb raider it gives me black screen with no signal notification above though it picks up 3d signal when game opens
My graphic card is nvidia 670m
and stereoscopic vision is enabled
Tried to install 3dtv play the same problem still there
So if any one can help?
Sorry for my english
nabilghali is offline
Reply 3D Displays
3d Hdtv
