Sony HMZ-T1 HMD Owner's dedicated thread - Page 114 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #3391 of 3395 Old 06-09-2016, 01:20 PM
federderemate's Avatar
Originally Posted by jimlau View Post
bought mine used. 1 button was a bit iffy but was tolerable. Been using it for 2 months just fine. Now no buttons seem to work, except the power button. I get to the welcome screen, but can't go beyond.
I unplugged all, secured cables, held the power button for 10 seconds, nothing.
Is it possible to open it up and check contacts maybe? Otherwise a total loss, as the warranty is past.
Hi Jimlau, look at red circle. May be you could try open it up and then check that connector. Pull up flex (be gently), clean it and install it again. Try it!
Greetings.
federderemate is offline
post #3392 of 3395 Old 06-23-2016, 03:08 PM
jimlau's Avatar
Quoted: 23 Post(s)
Greetings.
thanks. will try when i get the right tools. what all needs removing in order to get to that area? does the bottom panel come off, or do you have to go from the top down?
jimlau is offline
post #3393 of 3395 Old 06-25-2016, 09:04 AM
stumlad's Avatar
Can anyone tell me the length of the original HDMI cable that came with this unit, whether it has any special markings, etc. I'm going to probably sell mine but I'd like to include the original HDMI cable.
stumlad is offline
post #3394 of 3395 Old 08-08-2016, 08:55 AM
RonAlam's Avatar
Quoted: 27 Post(s)
Liked: 39
would that really impact the cost?
RonAlam is online now
post #3395 of 3395 Old 10-22-2016, 12:42 PM
jimlau's Avatar
Quoted: 23 Post(s)
HMZ-T1 Compatible with HMZ-T2?
is the HMZ-T2 headset compatible with HMZ-T1 box?
jimlau is offline
Reply 3D Displays
3d Hdtv
