Possible stand for Sony HMZ-T1 - AVS Forum | Home Theater Discussions And Reviews
Old 12-05-2011, 04:47 PM - Thread Starter
benz145's Avatar
Hi folks, I happened to be browsing the Astro Gaming website the other day (they make gaming headphones) and happened across a nice looking stand that might work well with the Sony HMZ-T1. Because the HMZ-T1 is designed to sit flat when not in use, the stand would offer a smaller footprint, saving you desk space, or it would likely be a good way to show off your HMZ-T1, when not in use, next to your home theater setup.
If you're one of those that dropped $800 for the HMZ-T1, you probably won't mind the $35 pricetag for the stand. Have a look at it:
http://roadtovr.wordpress.com/2011/1...-hmz-t1-stand/
I'm not 100% sure that it would actually work, but I'm sure that a brief test using a simple substitute from an owner of the HMZ-T1 would tell us one way or another if this would work well.
What do you think, would you like to show off the HMZ-T1 in this way?
benz145 is offline
Old 04-06-2012, 06:03 AM
iTTT's Avatar
Seems good, thanks a lot
iTTT is offline
