Samsung Plasma 3D - can't set top / bottom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-09-2012, 02:25 PM - Thread Starter
andysvi's Avatar
When I want to watch ESPN 3D which is top / bottom format, I go to the menu to select that 3D setting and the only option available is the 2D to 3D option. None of the other are accessible. I was able to get to these before.
Can someone help me? Please.
Don't know if my 8yo changed a setting or something. It's a Samsung 50 inch plazma about a year old.
andysvi is offline
post #2 of 7 Old 01-09-2012, 08:31 PM
bryanpog's Avatar
Hmm. U might want to check settings. I just bought a D550 and when I go to espn 3D I get the side by side pic and all my options are there when I hit the 3D button. Not that it helps but I use Directv Milwaukee WI area.
Ps. The national championship looks great! :-)
bryanpog is offline
post #3 of 7 Old 01-10-2012, 06:52 AM
Super Moderator
teachsac's Avatar
Quoted: 840 Post(s)
Liked: 1363
Who's your provider and how are you connected (through what equipment)? D* uses 1080i SbS for ESPN. Your Samsung should detect the proper signal automatically.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #4 of 7 Old 01-10-2012, 11:18 AM - Thread Starter
andysvi's Avatar
Thanks guys. I have comcast for cable. The ESPN channel comes in great its a top / bottom format. But when I got to select that format from 3D options ... they are "grey" and not accessible. I tried unplugging the box. I've seen other posts with this problem ... but no answers. I was hoping it was a settings thing. Dang.
Any other thoughts.
andysvi is offline
post #5 of 7 Old 01-10-2012, 12:07 PM
Super Moderator
teachsac's Avatar
Quoted: 840 Post(s)
Liked: 1363
How are you set up? Are you going straight to the TV from the cable box? Running through a receiver (which one), and I'm sure you're using HDMI.
S~
teachsac is offline
post #6 of 7 Old 01-12-2012, 09:52 AM - Thread Starter
andysvi's Avatar
Teachac -
Yes, I don't have a receiver only a blu-ray player, so I think it goes straight to the TV from the cable box, I'll have to check. Since I'm getting the ESPN 3D channel ok, would it not have to be a TV setting problem? Yes, I'm using HDMI.
Hmmm ... it worked before... very frustrating.
If I figure it out I'll post an answer here.
andysvi is offline
post #7 of 7 Old 01-13-2013, 04:27 AM
Joost Hebly's Avatar
hello every body i just buyt the epson eh-tw6100 full hd 3d projector
yesterday i hookt my pc on it and i downloaded a full bluray 3d movie avatar
the movie was top bottom 3d you saw the molvie twice above ethather
but not 3d so i went to the settings of my beamer and chanced that to top to botom but when i did that
you saw the good 3d for like 2 sec then it went black and after a few more you saw it movie again for a few sec and so it whent on
how can i fix that?
thnks for the help
greetings joost
Joost Hebly is offline
Reply 3D Displays
