acer h5360 help setup 3d - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-09-2012, 09:20 PM - Thread Starter
jallen49's Avatar
hey all, just got this projector a week ago and ive been trying to get this 3d to work for a while now but no luck so far.
first off heres my setup:
acer h5360 projector
radeon 5770 gpu
ultimate3dheaven dlp link 3d glasses
projecting onto a white wall
the projector is hooked up to the gpu through a normal hdmi cable that supports an audio and video signal, is this correct? do i need a special cable?
i have downloaded iz3d driver and iz3d mpc and have the latest catalyst control center driver as well as gpu drivers.
when i go through the dynamic stereo test i can manipulate the image convergence and separation but it looks the same through my glasses as it does through the naked eye. what am i missing?
when i turn the glasses on it recognizes a 3d signal and goes into a darkened shutter mode so im assuming it is syncing with the projector. i have the projector set to DLP 3d.
Im at a dead end here. i was under the impression that in order to get 3d to work with this projector i would need the dlp link glasses and a stereoscopic player with a decent gpu with the updated drivers.
please, any help will be greatly appreciated!
Thanks, J
jallen49 is offline
post #2 of 3 Old 01-10-2012, 01:23 PM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
Did you set the refresh rate to 120Hz? You probably did, if the glasses sync.
I would guess the problem is with the player (I am not familiar with it).
You may try TMT5 trial with a bluray 3d.
Roussi is offline
post #3 of 3 Old 01-11-2012, 09:23 AM - Thread Starter
jallen49's Avatar
yeah i downloaded tridef and it worked right away, go figure.
jallen49 is offline
Reply 3D Displays
Acer H5360 3d Dlp Projector
