Will the Sharp Aquous LC-60LE633U do 3D? - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2012, 11:47 PM - Thread Starter
jynx's Avatar
jynx is offline
Old 01-10-2012, 07:47 AM
Super Moderator
teachsac's Avatar
Quoted: 654 Post(s)
Liked: 962
Did you investigate the Sharp site for the specs? No, it doesn't.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 01-10-2012, 09:23 PM - Thread Starter
jynx's Avatar
I did. It has the required refresh rate and HDMI inputs. I know the TV does not have a 3D mode/setting. I was hoping that the Monoprice 3D converter (or similar) might work. But guess not.
Thanks for the response.
jynx is offline
Old 01-11-2012, 07:37 AM
Super Moderator
teachsac's Avatar
Quoted: 654 Post(s)
Liked: 962
That's a different question. Yes there are devices for 120Hz TVs that will simulate 3D. Look in the components forum.
S~
teachsac is offline
Old 01-11-2012, 02:09 PM
Justin-Dawson's Avatar
Are you planning to buy this TV or do you already have it? If you're planning on buying a TV - DEFINITELY buy a TV with 3D. DO NOT, I repeat, DO NOT buy a TV and then buy some crappy converter.
Justin-Dawson is offline
Old 01-11-2012, 09:13 PM - Thread Starter
jynx's Avatar
Already got it. We wanted a new TV. the wife picked it up at Costco (on sale) and to surprise me, had it hung when i was out of town. We've had it for to long now to return in.
Is there a better converter then another or do they all pretty much suck?
jynx is offline
Sharp Aquos 60 Led 1080p 240hz Hdtv Lc 60le633u
