Mitsubishi WD-73640 updates - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-14-2012, 07:07 PM - Thread Starter
BIGGGDADDY72's Avatar
I have a Mits. WD-73640 i was wondering if there will ever be a future update to allow this tv to adjust the depth in 3d,and if that would be possible.
BIGGGDADDY72 is offline
post #2 of 4 Old 01-16-2012, 08:54 AM
JOHNnDENVER's Avatar
Do the newer Mitsu models have this?
JOHNnDENVER is offline
post #3 of 4 Old 01-16-2012, 10:16 AM
GEP
GEP's Avatar
The 73640 is one of the newer models, all of the end digits of 40 seem to be the most recent models.
Per the Onwers Guide page 22 it seems that "Depth" adjusts the depth in the "2D + Depth" (2D to 3D conversion) feature. It does not sound like it is intended for real 3D signals.
2D+ Depth When selected, generates a simulated
3D image from an ordinary
2D image. Adjust the effect using
the Depth setting. Requires use of
active-shutter 3D glasses.
If your depth seems incorrect with real 3D signals, I suggest you change try the "Glasses L-R" in the opposite setting to see if that improves the image.
GEP is offline
post #4 of 4 Old 01-16-2012, 04:53 PM - Thread Starter
My picture is fine,just wondering if i might be able to add more depth in the future.
Reply 3D Displays
