Can HDMI 1.4 120HZ support TV refresh rate at 240Hz ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-02-2012, 12:52 AM - Thread Starter
batista11b5's Avatar
HI everyone , I'm using Rocketfish RF-G4102 . This is the feature :
http://www.amazon.ca/gp/product/B004...F8&me=&seller=
+From that amazon site , they said that is HDMI 1.4 at 120Hz . I'm using LG 55LW6500 at 240Hz ,and wondering that Do I need a 240HZ HDMI cable ? Because I want my TV use thorough 240Hz at the Spec of the TV when watching 3D .
+Any Ideas ? Thanks
batista11b5 is offline
post #2 of 8 Old 02-02-2012, 03:08 AM
Seegs108's Avatar
Quoted: 4967 Post(s)
Liked: 2485
That HDMI cable should suffice. The 240hz has to do with the internal refresh rate of the panel. It has nothing to do with the incoming signal. If you take a look at the acceptable inputs for this TV at 1080p you'll see the following:
1080p Source Input
HDMI: 60p/30p/24p, Component: 60p/30p/24p, RGB: 60p (WXGA)
The TV takes one of the inputs and interpolates the signal. 4:4 pulldown for 60hz, 8:8 pulldown for 30hz, and 10:10 pulldown for 24hz incoming signals.
There is no native content, other than from a PC, that is over 60hz. 3D content is still 24p, and usually, it's two 24p images. One for the left eye and one for the right eye that the TV will speed up to some integer of 24 to alleviate flickering or motion issues.
Seegs108 is offline
post #3 of 8 Old 02-02-2012, 08:28 AM
pete4's Avatar
You have 2 types of HDMI cables: normal speed and high speed, high speed should be able to support up to max data rate of 10.2 Gb. as per HDMI 1.4 specs, so it should work even with computer outputting 120Hz, but your TV can't accept anything above 60Hz.
Personally I always use Monoprice.com for all cables, unless I can't wait and have to have it yesterday, so I pick from the local store.
But since it seems you're in Canada, I'm not sure how would that work.
pete4 is offline
post #4 of 8 Old 02-02-2012, 10:09 AM - Thread Starter
Thank you guys a lot , by the way , Do you guy recommend the cable that I listed above (Rocketfish RF-G4102) on amazon ? The original price was 90$ , just bc that's a used one on amazon , so the price is 23$ .
post #5 of 8 Old 02-02-2012, 10:12 AM
Gino the tv guy's Avatar
Don't waste your money. You can go to Costco and get yourself two hdmi 1.4 cables for less than $40.00. As long as its 1.4.
Gino the tv guy is offline
post #6 of 8 Old 02-02-2012, 01:25 PM
walford's Avatar
Cables labeled as HDMI 1.4 are no longer legal. Cables are now labeled as standard speed or as high speed see:
http://www.hdmi.org/manufacturer/hdm...ght_cable.aspx
walford is offline
post #7 of 8 Old 02-02-2012, 03:29 PM
Super Moderator
teachsac's Avatar
Quoted: 814 Post(s)
Liked: 1335
If you're buying from Amazon, the Mediabridge work wonderfully and they're inexpensive.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #8 of 8 Old 02-05-2012, 02:56 PM
kemetblk's Avatar
Quoted: 16 Post(s)
I use Rocketfish cables in both my systems as well and have never had a problem. I'm sure the recommendations made by others here will work fine as well, just wanted to let you know that the ones you have work great also.
AVR: Denon X3300
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3 / Sub: SVS PB12-NSD
Sony XBR-75X940D, Toshiba HD-A30, Nvidia Shield TV (2015), Xbox One S, PS3
PC: Core i7, 16GB RAM, 512GB ssd + 4TB hdd, GTX 970 SSC
kemetblk is offline
Reply 3D Displays
