How can I get "Hulu Plus" on LG 55LW6500 Smart TV ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2012, 11:39 PM - Thread Starter
batista11b5's Avatar
HI guys , I'm using LG 55LW6500 , but it only content Netflix , I can not find Hulu Plus anywhere . Can anyone help me add HuluPlus to my LG TV ?
batista11b5 is offline
post #2 of 3 Old 02-11-2012, 12:18 PM
huntm856's Avatar
I have a 5600 but I think if you update the firmware to the most recent version you should get Hulu Plus.
Go to http://www.lg.com/us/support-product/lg-55LW6500, click on software update tab, follow instructions. You'll need a thumb drive.
huntm856 is offline
post #3 of 3 Old 02-11-2012, 05:11 PM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
I have the 47" version and it's on there. Just look under APPS and you should be able to locate it.
cinema13 is offline
Reply 3D Displays
